Question about Palm Treo 650 Handheld
Receiving MMS on Treo 650
I can't get MMS on my Treo 650. Even the Palm Technical support team can't help.
  • MoHoney1 Dec 19, 2007
    Yes I also have an Treo 650 with Palm OS that the MMS is totally missing from, I go into pictures and got to send a picture and my only options are Versamail which is emal and Bluetooth...please help,, I want to be able to click on a picture and send mms...
That soulution dont seem possible with Palm treo 650 running Palm OS
Posted on Dec 19, 2007
  • 537 Answers
This device should be compatible with MMS.
I found this thread which might help you set up MMS on your Treo 650. Look at the 2nd entry:
1. Start, Settings, Connections, and then tap the Connections Icon
2. Under "My Work Network" tap Add a New Modem Connection
3. Name it Picture Messaging and under Select a modem select (GPRS,3G)
4. Under Access Point Name type:
5. Username, Password, and Domain is left blank and then click Finish
6. Now, go into Proxy Settings and check "This network connects to the Internet" and check "This network uses a proxy server to connect to the internet"
7. Under the Proxy Server box type:
8. Tap the advanced button and tap on the HTTP line. Make sure the HTTP settings shows If not, change it.
9. Click the OK button a few times to get out of the settings completely.
10.Now go to Start, Messaging, Menu, then Options, Advance, then Click Manual, and then the Edit button
11. Message center number +12063130004
12. Email center number is 500
13. MMS gateway address is
14. MMS URL is
15. Finally under Network Profile select: My Work Network and then click ok.
Posted on Dec 13, 2007
Hi how to unlock my palm 650 to used outside of USA
You can use the Unlock code to Unlock Your Palm-One Tero 650 model Phone,You can get the Unlock code from here
Wickedunlock and follow the instructions and Unlock it step by step..
Palm One Treo 650 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Palm One Treo 650 mobile phones. If you enter over a certain amount of wrong unlock codes on your Palm One Treo 650 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Palm One Treo 650 with an ACCEPTED SIM Card,
2 - Go to Menu and select "Phone Tool" or "Phone Application",
3 - Type on Virtual Keyboard *#*#CODE#,
4 - Select with PEN "Numer" and Palm One Treo 650 will show that it's unlocked now!
1 - Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
2 - Enter the Unlock Code we send to you.
1. Remove Palm One Treo 650 battery, unplug cable,
2. Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
3. 'Sim not allowed' is displayed, click OK,
4. Go to the dial pad, and dial *#*#CODE#,
CODE: The unique unlock code for your Palm One Treo 650.
ACCEPTED : We mean, to use a sim card from the network your Palm One Treo 650 is locked to.
NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Palm One Treo 650 is locked to.
Jul 10, 2011 | Palm Treo 650 Smartphone
Instructions on how to unlock the IMEI code for a palm treo 650? Just need the steps.
There are some unlocking sites for Treo but most of them have charges.
Hope this site can help:
Feb 22, 2010 | Palm Treo 650 Handheld
My voice drops out on palm treo 650
Sorry, no solution - just some added info. I have the same problem with a Palm Centro. Changed sim card (O2) but no improvement. Palm eventually replaced Centro, but fault persists. Anyone with similar problems / solutions?
Sep 13, 2009 | Palm Treo 650 Handheld
I forgot my code to unlock my palm treo 650 cell phone
A last resort is to hard reset the device, but you will loose your data.
See here how to hard reset.
Jan 09, 2009 | Palm Treo 650 Handheld
How can i turn off the annoying LED light?
There are several possibilities. One is a little freeware application called LEDOff. Just Google "palm ledoff" and go to the first site you see. It says it's for the Treo 600 but it works great on my 650.
The other solution is to put some kind of barrier over the light, like electrical tape. If you're feeling adventurous, you could even open the case and put the tape on the inside so it doesn't ruin the look of your device.
I can't for the life of me figure out why the Treo designers used such a bloody bright LED. I mean, it's like a laser! If you try to look at the screen when it's charging you'll likely get a headache. But the utility I mentioned even turns off the charge light.
Dec 02, 2008 | Palm Treo 650 Handheld
Not receiving some of my text messages
I also have a Treo 650 that works flawlessly. I'm on AT&T and sometimes a message gets delayed but I don't think I've ever missed a message. I would believe it is the verizon network. It could also be effected by sunspots and the part of the world you are in.
good luck
Nov 14, 2008 | Palm Treo 650 Handheld
Palm treo 650 phone
Greetings to all. I have just purchased a palm treo 650. It was unlocked so I was told, but it was not a GSM, It was a CDMA, My carrier is T Mobile and I dont know what I could to Make It Work, as t mobile has a sim card and this treo 650 does not. Is there any thing I could do to solve this problem?
Aug 28, 2008 | Palm Treo 650 Handheld
Palm Treo 650 Unlock Code.
Call your service provider.
Jul 16, 2008 | Palm Treo 650 Handheld
Palm treo 650
Hi Sandra Bunch,
Could you inform us which treo do you use? If you use Treo 650 or newer, than you could buy desktop charger beside ordinary palm charger. But if you use Treo 600 there's no alternative than buy the ordinary palm charger. It's easy to get this accessories on the net, you could try or
Nov 10, 2007 | Palm Treo 650 Handheld
I would suggest a hard reset.  Be sure that all of your information is backed up prior to preforming these steps.
Please follow the hard reset instructions in the following publication.
(copy/paste this into your browser),Kb=PalmSupportKB,ts=Palm_External2001,case=obj(887)
Let me know if this works.
Oct 17, 2007 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
653 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
