Video Cameras Logo
j
juan leyva Posted on Oct 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to red the record ving card lock - The Video Cameras
Tony Parsons
Level 3:
  • The Master 6,405 Answers
  • Posted on Oct 18, 2019
Tony Parsons
The Master
Level 3:
Answers
6405
Questions
Helped
1651819
Points
20272
How long has this been happening ?
Have you consulted a medical professional ?
2answers
Ving card lock question: door is locked, program room key to unlock door. Doesn't work, light is RED. Master key/staff key works, Light GREEN. Why does the master key open door while room key doesn't?
www.elock2u.net/wp-content/uploads/2016/04/Hotel-Lock-System-Manual.pdf
If lock latch part is engaged, You can unlock it by using emergency key in ... Cards are programmed to function cards ... *1 When Hotel lock system is finished with all room settings, issue Setting cards ..... The most important card in system, the Master card can access all .... Then the lock will not work for its current Guest card.
1helpful
Locked and no software disc
Remove the SD card from the recorder and check if the write protection switch is in the locked position. Move it to the unlocked position and carefully replace it without toggling the switch. The switch is on the side of the card nearest the contacts but on the side without the angled notch.
Sometimes the lock switch can become damaged, the best thing to do in that case is to buy a new card. Since there is no data on the card, the time to make a temporary fix isn't worthwhile.
I hope this helps.
Insignia NS-DCC5SR09 camcorder card Locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
I have JVC Hard Disk Camcorder GZ-MG145AA, my problem is everytime to record it the counter of recording is Red flash..means cannot record to my SD Card any Brand or to hard disk is say hdd Failure no...
you should check out your sd card whether it has virus or not or you may try to format you card.I think it may help you.... if not let me know i'll give you other solutions.
7helpful
3answers
My GL2 only works when I turn it on to playback mode. When I try to turn the camera on in camera mode, it doesn't work. What could the problem be?
There is a simple solution to that... You see under the 'card-tape' switch? There's the red button for recording... attached to that button the is a switch that says 'tandby or lock'.... if you have it in 'lock' it will not let you go to record mode, you have to change it back to 'standby' and that should solve your problem.... Anymore question just e-mail me at [email protected] and I was wondering if you had a copy of the installation CD I can buy or have.... or maybe you could tell me where to get it? Thanks.
18helpful
Lock/read only card message
Make sure all the files from the memory card have been downloaded and saved to the computer. You are going to need to format the memory card to remove the write protect/read only/lock issue. By formatting this will permanently erase all data from the memory card so you are able to use it again.
To format the card: go to Menu - to Submenu - to Format option - Start - then Start again - Press Menu to initiate the process - When done the recorder will be able to be used for recording purposes again.
Locked on card protect
pp.5-6 of your manual has the information on locking/unlocking
Hand held electronics
If the card was edited via a computer the xD card becomes locked for protection purposes. Put the card in the recorder and format the recorder the lock will be gone. The device will show up as a removeable disk but gets moody if the memory is altered in any way by the computer.
Top The Video Cameras Experts
ZJ Limited
ZJ Limited
Are you a The Video Camera Expert? Answer questions, earn points and help others
