Question about Syntax Olevia LT32HV 32 in. HD-Ready LCD Television
Olevia LCD & Dish Network DVR - black/white picture
I just bought an Olevia 232-S13 32" LCD TV. I hooked it up to my Dish Network DVR, model 522. When I watch live TV, everything is fine. When I pause TV and then resume watching or when I watch a recorded show, the picture is in black & white. I have called both Dish and Olevia Tech Support, but they have not been able to help. Is there a simple fix or should I try to get Olevia to replace the TV?
  • nightowls211 Mar 08, 2009
    I have a similar problem. I have a Samsung tube tv with a Dish 522 dvr. When I pause the color gets all funky or it goes to black and white. Also if I start to watch a recorded show it starts b&w before it eventually goes to color.
tremaine1
SOURCE: Olevia 32" LCD HD TV model 232-S13
my tv was working. when i changed the station it dark blue. the channel numbers shows up. is there a solution?
Posted on Apr 13, 2008
  • 979 Answers
SOURCE: olevia 232-s13 32"
Best bet is to go the wall-mount MFGR website and check out their instructions...accordianman
Posted on Jul 01, 2008
SOURCE: Need a Power supply for a LT26HVX Olevia LCD
Cheap parts were used in the construction of the olevia. I replaced 2 capacitors that were bad on the power board and the tv works fine now
Posted on Apr 20, 2009
  • 6 Answers
SOURCE: syntax olevia lt32hv 32 inch lcd tv. power surge now no picture
The electronics are known to go bad with these TV's, and I'm looking to buy someone's junk TV that has a good screen, rather than have to throw it out.
(So if anyone is out there with a 532-B12 that isn't working, send me a message!)
Yours might be worth fixing - however I know sadly that parts are nearly impossible to get for these TV's, and the manufacturer is virtually impossible to contact.
If you DO manage to contact anyone (manufacturer or otherwise) who can source or supply parts, PLEASE do let me know - it's been nearly impossible for me, and I want to replace my cracked screen in my TV.
If you can't, please let me know - I'll gladly give you a few bucks at least to salvage the screen from your TV, to transplant into mine, rather than turning it into junk on your curb.
Posted on May 17, 2009
  • 45 Answers
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Posted on Jul 28, 2009
I have Dish Network and remote #1 and 2...the TV for Remote #2 has now changed but the remote will not work...I replaced it with an Olevia Flat Screen (used one) 32in LCDHDTV Model 432-S12 but cannot...
If this hasn't been resolved, I do have some steps that will help you out. The link below will walk you through a power scan, which will program the remote to the tv. At that point, you will be able to change the channels on the tv with the remote.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
Jul 14, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
How to hook up a game console to an Olevia 232-T12
It all depends on your game console.
You can connect most to the Component, Composite, or HDMI inputs.
For modern consoles, use HDMI cables or provided Composite cables.
HDMI = Single cable and single plug (Best)
Component = Red, Green, Blue, Red, and White plugs (Average)
Composite = Yellow, Red, and White plugs (Worst, used for most older consoles and older TVs)
Nov 25, 2009 | Televison & Video
My pwoer supply blew up as well part number HGP 180-p240JIFE
Ladies and Gentlemen,
Relative to Olevia TV Power Supply Problems Solution provided by: kb8tez Matt, the problem he had was Electrolytic Capacitor CS21. Upon careful examination of the Power Supply Circuit Board I find that CS21 is in parallel with CS22. Simply replacing BOTH Capacitors makes for a more permanent fix. Radio Shack P/N 272-1032 1000UF 35V Capacitors @ $1.59 each plus tax makes a very inexpensive repair. Apparently the same power supply circuit board is common to many different Olevia Models.
Fastest Robe
Aug 25, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Need code for 32in.olivia tv
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, TiVo’s, DVD, Blu-Ray or even HD- DVD players. The learning remote is available at 866-965-3842
Dish Network Remote Codes 506 or 127
could try Dish Network..Remote Codes 506 or 127
Satellite TV Systems Dish Network Remote Codes 506 or 127
May 23, 2009 | Syntax Olevia 537H Television
Wavy lines and jogging TV picture
it could be any of the things you listed, the coaxial output on the dvr, where it says channels 3-4 out, the cable , or the coaxial input port on your tv. the dvd player is probably hooked up with rca cables (red white and yellow) so the reason you dont have the issue with it is because its on a different port, one solution would be to hook your receiver up to the tv using this kind of cable, this would also get you stereo sound, you would then watch dish network programming on a video input channel,
if you want to narrow the problem down, i would suggest hooking a vcr up with the cable thats connected to 3-4 out, play a tape and see if the issue continues, if not the issue is with the dvr, if so try a different coax cable, if this resolves the issue, the issue was the cable, if not unfortunately the issue is your tv
Feb 20, 2008 | DISH Network DVR-625 DTV Receiver /...
I have had the same problem with my daughters Olevia...232-S13 out of the blue ti just decides to not turn on...blue light lit where the on/off button located but no sound and no picture....i guess the saying "you get what you pay for" stands clear here.......very upsetting.....
Jan 12, 2008 | Olevia LT32HVE 32 in. LCD Television
Remote control codes
Juni,
You'll have to look it up by the remote you're using... Then by the brand of Tv you're trying to control.. try here..
http://www.remotecodelist.com/remotes/
Bill
Dec 27, 2007 | Olevia LT42HVi 42 in. LCD Television
Olevia 232 hd tv remote codes
this code dd not work with my remote for the olevia 232v..
maybe i will just buy a new remote for $29.00 and be done with it...; > (
Dec 07, 2007 | Olevia LT32HVM 32 in. LCD Television
The right code
Dish Network can be listed as Echostar as well.. There is a possibility that they don't cover Dish Network. What is the model number of the TV?
Dec 06, 2007 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
Open Questions:
Syntax Olevia LT32HV 32 in. HD-Ready LCD Television Logo
403 people viewed this question
Top Syntax Televison & Video Experts
Jaime Hernandez
Jose Pino
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
