Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
Clicking noises My Toyo laser 56 is making some wierd noises lately. It's almost like a clicking sound. Everything seems to be working fine, no error codes, and it is putting out heat. Should I be concered about the strange noise?
It sounds like your fuel pump is trying to draw more fuel than is available ...So you may need to clean the fuel strainer [should be done once every month of use and before storing ...as you don't want any gunk to harden on the strainer when there is no fuel to keep the strainer moist].
Posted on Jan 17, 2009
  • 625 Answers
Check to make sure the wires going to the main fan are not hitting the blades.
Posted on Dec 15, 2007
I have a toyo laser 56 stove. It is starting to make a moaning noise. what shoud i do?
Pilot,
You need to have a new mat put in the bottom of the burner. When this mat lifts, sometimes the flame will cause a moaning noise with a large yellow flame. A new mat and maybe a burner ring will fix ya.
Tom
Dec 16, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
We have a Toyo Laser , when it kicks on we get
Tubearz,
You need to look at the igniter guide gasket. That is the gray fiber gasket just behind the igniter flange. When you remove the igniter you may see a black rubber gasket that could be cracked or completely gone. You will need to replace it with the new style ( #17185580). While you are looking, look at the draft tube, where it goes into the fuel sump. If it is cracked it will need to be replaced.
Good luck,
Tom
My printer wont work. I checked everything that can possibly be wrong with it but i cant find the solution. When I click "print" the green light is on and it starts to make that noise it always does and...
this could be your LSU often the printer doesnt realise there is a problem untill it starts to print, try downloading smart panel for this model from the samsung website, smart panel will usually give a more accurate error than the 2 lights do
Nov 13, 2009 | Samsung ML-2510 Laser Printer
Toyo Laser 56 EE2 message--no flame? valves open and clean filter
You might of got type 2 fuel oil. If it is a smaller tank sometimes the fueler doesn't clear the line before filling and you'll slug down some type2 which will snuff the flame.
Check to see if the filler kinked a line outside while filling.
Just an Idea...
Oct 07, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Blue risk game wont work
There a two lasers in a PS2 one reads DVDs and white game discs and the other reads CDs and blue game disc. Sounds like your blue one is broken I'm afraid
Jun 30, 2009 | Sony PlayStation 2 (PS2) Console
TOYO LASER 56
Here is a link to the owner's manual... look it over to see what may have come unhooked. If you can't solve it you may be able to contact the business for this web site...
http://www.rural-energy.com/publications/catalog/document/270
Sep 03, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
EE2 code for toyo laser 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? If you let me know the sequence of events, I can trouble shoot the problem for you. toyotech
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
EE2 code for toyo 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? The firing process is the burner button blinks green for 7-9 minutes, then it clicks up to the medium, yellow light which starts flashing. That is when the fuel pump starts pumping. If you hear a fairly audible tic tic, or thump thump coming from the fuel pump then that is your indication that the fuel pump is starving for fuel. You either have a fuel line restriction, too little fuel, a clogged filter, a clogged sump screen, or rarely, a failing fuel pump. Usually, it is a fuel line restriction.
If you hear no tic tic or thump thump and it just goes off on EE2 then the problem is in the burn chamber. You may have a carbon chain in the chamber causing the flame sensor to temporarily short out. You can clean the flame sensor, fuel nozzle, and igniter to resolve this problem until you can get your Toyo tuned up.
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
504 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
