Question about Sony PlayStation 2 Slimline Console
Ps2 switch my ps2 switch fell off inside its not attached anmore wat should i do
    Sergeant:
    Champion:
  • 317 Answers
If you can reach and power on the PS2 with your finger, go for it; if you are brave enough, open the console, and shake it until the switch comes out, then glue it back in a way it's still functional.
Posted on Dec 13, 2007
I need help on removing door panel on 2000 Dodge Caravan - window fell in dorr and I can not seem to get the panel off. Any suggestions?
Answer
FRONT DOOR TRIM PANEL
REMOVAL
Using a trim stick (available from parts stores), pry courtesy lamp from door trim.
Disconnect wire connector from courtesy lamp.
If equipped, remove screws attaching door assist handle to inner door panel.
If equipped, remove screw attaching door pull cup to inner door panel.
If equipped, remove screws attaching trim panel to door from below map pocket.
If equipped, remove window crank.
Using a trim stick, remove screw cover from switch panel.
Remove screws attaching switch panel to door trim.
Remove power accessary switch from door trim Front Door Switch Panel
Disconnect power switch from wire connector.
If equipped, using a small, flat bladed pry tool, remove memory seat/mirror switch and disconnect wire connector Memory Seat/Mirror Switch
If equipped, remove screw holding door trim to door panel from behind inside latch release handle.
Disengage clips attaching door trim to door frame around perimeter of panel Front Door Trim Panel
Lift trim panel upward to disengage flange from inner belt molding at top of door.
Tilt top of trim panel away from door to gain access to latch linkage.
Disengage clip attaching linkage rod to inside latch release handle Inside Door Handle Linkage
Separate linkage rod from latch handle.
Remove front door trim panel from vehicle.
INSTALLATION
Hold top of trim panel away from door to gain access to latch linkage.
Place linkage rod in position on latch handle.
Engage clip to hold linkage rod to inside latch release handle.
Place front door trim panel in position on door.
Install trim panel into inner belt molding at top of door.
Install clips to attach door trim to door frame around perimeter of panel.
If equipped, install screw to attach door trim to door panel behind inside latch release handle.
If equipped, connect power switch into wire connector.
Place power accessary switch in position on door trim.
Connect wire connector into memory seat/mirror switch and install switch into trim panel.
Install screws to attach accessary switch panel to door trim.
Install screw cover into switch panel.
If equipped, install window crank.
If equipped, install screws to attach trim panel to door inside map pocket.
If equipped, install screw to attach door pull cup to inner door panel.
If equipped, install screws to attach door assist handle to inner door panel.
Connect wire connector into courtesy lamp.
Install lamp in door trim.
Feb 02, 2012 | 2000 Dodge Caravan
I got a ps2 and it plays some games and it doesnt others...the disks are not scratched or anything it just doesnt play them... like when I put the disk the playstation logo comes up like its about to play...
This happens to me , Some games don't work on Some PS2 consoles for Example my friends Theme park world only works on a Slim PS2 and not a Proper Fat one , Wat type of PS2 do u have? and wat game r u trying to play?
May 21, 2011 | Sony PlayStation 2 (PS2) Console
Ps2 power light stays red
hello eric i've repaired a few ps2 most of the time it's been down to the power switch if not the power switch then the ribbon cable attach to the switch
regards
shaun
Feb 25, 2010 | Sony PlayStation 2 Slimline Console
The console fell off the draw and just reads disc error
it may have damaged your laser. but if you feel like opening it up, turn ps2 upside down and take the screws out(9 or 10). turn ps2 right side up, take the cover off. be exrta carefull with the reset ribbon(leave it attached) to your right(facing like you were installing a disc) is the disc unit( you will need a small phillips head screw driver) take the cover off of that( 4 screws) gently push laser head away from you toward the center. before you put your covers back on see if you have any ribbons that may be loose or completly detatched, put the cover back on laser unit and try it ( before you put the main cover back on. good luck, hope this helps
Jan 20, 2010 | Sony PlayStation 2 (PS2) Console
PS2 Metal square loose inside?
its nothing it goes on the inside on the left side its just there so you can buy a stand to stand your ps2 up
Jun 22, 2009 | Sony PlayStation 2 Slimline Console
Inland ps2 kvm switch
The control for Inland KVMs is ScrLk + ScrLk + #. Example: ScrLk + ScrLk + 1 gives you the first attached computer, ScrLk + ScrLk + 2 gives you the second.
Apr 10, 2009 | Inland 08216 2-port KVM Switch
My PS2 fell on the floor!
Use to have this problem alot, there is a track on the under side of the tray a little plastic pin follows, it has jumped the track, do not force it closed or you could break the track, hopefully it isnt broken already. Have you ever opened a ps2 before?
Dec 12, 2008 | Sony PlayStation 2 (PS2) Console
Getting ps2 micro switches realigned
micro switches is wat turns on and off the PlayStation2 and they make the Cd tray come out and resets the ps2 the buttons are the green button on the front of the ps2 to restart and turn on the ps2
and the blue button is at the bottom of the green one the blue button makes the Cd tray come out and the last micro button it at back of the ps2 its a black button that turns off and on the ps2
your rating is highly appreciated
Jun 23, 2008 | Sony PlayStation 2 Slimline Console
Mp3 player fell in water
my zen stone player fell into water. it was off at that time, but i didnt switch it on. i try to dry using a drier & after 2 days, when i felt it was completely dry, i switched it on.. but the buttons are acting crazy & its not recharging. wat should i do ? please help me.
Apr 16, 2008 | Creative Labs Zen Stone Plus MP3 Player
Sony PlayStation 2 Slimline Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
