Question about Canon PIXMA iP3300 InkJet Photo Printer
How to reset waste ink absorber full ip3300 warning?
My problem is canon iP3300 waste ink ABSORBER is full and the warning sign of servicing the waste ink absorber is needed. any solution please? i need the servicing code to reset the waste ink absorber meter counter. thanks
  • 5 more comments
  • Scahnabel Apr 01, 2008
    Printer is online, the message "Waste ink Absorber Full warning"
    and I can't print.
  • third eye Apr 05, 2008
    how to reset waste ink absorber full ip3300 warning?
  • Anonymous Apr 19, 2008
    yes, i have the same problem, how could i get these code?
  • kejin Aug 25, 2008
    Black ink is 1/2 full ((5) PGBK, but error message is " ink tank errors have occured" and " some ink tanks cannot be recognised"
    any suggestions????
  • gazy600 Aug 27, 2008
    i have a pixma ip3000 the blue and red empty in the printer now it says service error 6c00
  • Anonymous Sep 10, 2008
    fdsfdsfdsfdsfdsfdsfsdf
  • mark_lu256 May 11, 2010
    my problem is canon iP3300 waste ink ABSORBER is full and the warning
    counter. thanks
Try to enter service mode and reset EEPROM:
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head
Press RESUME 4 times then POWER to execute the command
turn the plug off turn on and all ok
Posted on Jul 30, 2010
    Problem Solver:
  • 7 Answers
My ip3300 orange bling 5x ,,how to do it??? help
Posted on Aug 24, 2008
I have the same problem, but Jet Tec waste inks. When I first replaced black (pgi 5bk)-don't forget to place the small chip from the original cartridge to replacement; it worked fine. But now, it has a lot of problems because this **** printer from canon only want original inks (and the original are tooooooooo expensive). I'll never bought anything else from canon.
Posted on Mar 23, 2008
Ink apsorber full /? canon ip 3300
replace waste ink absorber and reset main board. better contact an authorised service point
Apr 14, 2011 | Canon PIXMA iP3300 InkJet Photo Printer
E8 Waste ink absorber full, or platen waste ink absorber full WHAT MUST DO?
I am told that this will reset your counter and eliminate the full absorber warning that you are getting.
Cleaning the pads is messy, sending the printer to Canon is expensive,
I used a simular reset code for my MP470 and haven't had any problems.
1. To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Jan 14, 2011 | Canon PIXMA MP190 All-In-One InkJet...
I have a CANON PIXMA IP3300 printer. When i power the printer it warning "the in absrorer is full"
If it says nearly full, you can make a few more prints, if it's full it will shut down until the ink absorbers are replaced and the counter reset by a shop.
Dec 04, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
Ink absorber full
This is a very common problems with canon printers. They are set for a certain number of prints and they need the ink absorber serviced. Now along with resetting the printer its best to replace the absorber. Here is link to site that has reset instructions.
http://ij-forum.blogspot.com/2008/08/reset-waste-ink-absorber-error-waste.html
Thanks,
Lee
Nov 05, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
How to solve waster ink absorber full problem in canon ip3300
You need to replace the waste ink absorber and then reset the counter. Generally when these errors occur the waste ink absorber needs replacing, if not your images will start to degrade in quality and you will start to see ink splays / splodges appearing as well as random spots and ink patches. In the mean time press RESUME /CANCEL to continue printing.
Oct 02, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
Waste full
The waste ink absorber is a piece of sponge that (as its name implies) absorbs waste ink. On many Canon printers it an be removed if you are fairly dextrous. Wash it out and dry it and then refit. It may well be a fiddle but it will go back in.
The difficult bit is resetting the printer so that it knows the absorber is empty.
Do a google on resetting the waste ink warning for your particular printer (it's not the same for every Canon). It's done with various combinations of button pressing and light sequences and generally works first time (though one of mine took 4 or 5 goes before it actually reset).
Jul 26, 2009 | Canon Office Equipment & Supplies
Waste ink tank full
You can try this
Reset ip2000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 21, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon pixma MP110 waste ink absorber full
1 - Turn on the printer
2 - press MENù SCAN COPY SCAN (it will enter in service mode)
3 - select TEST MODE
4 - Select PRINTER TEST in TEST MODE
5 - Select EPROOM CLEAR
6 - Select INK COUNT
7 - Press OK
8 - Press the STOP/RESET key and then press the ON/OFF key
9 - Change the waste ink absorber in the printer
Oct 24, 2008 | Office Equipment & Supplies
Waste ink tank full
please help me for repair waste in tank full canon ip3300.
Nov 01, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Canon PIXMA  iP3300 InkJet Photo Printer Logo
7,140 people viewed this question
old marine
old marine
