Question about Honeywell HZ519 Baseboard Heater
Powers on, no heat
My heater powers on normally (the lamp in the same outlet even flickers slightly), but no heat. All the indicators in the display appear normal. Sometimes, you can feel the slightest bit of warmth, but that's it. It's only 2 years old--it worked OK for a few weeks this year--then nothing.
Yes--it's plugged in
Yes--it's clean
Yes--it's upright
HELP!! It's getting cold!!
  • 2 more comments
  • Keith Methot
    Keith Methot Dec 30, 2007
    Same deal... I do have a fluke meter...
  • oledog Feb 22, 2008
    The power is on, the thermostat works, timers, and it looks like it works but doesn' t produce any heat. Hoping there is a reset switch but couldn't find one.
  • Anonymous Oct 04, 2008
    Unit powers up, all functions appear to work properly, but the unit produces no heat at all.  Worked last winter just fine . . .
  • Anonymous Oct 31, 2008
    The Honeywell HZ519 is a piece of junk. I have two, and both have failed. One one, nothing powers up (no lights, no power on, etc.). On the other, it indicates that it is on, but no heat is produced. Honeywell is making junk.
    Problem Solver:
  • 3 Answers
I have this model heater and it quit working as well. I took it apart to find that the plastic bosses that the safety switch mounts/screws to melted and the switch fell into the bottom of the heater rendering the heater useless.
FYI, The safety switch removes power from the heater when the heater is laying on it's front or back incase it gets knocked over while it is on.
This is a serious defect. These heaters should be recalled.
Posted on Jun 28, 2010
    Sergeant:
  • 288 Answers
I can help you only if you have a volt/ohm meter. let me know.
Posted on Dec 29, 2007
  • Rob Luna
    Rob Luna Dec 30, 2007
    Get the fluke meter and set it to AC volts. I am assuming this is 110v, and you plug it into the wall, and you checked the plug already. Put one lead from the meter to the on/off switch and the other to a good ground terminal. You should have power on both sides of the switch when its on. Next go to the thermostat and do the same thing. If the thermostat or switch does not give a reading, unplug the power, by-pass the thermostat by connecting the wires to each other, return the power on and see what happens. If it heats up, its new thermostat or switch time. If not, then unplug again, set the meter to ohms. Touch the leads together to check it, different meters have different settings but try to find the one that makes a sound when they are touched together. Find the heating element, remove the wires, touch each lead to each of the ends. if the meter is reading open, then its the element. There also is a thermal safety disc, do the same thing as element. While checking these things, look for burnt wires everywhere. I hope I explained this good enough for you to understand.
I have a toshiba Satellite a135-s2386. It powers on but nothing on the display. I think I need a new motherboard. But am not for sure. What is the part number for this motherboard. any help will be...
Does the laptop appear to boot up but the screen id blank?
Does the hard disk LED light flash?
If so you may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Dec 09, 2009 | Toshiba Satellite A135-S2386 Notebook
Laptop powers up but no video
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
www.ladparts.net
Dec 08, 2009 | HP Pavilion dv5000t Notebook
Unite powers up, but screen stays dark. Unite is 11 months old, and used daily.
www.ladparts.net
Dec 08, 2009 | Acer Aspire 5610 Notebook
Flickering screen
www.ladparts.net
Dec 05, 2009 | Acer 4220-2346 Notebook
My ibm a21m turns on with the little light as well but nothing happens the screen is blank the hard drive powers up still nothing need help please
www.ladparts.net
Nov 30, 2009 | IBM ThinkPad A21m 2628 Notebook
NC2400 screen flicker
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 29, 2009 | HP Pavilion zd8000 Notebook
Screen flickering when turning on laptop and sometimes the laptop turns on after flickering and sometimes doesn't turn on at all after flickering. Just stays black.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 01, 2009 | Acer Ferrari 5005WLMi (LXFR506119) PC...
I have a Satellite 1805-204. I powers up and the screen will intermittently stay on. If I tap the sleep button the screen will display for a few second then go black. sometimes it will stay on for long...
This could be a faulty video cable or connector or CCFL lamp or inverter.
Try reseating the video cable/connector that connects to the motherboard first.
If this doesn't work then to determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 15, 2009 | Toshiba Satellite 1805-S204 Notebook
Dell inspiron... turn on and screen will not display anything, but slightly illuminates... plugged into desktop screen, running safe mode, computer will run, but cannot boot up normal on desktop screen and...
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 11, 2009 | Dell Inspiron 6000 Notebook
Convection Heater Light on Knob HBH 5015
It is normal for small orange neon indicator lamps to blink or flicker when they're about to burn out. This should not be a problem unless you notice other electrical problems such as sparks or smoke.
Any easy test for electrical problems in your heater is to turn on an AM radio in the same room with the heater...and tune it to a clear station that you can hear clearly. If you hear steady crackling sounds or static in the radio while the heater is on, then the heater should be inspected for electrical problems.
Jan 22, 2008 | Heating & Cooling
Honeywell HZ519 Baseboard Heater Logo
855 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
