Question about Samsung SGH-U600
Samsung u600 WMC ACM 1.0 App. An error occured during installation of the device. The data is invalid. plz hel me for this
  • 1 more comment
  • raees Dec 13, 2007
    plz hel me for this
  • Anonymous Apr 19, 2008
    cgnfhfjyhf
  • Eastern_swor Apr 22, 2008
    plz hel me for this
Unable to download images on to computer
Posted on May 14, 2008
  • edfarm May 14, 2008
    I need the software downloaded for samsungmobile U600 as my computer is not recognizing phone when when plugged into USB
  • 425 Answers
Probably incompatible software...
Posted on Jan 02, 2008
49.4C02-Error to continue turn off then on.
A critical firmware error has occurred.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
firmware operations.
NOTE In many cases, turning the
power off and then on will
permanently clear most 49 errors.
In some instances, electrical noise in the
cable can corrupt data during transmission to
the device. Other causes include poor-quality
USB cables, poor connections, or specific
software programs.
1) Upgrade the firmware.
2) If the message persists:
Turn the MFP off.
Remove the DIMM.
Remove any installed EIO devices.
Turn the device on.
If the error message disappears,
reinstall the DIMM and EIO
devices individually, making sure
to turn the device power off and
then on again as you install each
device.
g. Replace the component that
caused the error message.
May 20, 2011 | HP LASERJET M5035 MFP All-In-One Printer
49, 4c02 error in hp 4250
This is what the result for that error code is:-
ERROR 49.XXXX
A critical firmware error has occurred that caused the processor on the formatter to abort the operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some instances, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or specific software programs. Remove all EIO devices and firmware DIMM if installed. Restart printer. If error is gone replace each EIO device until error appears. Replace device which triggers error. May also be formatter.
Firmware updates are available for some machines at http://hp.com and clicking on the drivers and software tab. Also try printing from a different application. If that works go back to the first application and try printing a different file to determine if the problem is file related. You may need to reseat the memory DIMM's or replace the firmware DIMM or formatter board.
Feb 08, 2011 | HP LaserJet 4250dtn Printer
Photoshop 7.0 installation fails with the error message: "An error occurred during the move data process : -106" Upon install process it makes it to about 1% then gives the following error code....
one problem that could cause this error is lack of administrator rights,
right button click the setup.exe or whatever it called and select run as administrator,
Or if it's Vista try the compatiblity help , right button click the app, select properties and select run as XP service pack2 etc
Regards
gewiz.co.uk
Nov 30, 2009 | Computers & Internet
Whentrying to installed any new hardware.PC wont work new items
MY FRIEND THERE IS PROBLEM IN UR USB PORT.PLZ CONTACT TO GOOD DEALER OR WHR U PURCHASED UR LAPTOP
Mar 28, 2009 | Acer Aspire 5101WLMi Notebook
Error 49.420c
first try to upgrade the firmware
second try a cold reset
if this dont work change the formatter
Aug 06, 2008 | HP LaserJet P3005 Printer
Installing error code -106
I suggest go to Start/Settings/Control Panel/Add remove programs.
Check and see if the program is in list and remove it. While in control panel go to system/Device Drivers check non have a yellow mark on them if so reinstall drivers or upgrade Reboot and try again.
Jul 22, 2008 | Computers & Internet
Samsung mobile phone usb problem
When you try to load up the drivers for the device you get an error that states that your data is invalid. Here is the fix as I found it on the web. I wish that I had marked where I found it, but didn’t. Why do I get the message "data is invalid" when installing a device driver under WindowsXP? This error appears to be due to a protection problem in the Windows registry and can occur with a variety of drivers (sound cards and SCSI drivers have been reported). To fix this problem, go to Start, Run... and type "regedit" without the quotes to run the Registry Editor. Navigate to: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ENUM\PCI You will see a number of keys of the form "VEN_xxxx", where xxxx are strings like "1102&DEV_0004&SUBSYS_00011103&REV_04". Under each of these folders will be another folder with a long numerical name. Open each folder and look for the "DeviceDesc" which matches the hardware you are trying to install. Right Click on the "VEN_xxxx" for that device and select 'Permissions' and then tick "Allow" for "Full Control". Close Regedit and then continue with the installation of your device.
Jun 02, 2008 | Pioneer DE-U7001 (DEU7001) Drive
Samsung SGH-U600 Logo
682 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
