Question about Lands Phones
Vista-100 I need to know how to erase the old pre-programmed phone numbers in order to re-program new ones. I can't unlock the memory keys!
  • 2 more comments
  • slacker53 Dec 14, 2007
    How do I program phone numbers in the memory please
  • Al Longbrake Dec 28, 2007
    Want to add new numbers to old program
  • Anonymous Mar 08, 2009
    how to delete no longer needed phone numbers
  • Anonymous Mar 13, 2014
    Northern Electric
1/ Do not pick up the receiver
2/ slide open the option cover
3/ press the "Set Options" key
4/ press the "Hold" key
5/ press the "#" key (the key just below the number 9)
Posted on Nov 05, 2008
Bought a new key fob for a 2003 Chevy avalanche. After going through cycling the truck now won't start. I tried to turn over and dies.Is there anyway to clear the fob or what is going on?
Does it lock an unlock the doors ? How did you program the transmitter ? Like this ?
Important: Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
There are 3 methods for programming transmitters, which are listed below as methods 1-3. Up to 4 transmitters may be programmed to the passenger door module (PDM). Each programmed transmitter is given a position of #1-#4 in the PDM memory.
Method 1 - No Tools Required, Program All Transmitters
Important: All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter.
The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only; #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available.
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to 4 transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
Operate the transmitter functions in order to verify correct system operation.
Jan 10, 2018 | Cars & Trucks
How do you erase the memory on a renualt key
ok here we go...... inside the key there is numbers. keys with 5 or 7 characters can only be programmed using diagnostic equipment. keys with 8 characters as follows
ign off, press central door locking button for more than 5 seconds
NOTE: doors should lock then unlock. in other words pull the button up and down.
carry out the following within 10 - 15 seconds
press first key lock/unlock button twice (some models once)
press second key lock/unlock button twice (some models once)
hope i helped
Jan 07, 2012 | Cadillac DeVille Cars & Trucks
Hello i have a problem with my nokia 3110c whitch is : when i flash my phone with phoenix i got this result : Flashing started Creating product data items list Product data items list created Backup...
Now what is the condition of the phone ? If the phone has still problem, uninstall the previous file you have installed and re-install this one3110c file.Select the product code 0544311 or 0556977.This two files can use universal.Use fully charge battery or insert charger when message prompt.I hope there will be no error.Thanks good luck.
Aug 16, 2011 | Nokia N70 Cellular Phone
LOST THE ONLY KEY TO MY 2000 FORD EXPLORER. HOW CAN I GET A NEW ONE?
Go to dealer and bring your proof of id and paper work for vehicle. There maybe an additional programing fee, this is normal protocol. Or try a local locksmith but make sure you tell them over the phone your vehicle info.
May 17, 2011 | Ford Explorer Cars & Trucks
Do I need to reprogram all of the key fobs for my 05 chevy silverado 3500 or do I just need to program the new one? If so How is it done?
All key fabs need to be programmed at one time.
  1. Close all the vehicle doors.
  2. Insert the ignition key into the ignition lock cylinder.
  3. Press and hold the door unlock switch.
  4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
  5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
  6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
  7. Repeat the previous step to program up to 4 transmitters.
  8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
  9. Operate the transmitter functions in order to verify correct system operation.
Nov 25, 2010 | Chevrolet 3500 Cars & Trucks
How can I erase numbers from programmed memory buttons without entering new ones?
Press feature *1, then press the key you want to erase, and press the ok soft key without entering in any numbers. This will erase any speed dial or feature you have programmed under that button.
Oct 25, 2010 | NorStar Meridian M7310 Phone
I replaced the battery in the keyless remote and need to resynchronize keyless remote
Oct 12, 2010 | 2003 Chevrolet Tahoe
After many years have misplaced the instruction manual for our Vista 200. Need to know how to set up names and numbers for the automatic dialling feature. tdijimmy@hotmail.com
First, ensure the display is bright enough. If it is not, press successively on the "Brightness key" that is located on the top of the phone above the "Memory key". You have 8 brightness settings. Note that the "Brightness key" has no label.
You are now ready to start programming.
1. Press the "Memory key". It is labelled "Memory" and is located above the "Memory keys" numbered 1 to 10 on the right-hand side of the phone.
2. Press the "Memory key" you want to program. (1 to 10)
3. Enter the number you want to program using the "Dialling keys"
1, 2, 3,
4, 5, 6,
7, 8, 9,
*, 0, #
4. Once the phone number is entered, press the "Memory key" again.
5. Now enter the "Name" for the phone number you just entered. To do this, you press the "Dialling keys" as follows:
For A press the "2" key once,
For B press the "2" key 2 times,
For C press the "2" key 2 times,
For Q press the "7" key 2 times,
For Z press the "9" key 4 times.
Use the same for all letters.
To go to the next letter, press the "Right arrow key".
For a space, press the "Right arrow key".
6. Once the name is entered, press the "Memory key" one last time. You are done.
7. To test it, press the "Memory key" you just programmed.
Oct 19, 2009 | Bell BE-412CID Corded Phone
Programing remote contr ol
IMPORTANT: Before entering programming mode, have in possession all of the remotes you will be using on the vehicle. Once you program the remotes , all previous codes will be erased from the memory. The other remotes will not be functional until you program the remotes again.
1. Close the vehicle doors.
2. Insert key in ignition and turn to ON (As far as you can without cranking engine)
3. Turn ignition OFF and remove the key from the ignition.
4. Press and hold the driver side door lock switch in the UNLOCK position.
5. Insert the ignition key into the ignition lock cylinder and remove the key.
| (Do not turn the ignition key in the lock cylinder.)
6.
7.
Insert the ignition key into the ignition lock cylinder. (Do not turn the
ignition key in the lock cylinder.) Leave the ignition key in the ignition lock
cylinder.
8. Release the door lock switch. The vehicle will sound three beeps in order to
verify the Program Mode has been activated.
9. Press the LOCK and UNLOCK buttons together on the keyless entry
transmitter and hold until the vehicle beeps twice to verify that the
transmitter has been successfully programmed (this take approximately 15
seconds).
10. Perform the previous step to program up to four transmitters (including your
old ones).
11. Remove the ignition key in order to exit the Program Mode.
Jun 08, 2009 | 1999 Buick Regal
Door key pad, won't unlock door
  1. Enter the permanent factory remote keyless entry (RKE) keypad code.
  1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Jan 23, 2009 | 2005 Ford Freestyle
Lands Phones Logo
263 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
