Ice maker works fine, but dispenser on door does not work. It's as if ice is stuck inside, but I've emptied the ice from the storage caddie and allowed it to dry overnight and it still doesn't work.
I have a True Freezer (model #TR1F-1S) that suddenly started flashing a fault code of P1 where the...
(More)
I have a True Freezer (model #TR1F-1S) that suddenly started flashing a fault code of P1 where the temperature readout usually is. Does anyone know what this fault code means on this particular unit? Thank you!
The ice cubes appear to be stuck in the ice maker. There is a frequent clicking noise as if the turn...
(More)
The ice cubes appear to be stuck in the ice maker. There is a frequent clicking noise as if the turn mechanism cannot free the ice cubes.
I can get some ice from the dispenser but then it will quit. I have read the instructions in the...
(More)
I can get some ice from the dispenser but then it will quit. I have read the instructions in the instructions that came with the refrigerator but it did not help. I was told to pull it away from the wall and clean out the water hose and the filter and several other things to see if it would work. Can you tell me what might be the problem. It will make crushed ice. Thanks Peg
