Cars & Trucks Logo
Posted on Sep 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
94 mazda B3000 3.0L cylinder head torque specs
94 mazda B3000 3.0L cylinder head torque spec,,, Need cylinder head bolt torque specs. thanks
  • 1 more comment
  • Anonymous Mar 19, 2014
    TORQUE SETTINGS FOR CYLINDER HEAD AND BIG ENDS
  • Anonymous Mar 23, 2014
    I locked my keys in my 1994 mazda b3000
    flywheel bolt torque specs for 1985 ford courier
Anonymous
Level 2:
  • Expert 233 Answers
  • Posted on Sep 17, 2009
Anonymous
Expert
Level 2:
Answers
233
Questions
0
Helped
109397
Points
966
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
  • Clive Abrahams
    Clive Abrahams Aug 05, 2021
    Ask for valve setting on 3cyl spark 2007
Pregasen
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 29, 2024
Pregasen
Contributor
Level 1:
Answers
Questions
0
Helped
5744
Points
6
Hi wat is da torque spec cylinder head v6 ford courier
Head bolt torque specs 4 cylinder 2.3l
Here's a link Robert,join their site,it's free,then you can use their repair guides like me.
Need head bolt torque specs for a 1996 saturn sl
Quote:
Originally Posted by norvelplagbao52
1993 saturn sl2 1.9 dohc cylinder head torque
specs and sequence
Cylinder head bolt
tightening procedure:
CYLINDER HEAD BOLT TIGHTENING SEQUENCE:
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
torque the cylinder head bolts. Torque: 30 Nm (22 ft-lbs).
In sequence,
torque all bolts. Torque: 50 Nm (37 ft-lbs)
In sequence, turn each bolt an
additional 90 degrees.
specs and sequence
Cylinder head bolt
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
In sequence,
2helpful
2answers
04kiaoptima 2.4crankshaft torque specs
main bearings torque is 18 ft lbs. plus 90 - 94 degrees, rod bearings torque is 13 - 16 ft lbs. plus 90 - 94 degrees.crankshaft damper bolt torque 80 - 94 ft lbs, fly wheel bolts torques 94 - 101 ft lbs.
2000 model mazda 323 astina cylinder head bolt torque specs
Three stages with new bolts (a must), 1st 60 pounds, then 70 pounds then final torque is 80 FT Pounds.
2helpful
What are the torque specs of the head bolts of a Mazda protege 94
step 1 17-19 ft/lb
step 2 90 degrees
step 3 additional 90 degrees
engine uses Torque To Yield head bolts
New head bolts must be used when cylinder head is replaced or re-installed
stockam auto
If you need further help, reach me via phone at https://www.6ya.com/expert/dennis_f849d3d6a68c6430
7helpful
2answers
2003 mazda 6 3.0 need the main bearing torque specs
I'm sending you the torque specifications for your main bearings and also your head bolts. I also sent you main bearing and cylinder head tightening sequence. I hope this will be useful2c713bf.giffce6623.gif
Main Bearings Torque specs. 40-43 Ft. Lbs.
Cylinder Head Torque specs. 56-60 Ft. Lbs.
Need torque spec sheet for heads on a 4.3 tbi on a 94 chevy silverado
Cylinder head bolt torque specs: Step1 25ft lb
Step2 45ft lb
Step3 65ft lb
! 8 5 9 !
! 12 4 1 13 !
!_______________________!
! 11 7 3 2 6 10
Top Mazda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mazda Expert? Answer questions, earn points and help others
