Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Can't accept Quadra 500 on my owerMac G5 Quad
Took delivery today on Quadra 500.  Shipping carton was too large and box was loose all the way from California.  Connected via firewire 800 and it never mounted.  Was told this drive was formatted for Mac but it appears that it's not.  Called MacMall, and they said to try the firewire 400.  Same problem.  I have an older LaCie 200MB drive that's worked fine for 4 years.  After the failure of the 500, the 200 wouldn't mount either (fw 400).  Wouldn't mount on my G4 laptop either.  Neither could be seen by disk utility.  However, the 200MB drive did mount using USB2.  I have a return authorization from MacMall.  Should I scrap LaCie and go with Western Digital.  Also, How can I get my 200 to work with firewire again.  Firewire connection works with digital video, so it's not the Mac.
  • BobDerounian Dec 17, 2007
    Thank you for the attempt.  My inclination was to return the blasted thing and go with Western Digital, but I've had good luck with my old LaCie, and will use USB2 and Firewire 800 and do without the Firewire 400.  The 500 GB LaCie is very quite and works very well.  Also it comes with a 3-year factory warranty.  I hope I'm not making a mistake.  Ive read more BAD reviews on the LaCie than good ones, but take my chances.  Thanks again
  • BobDerounian Dec 20, 2007
    Again thank you.  I need a clarification on your 12/20 comment please.  Note, that both of my LaCie drives fail with FW 400.  Is it the port on the external drive or the port on the G5.  The FW 400 port works perfectly with other devices.
    Thank you for your consideration.
    Novelist:
    Champion:
  • 382 Answers
Scrap LAcie!! Sounds like in this case, it may have been jostled around during shipping. None the less, Lacie drives are nothing more than bricks waiting to fail. Go Western Digital, but if oyu can, zip straight for Seagates!!!! Professional grade!! ALways check the cables, the ones that come with them are bottom bin cables, made by little singapore children with no fingers..... Invest in a good cables...a drive is only as good as the weakest datalink.
Cash on the warranty!!!
Keep me posted.
Posted on Dec 16, 2007
  • Keith Seekwhensir
    Keith Seekwhensir Dec 20, 2007
    Understand, it's because the port is failing. I am an APPLE technician, and have had to recover more Lacies, than have been posted on this site. The ports will go one at a time, as they rest on the same pcb, and are very prone to wear and tear damage. When youre talking hard discs in the hundreds of GIGs, good luck isn't a realistic factor. My posting wasn't an attempt, it was spot on. But considering all the others that have rushed to answer this post........ so youve been warned.
    Keep your rating, no thanks.
  • Keith Seekwhensir
    Keith Seekwhensir Dec 21, 2007
    Port on the Lacie!! you should be abled to process of eliminate, by plugging another device in the fw port on the G5. Check this site even for complaints on Lacie drives as apposed to G5's. Also test the Dirt cheap fw cables that came with the drives. It's bottom dollar hardware. More money goes into designing the "slick" enclosures, than the actual inner workings of the drives. But again, you could be more fair in the rating, considering, and maybe you'll realize soon, that I am spot on. The fact the 2 of the exact same items from the same company is faulty, should lead you to your answer quickly.
Tip
For iPhone 7 4.7 LCD Assembly 3D Touch Screen Display
Product Description:
(LCD + TEMPTER GLASS) Free DHL High quality Retina LCD For Apple iphone 7 LCD Digitizer Assembly For iphone 7 frame replacement Black White Color
1). LCD for iphone 7 LCD Digitizer Assembly For iphone 7 LCD 4. 7 Inch Screen Replacement Black/ White Color
2). Components: LCD for iphone 7 4. 7 inch + Touch screen + Digitizer + Frame
3). Description: oem aaa no pixel no dead
4). Use: To replace faulty screen as display problems, touch problems, cracked LCD screens, wrong color issues, etc.
5). QC: Minimum 3 times tested with professional instruments or main boards before deliver to ensure 100% working perfect
Note: We recognize ONLY screen test result on Phone's Mainboard, other test results by test machines are not in our responsibility,
as now many faulty test machines have inaccurate test results. Pls make sure to test screen by your phone before installation.
6). Package: Well packed by carton box with EPE protective material surrounded to ensure safety in transportation
7). Shipping: Free Shipping by DHL Within 48 hours after payment confirmed
8). In full stock to ensure promp delivery.
9). Excellent after-sale service. IPhone 7 Plus LCD Screen Digitizer Assembly Frame Replacement Parts For...
on May 09, 2017 | Electronics - Others
I replaced the original burnt motherboard with gigabyte g31m-es2l an my sistem does not see the full capacity of the 2 HDD of 500 GB each.Instead reconizes only 129 GB of each HDD. CPU is quad 2.4...
you must update your bios so that it will accept the large capacity drives
otherwise, it only let you have about 60 % of the total, and the rest winds up going to waste because it's not getting used
Dec 16, 2010 | Gigabyte GA-G31M-ES2L Motherboard
Lacie Big Disk Quadra 3TB won't work with xp-32bit
One way around is to install Mac Drive on your system. First you format your hdd in HFS+ on a mac platform, with any size you want.Then, after you installed Mac drive on your PC, it will work.
Jul 01, 2009 | LaCie 3 TB Biggest Quadra External Quad...
Drive not showing up on my desktop
i'm not sure i can solve this problem--which started for me tonight as well with my lacie d2 quadra 500 gb--but i can share a possible explanation i've found online: apparently, they have lots of problems with their power supplies. see if the power adapter (the black brick) is making a hissing sound, or if there is a ticking sound coming from the drive itself. i have both these sounds. i am hoping all my data is safe and that my i.t dept. will be able to fix it with a new power supply on monday.
Sep 21, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Disassembly for shipping
As per page 4 of the User's Manual from Acer:
Detaching the Monitor
If you need to repackage the monitor, please separate the monitor and base, and restore them to
the carton. To detach the monitor:
1. Unplug the AC power cord to make sure the power is off.
2. Pull the 4 hooks on bottom side of the base and hold.
3. Separate the monitor and base and put them into carton.
Jun 19, 2008 | Acer AL1716B 17" LCD Monitor
Don't get it
I notice that you had issues initially installing the drive. Is it possible hat your actions as noted in the link corrupted the HFS+ formatting that was shipped on the drive?
Review this link
If as you noted THIS WAS THE FIRST TIME YOU USED THE DRIVE, you have no data on the drive to loose or recover.
Especially if you believe your actions may have corrupted the formatting of the drive, reformatting may be the appropriate response and could yield a working drive eliminating many return headaches. However if this does not seam reasonable contact with LaCie as to why the drive did not work directly out of the box may be appropriate. (I did confirm in the drive specs that the drive should have been formatted correctly for an apple computer -- windows users need to reformat the drive before they can use it )
I hope this helps
Dec 14, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
139 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
