Question about Hitachi 50FX48B 50" Rear Projection Television
Hitachi big screen
Model # 50fx48b 163 watts used to turn off on its own after aprox 20-30 minutes and now nothing wont even turn on, please help!
  • ranaweel Apr 29, 2008
    Sound and Picture became intermittent, cutting out every 10 minutes or so then prgressively at shorther intervals. Finally it stopped working altogether. You can hear the relays/audio clicking, but even the Red indicator in the front does not come on.
    Genius:
  • 1,694 Answers
1) Check F903
2) Pull chassis = solder any / all bad connections
Qualified technician recommended................T.
Posted on Dec 13, 2007
My pyle 2200 1400 watt 2 channel amp wont get power..... why!!!!!
did you check the remote turn on wire connection at the back of stereo?
Jan 15, 2012 | Pyle Car Audio & Video
My iphone wont turn on and nothing works
Click on the 'Home' button and on the "Lock" button for few minutes.
If not, charge the device, maybe it's battery is dead, and then press on boat buttons at the same time for few min, that should help you.
Hope that I helped you.
Dec 30, 2011 | Computers & Internet
I have a 3000 watt magnum energy sine wave inverter/ charger. It is hooked up to 5 -12 volt glass matt batteries. the charger used to charge in bulk mode @ aprox. 80 amps then absorb charge and then went...
I'm sorry that I can't help you, but if you're in a hurry, you can visit the Magnum website at: http://www.magnumenergy.com/Service/Servicefront.htm and try to find your model's online manual and search troubleshooting advice or you can email customer service at
support@magnumenergy.com and they should at least be able to lead you in the right direction.
A few questions: Does this problem remain even when there is at least a 10+ watt load on your system? is your Magnum in a hot environment? Does your inverter feel extraordinaryily hot? Have your batteries outlived their lives? Have you cleaned all the connections? Even if they 'look' like they don't need it?
All the best to you.
Sep 10, 2011 | Magnum Energy Inverter Fet Board Tfbrd3924...
I Need a New Power Transformer for hitachi model 50fx48b projection tv.Where can I can I purchase Transformer.?
www.tvrepairworld.com should be able to get any part for your Hitachi. Just click the contact button on the right side of their homepage and indicate your model number and what youre needing
Aug 20, 2011 | Hitachi 50FX48B 50" Rear Projection...
Amp turns on but there is no sound
Abra com cuidado e verifique as lãminas do Jack do phone , pois se elas estiverem levantadas não sairá audio pelo falante, pois existe um chaveamento que interrompe um ou outro. abraços
Walter Brunelli
Apr 29, 2011 | Line 6 Spider Iii 15 Modeling Guitar...
Camera got dropped and has a slight twisted lense
more than buying a rteplacement camera. Even a second hand one would be cheaper than repair
Aug 19, 2009 | Samsung Digimax S600 Digital Camera
Coleman 7300 rooftop air conditionor wont operate
When they sit allot - sometimes the fan will stick.. Take the cover off,, turn it on and see if the fan is stuck.. Spin it by hand to free it up..
Jul 09, 2009 | Dometic Rooftop RV Air Conditioner
Hi please help i have a peugeot 406 hdi i have had nothing but problems with the fuel system first i changed the bosch pump in the tank i then changed the high pressure pump and the car run lovely for one...
Try this but the fault I have is intermittent so may take a bit to work out - switch off everything in the car so there is no noise. Turn on ingnition (do not start) and listen for the sound of of the fuel pump below the rear seat - behind the drivers seat. The pump should run for about 5 - 10 sec then shut off, it may work but if you cannot hear it it may be an ECU issue. If it does run start the car and drive it until it stops again, switch the ignition on/off and listen for the pump running. if you can confirm that the pump is running intermittently you have the same ECU problem I have. The official solution is to replace the ECU - ££££££. The low cost alternate is to run a wire from the ingnition controlled feed at rear of the radio and connect to the pump feed at the fuel tank, ensure a correct rated fuse is installed somewhere along the wire. There is a least one issue with this - if the ignition is on the pump is running, so not a good idea to sit with the key turned to listen to the radio.
Feb 19, 2009 | 2005 Peugeot 405
Televison & Video Logo
276 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
