Question about Sony Handycam DCR-TRV103 Digital Camcorder
Battery charging problem.
I have a Sony Handycam model # DCR-TRV103. It runs fine off the battery, but when I plug the charging cord into the camera, it shuts the camera down. It doesn't matter if it is plugged into the power outlet or not, and it does not charge the battery if it is left plugged in.
  • 3 more comments
  • fishdad Dec 16, 2007
    Everything is hooked up right. I just went out today and bought a new battery. It still won't charge. I'm going to get a volt meter to check and see if my charger is ok. What kind of voltage should I see?
    I went and bought a new battery today and the problem is still there. I won't charge or turn on. My next step think is to get a volt meter and check the charger. Do you know what the voltage is I should see when the charger is plugged in?
    Yes to all three.
    Is it possible the lithium battery could have something to do with it or is that just to keep the memory for the date/time display?
    Yes the power switch is off. I just got a hold of a volt meter. I just tested the charger and get 120 v ac before the charger but 0 v dc on the pins. It is not a round connector but sort of a rectangular connector with two pins side by side. Also I'm not sure if the charger gets warm when it's plugged in like the charger on my laptop, but this charger is cold. I'm starting to think that it is my problem. do you think there is somewhere I could take it to have it tested before I buy a new one because my new battery just cost me $50.00 and I don't want to throw anymore good money after bad..a Radio Shack perhaps? I'e got to try and get this figured out before Christmas. I appreciate the help you guy's have been giving me.
    Sergeant:
    Champion:
  • 298 Answers
Link to the manual
Read page 9 make
sure you have the
right battery and
that everything is
hooke up right
Posted on Dec 13, 2007
  • 4 more comments
  • Eugene Merritt Dec 13, 2007
    If you have the right battery
    and everything is hooked up
    what percent charge does it
    show read page 8 9 10 & 11
  • Eugene Merritt Dec 16, 2007
    shipped with a NP-F330
    charging rates in table below
    Any of thes numbers correspond to the battery pack you bought?
    Are you using the charger that came with the camera?
    Did you download the manual from the link above?
    The lithium battery is memory backup
    The power adapter should have a voltage
    rating and terminal polarity on the case
    showing + and --
    Is there a center pin in the dc input
    receptacle (possibly bent) or broken and or
    the adapter have a pin in the center
    instead of just an open barrel
    Maybe the dc input receptacle is defective
    bad solder joint broken or shorted connection
    ground
    Is the power switch in the center/ooff
    posiltion when you attempt to charge
  • Eugene Merritt Dec 17, 2007
    If your adapter has three prongs check for continuity
    between the ground and the 2 pins on the camcorder
    side of the adapter Its probably a rectifier diode and or
    voltage regulator in the adapter thats shorted
    The adapter is probably the problem if they have thet model
    at Radio Shack they might allow you to test an adapter on
    your camcorder to verify if its bad or maybe the store you
    purtchased it from will allow this if they can order it for you
    Heres a link you might check
    check the part # on the adapter
    see if it matches the number
    listed
  • 170 Answers
Hi, its clear that the battery is gone .
replace the battery with a new one its gonna work fine.
when you plug the charging chord into the camera,the camera shuts down because the battery is gone.the battery has lost the ability to charge,so to protect your handycam from any hazard the camera shuts off.
take care bye & have a nice day.
  • 2 more comments
  • bharath m
    bharath m Dec 14, 2007
    FOR CLARIFICATIONS CHECK THIS LINK
    http://www.docs.sony.com/release/DCRTRV1...
  • bharath m
    bharath m Dec 16, 2007
    when you plug in the voltmeter check the voltage drop across the battery while charging .it should be same as the voltage that is specified in the charger.
    using the multimeter check for the connections int he circuit(whether the circuit is open or closed).....
  • bharath m
    open circuit or faulty components also causues this problem
  • bharath m
    bharath m Dec 17, 2007
    using voltmeter check the voltage that you are getting at the terminals of the charger(terminal which you plug the pin into the handycam) .
    it should be the dc voltage as specified in the specifications of charger.
    if you are getting any ac voltage or 0voltage dc then the charger is not functioning properly.
    inside the charger there exists a component which converts ac into dc .that component is not functioning properly........
3 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Purchasing Sony Handycam DCR-TRV103 supplied accessories..
http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do
above web link might help u out.
Posted on Jun 08, 2008
  • 12 Answers
SOURCE: I Need a DV in/out connection cord for Sony
Try eBay: (as of 09/21/09) Item number: 370253287438
Posted on Sep 22, 2009
The camcorder has no power and will not turn on either with the battery or power cord.
The most likely culprit is the power cord. it is probably not supplying power therefore you have a camcorder with a dead battery. A simple volmeter. will test the output of the charger (should be DC 8.4V 1.5A). If it is not putting out the correct volts Then you van get one from Amazon for like ten bucks. http://www.amazon.com/HQRP-Replacement-compatible-DCR-TRV103-DSR-PD100A/dp/tech-data/B002OVMKE2
Feb 28, 2011 | Sony Handycam DCR-TRV103 Digital Camcorder
How do I charge my Sony Handycam DCR-HC30 if I do not have the power cord? Thanks.
You can buy battery charger for your handycam.And charge it with power supply plugs.
or
Buy a data cable for your particular camera and connect the camera with computer to charge it
Sep 17, 2010 | Sony Handycam DCR-HC30 Mini DV Digital...
My sony digital handycam flashes C:31:42
C:31:42 indicates that you having a problem with capstan motor. It has to be replaced.
Nov 05, 2009 | Sony Handycam DCR-TRV103 Digital Camcorder
Have a sony DCR-TRV103..trying to upload video to my laptop using a USB cable...but the laptop does not recognize the camera..and I can't find any drivers? Any ideas?
You can't do this with USB. You need special cord - 1394 IEEE adapter on one end, and a DV adapter on the other (camera)end. This fits into slot on front of camera under and to the left of the microphone.
Jan 13, 2009 | Sony Handycam DCR-TRV103 Digital Camcorder
Connecting to Computer
Look at the camera as though you were peering into the lens. On the front face of the camera in the lower left hand corner, there is a rubber plug labeled DV In/Out. Under that plug is an IEEE-1394 port (firewire). You will need to purchase a firewire cable and have a computer with the same port (some are four pin and others are six pin...I believe the four pin is more common, but the cable will need to match). When you plug the camera to the computer, it should be detected automatically similar to a USB device. You will also need to have the software for capturing and editing the video. My HP laptop came with a fairly decent program called Cyberlink Powerdirector. You can check out the videos I've done on youtube with my DCR-TRV103 at www.youtube.com/user/stu11926.
Jonathan
Mar 24, 2008 | Sony Handycam DCR-TRV103 Digital Camcorder
Sony Handycam DCR-TRV103 Digital Camcorder Logo
377 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
