Question about Apple Power Mac G5 Desktop
Firewire ports malfunction
I cannot access any of my firewire ports on my power mac g5 funning 10.4.11.
  • FreedomMusic Dec 08, 2008
    My G5 suddenly stopped recognising any firewire devices. I checked external drive on a lap top and all is good. G5 did not respond to SMU reset as per Apple site instructions..........anybody got an answer
    G5: Tiger 10.4.11: G Drive 250 Gig ext Drive : Presonus Firestudio:
    Problem Solver:
  • 6 Answers
Boot the machine from external hard drive with known good OS installed.
If issue persists then, then logic board has issue.
Posted on Dec 14, 2007
My G5 tower is no longer recognising my external iSight camera. The only thing that happened was that I switched the G5 off and on again, it was working fine previously. Can you help? Many thanks
Best thing you can do is to determine whether its the port or the camera.
If you go to the Apple in the upper-left corner, and go to "About this Mac", then click "More information", it will start System Profiler. On the left side, under "Hardware", click on "Firewire" and see if your iSight shows up. If you have another FireWire device, plug it in, and see if it shows up there as well. The solution could just be a dead iSight (hopefully!). The worst case scenario is a dead FireWire bus...
If you have a dead iSight, I'd guess that ebay would be your best resource at this point. If its a dead bus, I'm afraid it won't be terribly cost effective to fix it :-/
Jan 06, 2011 | Apple iMac G5 Desktop
I purchased a JVC BR-DV600U DV deck to use with my Mac computer for video editing. When I plugged the Firewire cord from the deck into the computer, problems began to happen. Two of my three external...
There exist a number of methods for dealing with FireWire device interference, a few of which are explored here. Switching Ports The first procedure you should try when experiencing a problem that you believe to be caused by device interference is to simply reconfigure the arrangement in which your FireWire peripherals are connected. Try switching each device to a different port, or temporarily disconnecting one or more of the devices. In particular, if you are a PowerMac G5 owner, trying switching devices from the front to back ports or vice versa. Adding an external hub In some cases, it appears that FireWire devices are not drawing enough power from the computer. This can cause a sundry of strange issues, including apparent conflicts between devices and unexpected power-offs during device operation. In these instances, adding an externally powered FireWire hub can clear things up. One of the reasons an "under-powered" situation can occur is that different Mac models have varying power capacities available through their FireWire ports. PowerBooks and iBooks have the least, generating around 7 watts. The iMac G5 also generates a relatively low amount of FireWire power, sharing 8 watts between its two FireWire 400 ports. The Power Mac G5 shares 15 watts between its one FireWire 800 port and two FireWire 400 ports. Place devices on different FireWire busses/Isolate the iSight Similar to the above procedure, adding another FireWire bridge -- via an extra PCI-based FireWire adapter or another means -- can eliminate conflicts from devices that reside on the same bridge. Power cycling the system Simply cycling the power on your system may be enough to temporarily eliminate a few FireWire conflict issues. Shut down your Mac, and disconnect all FireWire devices as well as the computer's power cord. Leave the system off for about 10 minutes, then plug it back in. First turn your Mac back on, then re-attach the FireWire devices one at a time and check for the conflict to resurface. Disconnect specific FireWire devices (especially iSight) to check for conflicts As noted above, the most common cause of interference is Apple's own iSight. In case after case, simply disconnecting this single device has eliminated problems with other FireWire devices. Other devices often implicated in FireWire conflicts include video-related devices; cameras, the EyeTV, video decks, etc.
Disconnecting the iSight has proved particularly successful for an issue where the iPod disappears from the Desktop and from the iTunes playlist, while the iPod status screen cycles from the Apple logo to a "Do not Disconnect" message over and over. The exact reasons why the iSight causes more than its fair share conflicts with other FireWire devices are many, and sometimes unclear. One potential source of conflict, however, could be the unit's high bandwidth usage. The iSight captures video at a 640 x 480 pixel resolution, at 30 frames per second in millions of colors. Such throughput uses a significant chunk of the standard FireWire port's 400 Mbps bandwidth. As such, when other devices are connected, the bandwidth requirements for satisfactory performance may not be met. Try disconnecting all FireWire devices, then adding them back one by one and repeating the originally failed operation to check for conflicts. Apply the latest updates Make sure that your FireWire drives are using the latest firmware (check the manufacturers' Web site) and the most recent iPod update has also been applied. Of higher importance, if you have an iSight, is the iSight 1.0.2 updater. In a large number of cases it has resolved conflicts caused by the camera. Re-apply the most recent Mac OS X combo updater In some cases, re-applying the most recent combo updater can resurrect seemingly defunct FireWire ports and allow devices -- drives included -- to be recognized again. The most recent combo updater is available from Apple's download page. Clear caches Try using a tool like Tiger Cache Cleaner or Cocktail to remove potentially corrupt system caches. Restart, then check if your FireWire devices are recognized.
Feb 05, 2010 | JVC BR-DV600U Mini DV VCR
Apple mac G5 freezes when booting up.
Try unplugging all Firewire/USB devices. Also, unplug the power cord from the computer. This resets the logic board. If that doesn't isolate the problem, put your Original system CD that came with the computer and hold down the C key. Boot up and run Disk Utility. Run the repair disk and then repair disk permissions. Reboot and try booting your system again.
Jan 03, 2010 | Apple PowerMac G5 Dual Mac Desktop
My Apple G5 and WD Passport 500Gb don't mount
You need to determine whether the problem is at the disk interface or at the computer interface. Will the drive mount on ANOTHER machine using FireWire? Will your computer mount ANOTHER device using FireWire? This will tell you which machine is at fault. It's not unheard of for the FireWire channels in a Mac to just go bad, and (unless it is a Mac Pro) it typically requires a logic board replacement to address. For a G5, this would not be cost-effective. On the other hand, as I say, it could just be a bad interface in the drive itself. It's up to you to determine which it is.
Sep 20, 2009 | Apple iMac G5 Desktop
G5 dual processor keyboard freezes for 10 seconds or so
you might need to check the usb connections for the keyboard and mouse. and see if they are correctly connected, also to clean the connections with a q-tip from time to time. Also you might want to switch to another usb port. to narrow down the issue. Because if say you change to another port and it still persists, even when running a usb hub with external power, and even a external firewire hub with usb connection then the issue would be the com board for the usb and firewire. and hopefully the G5's usb, firewire ports are on a separate board that is then ribbon wired to the main board. because if its just ports ribboned to the main board you will need to get a new logic board. and that is not cheap. unless you still have your applecare. then just take it in to get replaced.
Jul 02, 2009 | Apple 24" iMac Desktop
External sound problems on Power Mac G5
Mac g5 sound output is echoing? what is the reason
Dec 02, 2008 | Apple Power Mac G5 Desktop
002 digidesign console
i think you blown your fire wire port,try something else in those ports and see if they work..
Feb 26, 2008 | Apple Power Mac G5 Desktop
YOur camcorder will have to have a 1394, firewire or ilink port. they are all the same thing ( firewire ) , bur sony calls it ilink so they dont have to pay apples licensing fees. If not, you will need a sony8 video tape deck with firewire out.
Any other questions?..keep me posted.
Dec 26, 2007 | Apple iMac G5 MA064LL/A Desktop
DSR-11 not recognized by FCP
Hello tommy_bee, Try the advice offered on this link. It has helped me
Aug 15, 2007 | Sony DSR-11 DV / Mini DV VCR
Apple Power Mac G5 Desktop Logo
215 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
