First off all you should remove the battery pack and the adapter before starting
I have replced it is very simple
before doing set the and move the lcd as required 90" or 180"dig to remove
Just open the plastic panel which is beside the switch, and then un screw the keyboard screws and remove the strip wire slowly by ulocking it,
Hi, I have a 3yr old Dell e1405 Laptop, which I have teared it apart to clean the fan as it is so...
(More)
Hi, I have a 3yr old Dell e1405 Laptop, which I have teared it apart to clean the fan as it is so dirty and hardly runs. Unfortunately I broke the pin on the motherboard that connects the touchpad. Since then my laptop has problem turning on, and sometimes I have to press the power button so hard to start the laptop. So, I went ahead and bought a motherboard on ebay and replace mine with new one. After installing the new motherboard, my system doesn't turn on when power button is pressed. I took off the CMOS battery and battery fro the laptop and plugged it directly to the power cable, all of the sudden system turns on without pressing the powerbutton. If I put the CMOS battery laptop won't turn on. Does anyone experienced this problem. Please help..!
CPU: Intel core duo T5300 2.0ghz RAM: 2gig PC2-4200 ram (Hynix is the brand i think?) VID: ATI X1400...
(More)
CPU: Intel core duo T5300 2.0ghz RAM: 2gig PC2-4200 ram (Hynix is the brand i think?) VID: ATI X1400 256mb HDD: 80gb 5400rpm hd OS: Windows Media Center w/ SP3 and latest updates LCD: 15.4" WSVGA+ The problem is the image on the screen will just disappear.The monitor semms to just turn off but I can still hear the fan and hardrive on. I still see green lights on the laptop. Playing a game or surfing the internet, it doesnt matter, you hear like a click noise the screen goes blank. At first I though it may have been in sleep mode so I turnd everthing to never in batery saving mode. The problem still occurs. I have swithced usb mouses and dell batteries and also ac adapter. The sgut down still occurs. Interestingly I can correct the problem shuting the laptop down hard and removing the battery for a few seconds. After putting the battery back the laptop starts up fine I'm thinking it may be an inverter issue but I am not a technician. Thanks for any help on this
I have a compaq presario 1200 laptop and I have a blue screen problem. Whenever I run anything...
(More)
I have a compaq presario 1200 laptop and I have a blue screen problem. Whenever I run anything memory intensive it simply flashes a blue screen at me then reboots. Whats more is after it reboots it won't get past a certain point in the loading bar underneath the windows 2000 logo and thus won't boot until I have manually turned it off and then on again.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
