Question about Garmin iQue 3600 GPS Receiver
Garmin nuvi 660 personal travel asistant
My gramin nuvi 660, starts up as normal and after ..i touch agree and menu comes up and i touch menu screen it shuts down...then after trying process again it says pre boot mode and menu comes up then shuts down when screen touched..help please..
  • Anonymous Mar 26, 2014
    garmin shuts down and reboots at will frecuently
Do you know how can I do hard reset in Garmin 660
pelek82@o2.pl
Posted on Mar 12, 2008
  • 537 Answers
Are you running this unit while it is charging? Does the Nuvi 660 have a sufficient charge?
Try to do a hard reset on the unit.
Posted on Dec 13, 2007
  • alem962
    alem962 Aug 12, 2012
    Thanks!
    Scholar:
  • 40 Answers
In case it is a software problem try this and see if it will fix it....Try this and see if it fixes your problem...follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to try recover from the problem.
Posted on Jan 19, 2009
  • alem962
    Thanks! It worked.
Garmin 660 opens to where to/view map/travel kit/after that touch screen does nothing.good battery an ant signal.thanks
This is a well know issue with this unit and caused by a touchscreen failure. Please see this link for more info. Too much info to retype here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
May 27, 2011 | Garmin Nuvi 660 GPS Receiver
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I was in Florida traveling home to Wisconsin. My Garmin Nuvi 660 for some unknown reason said my home was someplace in Florida. Has anyone ever heard of the home location changing for no reason?
nope some one may have touch it in error, if you go to 2d screen and search area state ( -) button to zoom out to see bigger area , place arrow on you home area and zoom in and when arrow where you what togo save as favorite
Dec 27, 2009 | Garmin Nuvi 660 GPS Receiver
Not touch sensative
In 90% of the cases it's the digitizer (the touch sensor that is mounted in front of the screen). You can try to replace it yourself or send it to a third party gps repair service.
Jul 24, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 touch screen freezes up. Soft
I sat on the phone for 30 minutes waiting for Garmin support when my Nuvi suddenly had no touch screen response. They had me delete a file on the device (with it hooked to my computer) then reboot and it went thru a touch screen alignment and it worked.
Sadly, it has frozen again and I don't recall the file (it had been a GCD file in all caps, that is all I know and I don't see a file in all caps any more). I will be calling support tomorrow.
My take is that it *is* a firmware thing *and* there is some way to reset the firmware.
May 01, 2009 | Garmin Nuvi 660 GPS Receiver
My garmin nuvi 670 touch screen is not calibrated
Have you tried using the screen calibration command? Press the Wrench symbol, then the Display symbol and then Calibrate screen. Press the dots as it tells you to and you should now have a calibrated touchscreen.
- Jim
SHARCNET- USA
Dec 09, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660
Have you tried the Recalibrate Screen option in the tools menu? It may be in the "Display" option. I don't have a Nuvi in front of me to walk you through the steps but there is an option for it.
It will show you dots at various locations on the screen and you touch them. By doing so, it calibrates the screen.
- Jim
Sep 17, 2008 | Garmin Nuvi 660 GPS Receiver
Can't get a satelite signal
I am having the same problem. I think that Gramin is not tellimg us something. My signal will come a go, but never stay up for more them one minutes at a time.
Jan 12, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin iQue 3600 GPS Receiver Logo
433 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
