Question about Kenwood DVR-505 DVD Player
No Sound on Kenwood DVR-6300
When I am in Video-1 mode(sound replacing my TV's speakers), I only get sound while the DVD door is in the act of opening or closing.
The sound is goes off when the tray is fully out or fully closed.
  • safesound Jan 02, 2008
    I am working on a boat that has 2 Kenwood DVD-6300 receivers. The first 6300 there is no audio on either video 1 or video 2 inputs. The am/fm and dvd are ok.
    The second receiver does not respond to any IR or direct commands and the display on the 6300 is fragmented. It is stuck in DVD and will output video to the TV but will not play the DVD.
    I checked the receivers for 110 volts, I bypassed the receivers A/V inputs and went directly to the TV and proved the satellite receiver and VCR are operating normally.
  • 4234 Answers
SOURCE: DVD tray makes noise when it rotates
This noise can be casued by two things:
1) The tray is not completely in the loaded position and the "clamper" is rubbing. Replace the loading belt and the loading sequence will complete and the noise should stop.
2) The "CD table" that is part of the spindle motor assembly has slipped a bit. This will make the CD/DVD ride too low and strike the lower tray support. This will require that the table be "re-aligned" to the proper height which may not be possible on your model without special measurement equipment. The height is critical to proper operation of the unit.
Try replacing the load belt first and report your results.
Posted on May 30, 2009
  • 66 Answers
SOURCE: the drawer open & close function on my Yamaha DVR C300 isn't working.
could be that the rubber band is need of replacement, take it in to radioshack and they will get you the right piece, it should cost you a few dollars
Posted on Jun 28, 2009
SOURCE: LG RHT 398H. DVD tray not closing.
I've dismounted the unit and it seems that I have located the problem. The tray is connected to a wheel, so any displacement is translated into a rotation of this wheel. When the tray is near the close position, it releases a mechanism in order to position the lens. Summarising: if you have pushed the tray with your hand instead of pushing the button open/close, probably you have introduced a desynchonization. To solve this, when the tray is in close position, apply a small rotation to the wheel in order to compensate the desynchronization. There is not an exact position, but you need to try. A few degrees is enough. Regards
Posted on Mar 31, 2010
  • 1285 Answers
SOURCE: DVD Tray stuck open
the tray is not catching (underneath the tray is ridges). unplug the dvd player from the wall for 5-10 min...plug back up and give the tray a lite push while tapping the open/close button
Posted on Jul 17, 2010
SOURCE: Disc tray won't stay closed.
I fixed this by jerking the tray gently. Someone jammed my tray and it skipped a few gear teeth. It seemed like the machine couldn't pull it in far enough to reach its preset position. So I let it close and when it was almost closed, I gently jerked it out to skip the gear teeth back into alignment. It is kind of tricky because the motor will just reverse instead of skipping teeth (you'll hear the plastic clicking when it skips). Perhaps unplug it and slowly push it in manually then **** it back out softly. Just be gentle. Good luck.
Posted on Aug 22, 2010
I have 2 good qaulity heybrook speakers and have tried everything to connect them properly such that both play sound when the tv / dvd is on. Both speakers work perfectly one at a time and both work...
You're guessing. That is exactly the wrong thing to do. Get the manual.
"[D]vd 6 channel input" is for a 6-channel analog input as the name implies. I doubt you even have a source that HAS 6 analog channel outputs.
Speakers are OUTPUTS of the amplifers' speaker posts. Any one can work ANYwhere.
And that bi-wire capability, IF the speakers have it - pretend it isn't there.
Jul 31, 2011 | Kenwood VR-205 Receiver
I have had the Kenwood VR-407 since 2001. I also have a Mitsubishi projection TV, attached to the receiver. When watching regular cable TV (u-verse), I can not get sound from the rear speakers. I am using...
Most TV stations you watch don't send a surround sound mix so you won't get anything in the back speakers. DVDs generally all have a surround mix which is why it sends to all speakers. What you are experiencing is normal, Bob.
Jan 04, 2011 | Kenwood VR-407 Receiver
Reear speakers not putting out sound
If the TV sound source is through stereo RCA cables you'll only get rear sound if you choose one of the DSP modes. A digital source might work as expected, IF you have things correctly set up for multi-channel.
Dec 26, 2009 | Kenwood VR-405 Receiver
I have a VR 615 receiver. All 6 surround sound
It all depends on the processing the receiver is doing when recreating the sound. Change the surround mode to Dolby Digital or THX if it's on there. When it is receiving a Left/Right signal only, it does some processing but pretty much spits it out of all the speakers, fronts being the loudest. That's why you always hear them. When it is getting a Digital signal, the receiver does a much better job of processing the audio to the correct speaker, but unless there is a lot of background noise, there might not be any signal going to the speaker.
Also, check to make sure that the "size" of the speaker on the rear channels is set correctly. There is a setting on most receivers to tell the receiver how big the speaker is on that channel. This sets the power level on the output to accomodate the size of the speaker.
Oct 25, 2009 | Kenwood Audio Players & Recorders
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
TV has no picture but has sound
Did you say you went in to DVR set-up and checked the component out audio option? I have had similiar problems with motorola dvr boxes and once I was able to enable audio output option the dvr digital output was fine. Find the manual for the model dvd and this may cure.
Jan 31, 2009 | Denon Audio Players & Recorders
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
Jan 24, 2009 | Onkyo Audio Players & Recorders
Onkyo HTR500 no sound from the surround speakers or subwoofer
insted of running it thru the tv an to the reciver try doing it directly from the DVD player to the reciver just the audio jacks
Sep 08, 2008 | Onkyo HTR500 Receiver
Speakers not working
They will only have ambient sound (not same sounds as front speakers). Also for each input (video 1, video 2, dvd, tuner, etc...) you need to choose what surround mode you would like to use via the "Listen Mode" button. There is a little pictogram in the display which indicates which speakers are in use.
Sep 12, 2007 | Arcam AVR-200 Receiver
Kenwood DVR - 7000
Hi, same thing happened to my one of the above. I bought a cheap dvd player to view movies and run the audio through the kenwood to use the surround speakers.
Feb 21, 2007 | Kenwood DVR-505 DVD Player
Kenwood DVR-505 DVD Player Logo
325 people viewed this question
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
