Question about Whirlpool MH1150XMQ Microwave Oven
Microwave does not warm up food after big bang
Yesterday, I went to start the microwave and heard a big bang. Since then, although controls seem to function and fan starts (it does make a harsh noise), the oven does not get the job done (no warming up of food or liquids).
WHat may have gone bad? Should I have it repaired?
  • BigFunty Dec 15, 2007
    okay testing
  • Anonymous Mar 18, 2014
    My microwave lights up, performs the time countdown, and makes a clicking sound when I press the start key but it doesn't warm the food or make the usual warming noise.
  • 456 Answers
Oh ya man the heating coil is damaged so you have to change it.
Posted on Dec 13, 2007
Maytag Microwave over the counter -error code SE
Banging on the control panel got it working would indicate a bad connection inside, not a short. Could be anything from a bad wire connection to a cracked solder joint on the main board.
Aug 23, 2017 | Microwave Ovens
I have a Kitchenaid YKHMS147HW microwave that started turning on by itself, and will not shut off unless I unplug the unit. If I put food in to cook, the food starts cooking as soon as I plug the unit in,...
Sounds like stuck relay contacts. Magnetrons need a high voltage source which is controlled by a micro to relay and then from relay to voltage source. Even the turntable works via a relay.
Oct 14, 2013 | Microwave Ovens
If you try to heat something for a minute , the microwave will turn on for about 15 seconds then shut off . It doesn't even seem to warm the food.
It may need a reset. You can do that by unplugging the power for a minute or two, then plugging it back in and setting the clock.
If it still fails, you may have a failing cooling fan or a problem on the control circuit board.
Apr 14, 2013 | Thermador MCES Stainless Steel 1000 Watts...
How to fix microwave with bang, flash
That was the magnetron tube breaking. Too expensive to fix. Better to go and buy a new microwave.
Feb 04, 2013 | DeLonghi MW 535 Microwave Oven
GE Spacemaker arcing?
It is possible, but you heard a similar bang earlier, from the description the magnetron is arcing on a occassion because it is failing, or there is bare metal exposed on the interior. I would recommend getting it checked out to make sure there is no safety hazard and have it resolved.
May 02, 2012 | GE SpaceMaker Microwave Ovens
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
Microwave stopped heating, everything else seem to work. heard a big noise with this started.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ]
May 30, 2011 | Frigidaire FMV156DC Microwave Oven
Model #mh1150xmb-0 The light bulb under the microwave burnt out (with a bang) this morning. Although the lights and clock come on the microwave it won't start.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too, and on these models, can prevent them from starting or running.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller
Dec 18, 2010 | Whirlpool MH6150XL Microwave Oven
Although all systems seem to function,(fans lights clock,grill etc.) it does not heat on the MW mode. My wife turned it on thinking it was full when it was empty and heard a Sparking sound. Model WM...
If there is no heat but all other functions work, then the magnatron is likely faulty. The magnatorn provides the heat. You can get one at or
Dec 07, 2009 | Microwave Ovens
Yesterday, I went to use the microwave and as I pushed start, I heard a loud pop and saw sparks behind the vent cover. The microwave light and turn table work fine, but it does not heat. Is it repairable?
sounds like your magnetron went out . check how old it is, sometimes the manufacture gives a 5-10 yr warrenty on part if no warranty on unit then it may not be worth fixing depending on how much u spent on it. part roughly 89.99-139.99 labor 85-165.00 depending on who u use and were u live. hope this helps . thanx..
Oct 07, 2009 | Whirlpool Microwave Ovens
Whirlpool MH1150XMQ Microwave Oven Logo
489 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
