Question about Craftsman 17026 Wet/Dry Vacuum
Power I bought my Vac about a year ago for a home project, used it about an hour total, and when i went to use it today, it started to turn on, and then shut off.  I thought i tripped a breaker, but that was not the problem.  Very confused. George
  • moose2000 Dec 30, 2008
    How do i test the motor on my shop vac to see if i burned it out?
  • 883 Answers
I had a similar problem with a Shop Vac. The solution was to disassemble the power switch and polish the metal electrical contacts to remove any oxidation caused from humidity. Tedious and time consuming but effective.
Posted on Dec 13, 2007
  • Marty marty Dec 13, 2007
    ...while you are at it, first try to "bump" the motor with a second power cord temporarily wired to it to make sure your motor is still ok.
Shop vac doesn't work. Does my shop vac have a thermo fuse?
Contact the manufacturer of device. They may help you. If not, make sure that current is reaching the on/off switch and that the power is reaching the motor - if power gets to motor and still nada then the issue is probably with the brushes not making proper contact with the commutator.
Dec 23, 2016 | Shop Vac Vacuums
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
I have a hoover steam vac F5915-900 I bought at walmart about 4 months ago. I used it about 5 times in differnet rooms. Today when I went to use it It won;t pick up the dirty water. I cleaned the filter...
Make sure the suction area of the face plate is clear of all debris. If anything else, call the number on the machine, it's still under warrantee if the machine doesn't work from normal use.
Sep 05, 2011 | Hoover Vacuums
I just bought a Salton Ice maker 3 weeks ago and went to make ice today waited 2 hours no ice??
hi sheles.... it takes about 24 hours after you plug the icemaker in to get the first batch of ice. Joe
Jun 12, 2011 | Vacuums
Eureka central vac 's power stopped won't start again.
I took to dealer I bought from . He examined it. The motor is gone needs new one. Thanks, Ann
Jan 24, 2009 | Eureka 1810 Central System Vacuum
Central Vac does not shut off
Sounds like the relay that is in the central vac unit is stuck to the ON position. When you plug it back in..does it start right up ? If so.. You should be able to disconnect all the receptacle feeds to the central vac unit at the central vac unit to determine which one ( if any) is calling for the vac to stay on.. if none are.. then it is internal to the vac and may be a stuck relay... Hope that gives you some ideas to check...
Aug 28, 2008 | Vacuums
Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
Generic problem for all Vacuums
Posted by buster_lls on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
After i cleaned the filter, shop vac doesn't turn back on
May 04, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vacuum problem
I bought a dirtdevil 8 years ago and it's still going. As long as the motor works then you have check to see if the brushroller turns. If not then check the roller belt (take the cover apart some have screws or lock tabs on bottom panel near wheels) If the suction is low then check the vac bag, also with bag off, turn on the vac to check if air comes thru.If not the inside tube is clogged(plastic bags, small objects, ect.)Also when you open the bottom panel to check the roller belt, check the flex pipe that sucks up to the vac bag(unclogg it).
Apr 02, 2007 | Dirt Devil M085805 Upright Vacuum
Craftsman 17026 Wet/Dry Vacuum Logo
293 people viewed this question
Top Craftsman Vacuums Experts
Tim Doolittle
Tim Doolittle
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
