Question about Daewoo KOR-1B4H Microwave Oven
Common part I need the foil like film that covers the microwave guns outlets. Where to buy and the part #
  • Daewoo Master
  • 9,098 Answers
Model KOR-1B4H doesn't show up on their parts page, so I would contact them directly with your full model number.
The part you need is called the wave guide cover.
See http://www.mcappliance.com/contactus/contactus.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 04, 2008
Replacement mica cover for sanyo d95535n microwave
Hi there micro
There are things that the microwave does not like. One of them is aluminium or metal for that matter.
You can buy plastic hoods or just cover the plate with plastic film not forgetting to pierce the film in several places in order to let the steam escape.
all the best
Kolbrun
Apr 09, 2012 | Sanyo Microwave Ovens
The paint came off because my grandaughter put aluminum foil in it. How can I repair the paint?
I would like to make a warning ,do not try to repair microwaves , they are lethal weapons , I know someone who ran one with the cover removed and cooked his kidneys , if it is faulty dispose and get new, if aluminium foil was put inside it has heated up and as you say damaged paint ,the seal could also be damaged and lethal , dispose and buy another .
Mar 22, 2012 | Kenmore 63252 Microwave Oven
My microwave keypad doest not work apparently. It says "service may needed". How can solve this error.
HELLO.
The solution to your microwave problem is explained below.
Things You will Need
* Phillips screwdriver
* Foil
* Large ziplock baggie
* Tape
* 1 Unscrew the 2 screws in the top vent grill and remove it.
* 2 Unscrew the 1 screw above the computer keypad, then slide it up to unlock it and it will hinge down, revealing the computer circuit board behind the keypad.
* 3 Put a sheet of foil into the large ziplock bag and seal it up.
* 4 Then tape it to cover the whole circuit board in the back of the computer. You may have to let the wires stick out of the middle of your foil covering. The ziplock is to keep the metal foil from short circuiting anything on the computer, and the foil protects the circuit board from the small amount of leaking microwaves inside.
* 5 Lock the keypad back up and plugin the microwave to test it before screwing everything back together.
Thanks.
Sep 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Two buttons on keypad do not work
HELLO.
The solution is to work on your microwave keypad as explained below.
If there is need for further assist,notice me
Thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile JVM2070sk02 Every thing works and lights up but touch pad will not take any input. Fan ,Boost and light work .
HELLO.
The GE problem is with the magnetron being to close to the computer. If your microwave will not take any input, you can follow these simple instructions to fix it.
needed things.
* Foil
* Tape
1. Unscrew the 2 screws in the top vent grill and remove it.
2. Unscrew the 1 screw above the computer keypad, then slide it up to unlock it and it will hinge down, revealing the computer circuit board behind the keypad.
3. Put a sheet of foil into the large ziplock bag and seal it up.
4. Then tape it to cover the whole circuit board in the back of the computer. You may have to let the wires stick out of the middle of your foil covering. The ziplock is to keep the metal foil from short circuiting anything on the computer, and the foil protects the circuit board from the small amount of leaking microwaves inside.
5. Lock the keypad back up and plugin the microwave to test it before screwing everything back together.
Thanks.
Aug 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Hamburger in foil wrap put in microwave - shorted unit out
Hi- The first thing here is safety. If the power supply is good- 120v at outlet- then address the fuse in the cabinet. Open door, remove screw(s) holding control panel, and tilt out panel. Fuse should be visible. Check for continuity. If bad, replace with 15amp appliance fuse. Plug in and check for operation. If fuse blows again, unplug and start looking at a new microwave. Let me know if this info helps. Have more if needed- Thanks- Ed
Mar 15, 2010 | Whirlpool MH6141XK Microwave Oven
My Sanyo 1000W microwave is shooting sparks!!!
you need to replace the cavity cover "the cardboard like",the antenna bearing set "the gun barrel like" and the gear motor.If the "gun barrel like" is stuck up because the gear motor is not rotating excessive heat will occur inside the microwave thus burning the cavity cover.
Mar 20, 2009 | Sanyo EM-A5200SW Microwave Oven
Set up Oster Microwave
No, that is the "waveguide cover".
It provides very important protection for the magnetron.
And always keep it clean according to your manual's instructions.
Jan 18, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
Hole in film on interior door
wouldnt be concerned about hole in the film strictly cosmetic!film wouldnt be available youd need t repalce door and thats just not feasable
Mar 11, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No display ... microwave does not turn on
You have oficially BLOWN UP the microwave if you pay a service fee it will be aheck of a lot buying a new microwave would be the same price as getting it repaired sorry about that!
Feb 04, 2008 | GE JVM2070 Microwave Oven
Daewoo KOR-1B4H Microwave Oven Logo
159 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Ian Summerfield
Ian Summerfield
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
