Question about White Sewing W2500
White w2500 serger
New machine...serging along and suddenly the fabric stops feeding. It stopped feeding in action. I removed the feed dog plate for inspection and it looks ok. I checked the presser foot bar and the tension adjustment knob is moving the spring. It has differential feed, and I moved the adjustment knob and noted that the dogs move closer together. I then attached another foot and it did not work either. If you place fabric under the presser foot and engage the motor the fabric is actually moving in the reverse direction. What's up?
Thanks,
Sharon
  • Anonymous Oct 30, 2008
    Same problem on I have a kenmore overlock 3/4D model #16642. It is 14+ years old but have never had any problems with it.
  • e_p_thomas Jan 10, 2009
    I have an old White 534 Serger which worked perfectly right up to this weekend. I had it serviced 4 weeks ago and it has started to suddenly reverse for no apparent reason in the middle of stitching. I would love to know what is going on with it.
MakikiChris
  • 84 Answers
SOURCE: My fabric won't advance.
Hi Jodyk...Remove your flatbed so you can access your bobbin area. Open the cover of the bobbin area. The shiny/bright components consist of the Bobbin, which snaps into the Shuttle Hook, which is contained in the Race. Immediately right of the Race is a pewter/matte silver colored lever. Press the lower portion of the lever to raise the Feed Dogs. Pressing the upper portion drops the Feed Dogs, and is commonly used to accomplish free-hand applique work......good luck my friend.
Posted on Aug 02, 2007
  • 19 Answers
SOURCE: My kenmore 385 won't feed fabric
hi there check feed dogs are up not down mary h
e
Posted on Dec 30, 2008
louislevel_2
  • 374 Answers
SOURCE: Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Posted on Mar 19, 2009
  • 323 Answers
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
Posted on May 16, 2009
  • 20 Answers
SOURCE: Feed dog on Serger Babylock 5260D
Make sure that the presser foot dial (the silver "knob") on top of the machine is not too loose. You can adjust this w/ a nickel; tighten it all the way down & then loosen about 4 full rotations for cotton fabrics. Also make sure the Differentail feed lever is on "N". You can order a book from your local Baby Lock dealership for all models. Good Luck.
Posted on Jun 18, 2009
My Elna 6000: the needle does not want to move forward or backwards
The needle never moves forward/back on its own for most sewing machines. The needle bar goes up and down. The fabric moves due to the action of the feed dogs. First remove the fabric from under the presser foot. Check for tangled thread wrapped around the feed dogs or fabric/thread going down into the bobbin area in a tangle. Next check if the feed dogs are up. (When the feed dogs are down or covered (on some machines), the machine is in darning mode. The fabric will only move if you move it yourself.) With the fabric out of the way, rotate the hand wheel and check if the feed dogs are moving. Open up the bobbin compartment and clean out any lint, thread or other debris that may be tangling the mechanism. Take off the throat plate and check the feed dogs. A damaged throat plate can stop the feed dogs from moving properly. You may need to replace the throat plate.
For some machines, you may need to make sure that the unit is not in bobbin wind mode. This is usually obvious since the needle bar won't move either.
I hope this helps.
Jul 16, 2018 | Elna Sewing Machines
I have been sewing all morning. Suddenly the fabric does not feed everything is clean
Look at the feed dogs to see if they are rising above the needle plate at least 1 mm. If not rising lint may have felted between the feed dogs and the needle plate. It could also be the feed dogs have been lowered, or the height has slipped. If the feed dogs are above the needle plate turn the hand wheel and see if they are moving from the front of the machine to the back. If not it is a length adjustment. If this is normal the pressure on the fabric may be too low. Another problem may be the timing of the feed dogs. The feed dogs should rise above the needle plate when the needle leaves the fabric and descend when the needle comes down into the fabric. This requires an expert to fix.
Mar 15, 2014 | Euro-Pro Shark 60 - 384
Fabric will not feed
if the serger is new, then take it back
if its not new,,
it sounds like there could be a problem with the feeddogs or with the timing, it would be a good idea to have the machine checked at a sewing machine repair shop..
Jul 09, 2013 | Simplicity Serge Pro SW432 Mechanical...
Baby lock serger will not feed, fabric want come out from under presser foot.
what is the stitch length set to? should be 2.5 or thereabouts for normal serging.
Is the pressure foot pressure turned up too high perhaps?
The reasons I could think of for it not feeding through would be:
- the feed dogs under the pressure foot are out of position/not moving
- that the differential feed is turned up so its pushing the fabric back to the front of the machine
- stitch length is set very low so hardly moving the fabric at all
- or youv'e got a thread tangle happening around the foot/blade area.
Jun 14, 2012 | Sewing Machines
Broken needles
Machine breaks needles
change needles
make sure you are using the right needle for your type of machine.
the presser foot may not be installed properly
use the correct needle for the type of fabric you are working with. To fine of needle on heavy fabric or to course a needle on silk or jersey can damage fabric.
let the feed dogs guide the fabric & the feed dogs will work with the presser foot .
the needles is not all the way in -push all the way up against the stop
Check thread tension
May 02, 2012 | White Sewing Superlock 2000 ATS Mechanical...
Feed dogs are not feeding
Either they are clogged with lint, or if you remove the base and find shredded gears (esp Singer)....not good
Nov 10, 2011 | Sewing Machines
When sewing with the brother serger 1034d, loops of thread stick out beyond the fabric-it is not nice and close like it's supposed to be. the settings from left to right are: 4,4,3,3. this is what my...
Can you wind the lower cutting blade to the right to cut less fabric and therefore fill out the stitching? On most sergers the lower blade position can be adjusted sometimes with a little knob or dial. You need to raise the top blade out of the way first, usually you put pressure onto it to release the spring holding it up against the lower blade, then swing it up to do this. Then wind the adjustment on the lower blade and move it to the right to cut less fabric then test serge. Your manual should give you more specific information on this and should be your first 'go to".
I would adjust my looper tensions to suit the fabric and width of the stitch I'm trying to achieve so yes, the settings you've been given are average tensions but its okay to vary these too. From left to right, I'd set 4, 4, 4, 4 and test serge again and see if this pulls the looper threads in against the fabric if moving the blade hasn't tightened up the stitching.
Sergers are more variable than a straight stitch sewing machine so its okay to move tension knobs a bit, just turn each a half number each time you adjust, then test serge and look at the stitch formation. Your needles tension should be fine at 4, leave them alone.
I'd suggest if you can find one, go to a "Getting to know your serger" type class as there is lots of techniques such as seaming on a curve, turning right angles, both inside and outside and making rolled hem edges that are very helpful serger skills to learn along with making adjustments and troubleshooting. Or go to you-tube and search some of these techniques for videos. Also www.sewing.about.com is a great sewing resource and Debbie has pages on sergers/overlockers here too.
When I'm starting a new dressmaking project I will spend 10 mins on the overlocker/serger, changing the thread colour to suit the garment, then test serging and adjusting the stitch tensions to suit the fabric. I have 4 cones of thread each in white, black, beige, grey, pink and pale blue and these threads will give a suitable finish on most fabric colours and prints. Then there is wooly overlocker thread, this is a fluffy thread that you can use for rolled hems as the thread relaxes once stitched and "fills" out the closely stitched edge covering the rolled fabric edge and is another whole area of fun to try out.
Often I'll just use a three thread to neaten the raw edges of a seam I will press open. Or I will assemble a whole knit garment using the four thread stitch, so much faster then stitching seams, then neatening. Jersey knits and sergers are made for each other.
As an aside the D on your machine model would denote "differential feed" too - briefly differential feed is adjusting the amount that the two feed dogs move under the foot and means you can "hold back" the fabric as it is stitched (0.5), or "stretch" it out (1.5 or 2 setting). Really handy for loose weave fabrics that stretch as you serge them, you can compensate using the differential feed setting. And in reverse, you can create a "lettuce" or wavy edge by turning the differential feed up.
I hope that this helps you out with your Brother 1034D and hasn't just confused you. Good luck.
Aug 01, 2011 | Brother 1034D Mechanical Sewing Machine
Machine does not feed properly. It sewed fine for
Here are a few solutions to check.
* Check your fabric to make sure it isn't caught on something.
* Check your pressure foot to make sure it's screwed tightly in place.
* Adjust the pressure of your pressure foot as it may be too light or too heavy for your fabric.
* Check your feed dogs for lint. If your feed dogs are clogged with lint, they're not gripping your fabric properly. Remove your pressure foot and clean out any lint with an old toothbrush.
* Raise your feed dogs if your machine has this function. They may have been inadvertently lowered.
* Check your stitch length regulator, If its set at “0” or a very small number, try switching to a longer stitch length.
* Change your needle, it may be damaged.
* Check your needle plate and make sure it's securely in place.
* Use a “Jean-a-ma-jig” or a “Hump-jumper”. If you've been trying to sew over a bump of fabric, such as a thick jean hem, try using this tool (your local fabric store should carry it). It keeps your pressure foot level as you sew over the bump and gives your feed dogs something to grip.
I hope this helps
Mar 13, 2010 | New Home L-372 Mechanical Sewing Machine
sewman7
May 14, 2009 | Sewing Machines
What does the differential feed do?
Get a basic book on serging from your library. The higher the #, the feed dogs infront feed fabric in faster, keeping knits, etc from stretching. It can also gather if you go to the highest #. A slightly lower # the N can be used for slippery fabrics because it slows the front feed dogs, but be careful because it can stretch and ruin the fabric. I have only once needed the lower # for a really slippery chiffon. Start on scraps and experiemnt. It's not used very often unless you sew daily or professionally.
Mar 18, 2008 | Baby Lock Eclipse Serger
White Sewing W2500 Logo
191 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
