Will not drain or spin
The washing machine stops when it gets to the drain cycle and the timer quits moving. Cannot get it to drain or spin. It fills and agitates okay.
The washing machine stops when it gets to the drain cycle and the timer quits moving. It fills and agitates okay. When I turn the timer forward a little bit then it would drain the water and spin. Please let me know if its the timer or the lid switch.
  • 1 more comment
  • ljc102376 Jan 05, 2008
    I think I jammed my washer..I washed too many things at one time. Now it will do the intital work but when it gets to the spin cycle it stops and flashes something (can't read it) on the screen. Do I need to call someone out to fix it!!???
  • Anonymous Mar 23, 2014
    Drum and agitator do not move after machine fills and cycle changes.
  • Anonymous Mar 31, 2014
    will spin and drain on delicate only if timer manually advanced lid switch clicks .Belt looks good. Pulleys turn agitator in both directions. No smells water levels correct. pulleys seem to move freely
  • 51 Answers
Unless you jarred the machine it's the timer. You can check this by bypassing the lid switch and seeing if it will cycle.
Posted on Dec 13, 2007
KenmorenLaunry center not draining or advancing cycles
Hi David if the timer is not cycling the tub will not drain ,the washer will not complete cycles, second check the lock switch on the door. this can stop the timer and the tub from draining. when not cycling the timer is at fault , this could be two problems, 1st when everything stops check the door safety switch , 2nd listen for the timer, if it stops running. good luck ,geodaws
Dec 09, 2013 | Kenmore Washing Machines
1.5 year old ge profile washing machine will not agitate or spin
Timer seems to have gone bad. Manually move the timer to make the dryer spin. If you get it to spin and drain then it's your timer.
Jul 01, 2009 | GE WDSR2080D Top Load Washer
WASHING MACHINE WORKS UP TO DRAIN/SPIN CYCLE AND STOPS
Hi, this is just a faulty timer control module. you will need to replace this failed control device asap. you can purchase it on line if you choose below by clicking on the link provided.
CLICK HERE
May 25, 2009 | Washing Machines
Kenmore will not agitate
The timer is the most common problem. Call any appliance parts store and tell them the model number and ask for price for new timer. Also call sears appliance parts and get price. But a new timer and install it.
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Washer won't advance from cycle to cycle
    * It's the timer, if your washing machine fills with water and begins agitating, but the timer never
    the timer.
    * It may be a cold-water supply problem, if the washing machine fills with water, agitates,
    Nov 16, 2008 | Danby DDW1805W Designer Series...
    Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
    Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
    May 23, 2008 | Kenmore Washing Machines
    Washing Machines Logo
    940 people viewed this question
    Top Washing Machines Experts
    Marvin
    Marvin
