Question about Dell 924 All-in-One InkJet Printer
Carrier jam on dell 924 printer??
Whenever i print the "Clear the carrier jam" appears on the screen and makes a clunking noise; don't know how th fix it
  • 28 more comments
  • smpbizbe Dec 14, 2007
    well I have the same problem I hear two clunking sounds made as the carrier hits both ends of the printer and then it gives me the error message Carrier jam 1. clear the Carrier jam and nothing works cause i don't see anything wrong except the carrier doesn't know when to stop anymore.............HELP!!!!!
  • dlshelley Dec 14, 2007
    I'm getting the error message to "clear the carrier jam" on my Dell 924, however it seems cleared. Any help on this issue?
  • Anonymous Dec 22, 2007
    printer ink cartridges are stuck on left side of printer
  • Anonymous Mar 13, 2008
    whenever i try to print my printer makes a big noise and says carrier jam.. how do i fix this problem?
  • Anonymous Apr 13, 2008
    Same problem. Can't find answers anywhere. The recommendation did not solve my problem.
  • Anonymous Jun 10, 2008
    Same problem - this happened following a paper jam. There seems to be a spare bit of plastic but don't know where from .
  • conlan133 Jul 16, 2008
    dell 944 printer clear carrier jam -don't know how
  • Anonymous Aug 09, 2008
    printer makes a loud clicking sound when turned on
    I have an orange exclamation point when i try to print and there is a loud clunking noise. What do i do?
  • 2kidskk Aug 13, 2008
    THE INK JETS WILL NOT COME OUT FROM RIGHT CORNER ALONG THE CARRIER.
    JUST MAKES A CLICKING SOUND.
    2kidskk@bellsouth.net
    " CARRIER JAM " KEEPS APPEARING IN LITTLE WINDOW.
  • juliyajo Aug 27, 2008
    the printer states to clear the carrier jam, and the cartridge, moves very fast from left to right making a loud sound? how do i fix this problem?
  • dustinkissel Oct 01, 2008
    display says clear carrier jam how do i clear it
  • lisababy Oct 07, 2008
    i have a 924 dell photo in all one printer and when i need to print something is says that i need to clear the carrier jam and i dont know what to do?
  • Anonymous Oct 14, 2008
    That happened to me too! and when I tried to call Dell for help, the guy told me "your printer has gone bad and you need to purchase a new one". Ridiculous
  • Anonymous Oct 22, 2008
    the printer states to clear the carrier jam, and the cartridge, moves very fast from left to right making a loud sound?????
  • flys Oct 28, 2008
    Went to scan paper.came on screen clear carrier jam on press to start. have tried everything . i unplugged, shook it,blowed out with air gas,cleaned plastic strip. everything still connected but still says carrier jam.when try on computer it says printer busy. no doucments in quesk
    help!!!!!!!!!
  • teddybrown05 Dec 05, 2008
    I've been having the same problem and I even put my vacuum hose in there in case there's a lint ball that's causing the problem. I called Dell and they wanted 49.95 to help me and then he says that if it's not fixed then I would have to call back and pay again! NEED TO PRINT!
  • Anonymous Dec 08, 2008
    I have two problems. 1. the paper starts to feed but gets jamed and it will not print.
    2. on my other 924, the incoming fax does not print.
  • Anonymous Dec 21, 2008
    carrier jam error.....cartridge clunks from one side to other and wont center
  • michvincent Jan 24, 2009
    On turning on my Dell printer it makes a scratvhing sound and a notice tells me to clear the carrier jam
  • sam1962 Feb 02, 2009
    carrier jam error keep appearing when ever I start the printer. It also make a very heavy noise
  • fsainbert Feb 02, 2009
    it said clear carrier jam and press continue
  • Anonymous Mar 16, 2009
    Printer 944 - As I tried to print the printer made a very hard banging/scratching sound and then stopped. Printer reported Carrier Jam but I cannot see any paper stuck anywhere. When I try to continue for even restart the printer, it makes a very hard banging noise and goes back to Carrier Jam problem. I have recently replaced the colour cartridge and printer still says I need to put in new cartridge??? Don't know what else to do!
  • Anonymous Mar 19, 2009
       I receive the following message... clear the carrier jam and then press to continue...
    I can't figure out what to do
  • cszpila90 Mar 25, 2009
    I have the same exact problem. My printer started not correctly feeding the paper, when it would the paper would get jammed and I would have to keep trying to reprint only for it to continuously jam once again. Now the printer says "Clear the carrier jam and press start to continue." I have tried everything.
  • Anonymous Mar 27, 2009
    carrierjamcomeuponthescreen
    carrierjam
  • Anonymous Apr 18, 2009
    zz fsdfsdfsdf
  • charliesue May 11, 2010
    my 924 printer says to clear carrier jam. How do I do that?
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Posted on Dec 17, 2007
I had the same problem with my Dell 924 printer.
But, the problem had nothing to do with the ink cartriges. I managed to slide the ink cartriges away from the jam, and saw that the problem was under the cartriges. There was a small black disk with silver teeth connected to an unravelled spring sticking up. I couldn't fix it, so I had no choice other than to cut off the spring-wire connecting it to the carrier. I had to make sure there was absolutely no wire sticking up at all... It's printing smoothly now, but I literally just fixed it, and I don't know how long it's going to last now. I don't know if I reccommend this option, but it's either this, or get a new printer. D: Do not follow this option unless you've tried the other solutions first!!
Posted on Apr 19, 2009
Jmhomulos, your solution certainly put me on the right track, however it was the cartridge on the far left that was the problem on my 944. I used a firm plastic kitchen spatula to hold cartridge top down enabeling both cartridges to engage properly.
I would never have fixed it if not for your help, I did not even know what a carrier was and as far as Dell's solution, well, stupid leading stupider comes to mind.
Thanks from Ireland,
Lilian1.
Posted on Jun 05, 2008
HI, MY CLEAR THE CARRIER JAM APPEARS ON THE SCREEN AND MAKES A CLUNKING NOISE PLEASE HELP......
Posted on Dec 09, 2008
I HAVE THE DELL 924 IT KEEPS SAYING CLEAR CARRIER JAM AND MAKING A WEIRD NOISE BUT THERES NUTHING BLOCKING IT WAT CAN I DO HELP ME PLEASEE ASAPP
Posted on Apr 22, 2010
All lexmarks are ******* ******** **** them all in the ******* *** twice at the same mother ******* time. they can ************ for having bought a brand new ******* printer and the damn thing is clean as ****, yet there seems to be a ******* carrier jam. they should have put on the damn box that every one of their printers come with a carrier jam.
Posted on Jul 13, 2009
I got the "carrier jam" message with a terrible rasping sound after changing an ink catridge on a Dell 942 printer. Seems I had pressed down too hard on the lid of the ink case. Lifting the ink carrier apparatus slightly with a finger did the trick
Posted on Mar 02, 2010
2 Suggested Answers
SOURCE: Carrier jam on dell 924 printer??
eventually I uninstalled it then re installed it and thank god it solved the problem ididnt know it was that easy
Posted on Jan 17, 2009
I Got a dell printer and i don't know what to do and in the printer it says Clear Carrier Jam
Turn the printer on.
Lift the lid to expose the print-head mechanism.
The "carrier" is that part of the mechanism that moves the print-head across its range.
Something is physically blocking, or "jamming", that carrier.
Feb 25, 2011 | Dell V305 All-In-One InkJet Printer
The carrier is not taking the paper all the way in . I have tried feeding it through. I have tried cleaning the carrier. I don't think there is anything obstructing it. If it does take some of the paper...
no, we will not be able to fix the print wheel. by the symptoms you are describing.. it appears to be an hardware issue..
will have to replace the printer!!!!!!!!!!!!!!!!!!
Aug 12, 2010 | Dell 924 All-in-One InkJet Printer
"Clear the carrier jam" on DELL Printer 926
could something be stuck in the printer? clip/ paper/ dust
might be that simple!
Jan 24, 2009 | Dell 926 All-In-One InkJet Printer
Jan 16, 2009 | Dell 926 All-In-One InkJet Printer
Dell all in one 926
Did you lift up the front and look?
Did you open the door in the back (lower) and look?
Jan 16, 2009 | Dell 924 All-in-One InkJet Printer
How to clear carrier jam in Dell Photo All in One 944
simply open up your printer and see if there is any residual paper that get stuck, in some case if you can find some small miniature piece of sensor it might cause a erratic sensing that there is a presence of paper while there isnt, try to clear this or clean.
paper jamming indicator means there is some paper in the paper path, unless otherwise ou clear this up you cannnot print.
after you may need to power down or restart your printer once again
cheers
Nov 27, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 Carrier jam
Try and manually move the carrier. If it is stuck, dont forcefully move the carrier.
Jul 13, 2008 | Dell 922 All-In-One InkJet Printer
Need to fix a carrier jam
you have to open the printer and check for any parts is struck or dislodge
Jun 23, 2008 | Dell 924 All-in-One InkJet Printer
Carrier jam
i had the same problem and i'm almost positive it's because i do not have a color ink cartridge in my printer. i called the technical support and they said that both ink cartridges have to be in the carrier for the printer to work. even if one of them does not have ink in it. hope this helps. (for me too)
Dec 18, 2007 | Dell 924 All-in-One InkJet Printer
Dell 944 All-in-One Printer - printhead carrier jam
I just found that one of the little feeder rollers (??) on the roller bar has jumped out and is sitting (still attached by its spring) on top of the roller bar. I reckon that's curtains for the printer. Am I right or is it repairable?
Nov 25, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
7,450 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
