Question about Goodman GMS90703BXA Heater
Furnace newly installed, cycles off too soon and reignites
  • buckeye fan Dec 19, 2007
    had to set fan speed higher due to horizontal evaporator for a/c
    had already set anticipator to furnace mfg specs...thanx anyway!
    Sergeant:
  • 288 Answers
What type of thermostat are you using. It may be possible that the heat anticipate is not set correctly.
Posted on Dec 18, 2007
  • Rob Luna
    Rob Luna Dec 20, 2007
    Are you using the same fan speed for the heat as wlll as the a/c?
Goodman Furnace gms91155dxa not staying on. The system ignites, but shuts off after 3 minutes. 1 blink LED system light
100% sounds like an electrical problem, something is not allowing it to go into a duty cycle.
Dec 04, 2016 | Goodman Heating & Cooling
Does Vulcan Pyrox gas wall furnace have a filter? It seems to cycle on and off too often and the gas seems too high. Also it makes a bang when reigniting. How can I turn the gas down inside it?
get it serviced by a licenced gas fitter / plumber. Should be serviced every two years. Don't risk your life via carbon Monoxide poisoning get a licenced gas fitter /plumber to assess the unit.
Jul 12, 2015 | Vulcan Heating & Cooling
Hydra flame r.v. furnace works as it should several cycles then all of a sudden at end of cycle the blower fails too shut off and will not reignite until shut off at thermostat. Is circuit board causi
Not only can the circuit board be faulty but the high limit switch may be the culprit as the furnace may be overheating and the default function is to have the fan run until the temp in the combustion chamber is within normal limits. the fan switch itself needs to be checked for proper cut in and out function. Hope this helps.
Jan 04, 2015 | Heating & Cooling
Boiler fails to reignite
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Mar 26, 2011 | Heating & Cooling
Any time you run out of lp gas in a tank fed lp gas appliance what is the proper way to reignite the appliance when the gas lines have air in them?
Depends on the appliance. If it's a gas grill, turn the tank on very, very slowly until it's fully open.
If it's a gas heater or gas log set, the air will have to be purged out of the line, so the gas can reach the pilot, before relighting. If it's a gas range, depending on how long a run of piping, you may also need to purge it. If it's a gas furnace, you'll have to do the same thing. Unless, it's a high efficiency gas furnace, then it will purge itself when it runs thru the start up cycle.
Hope this helps.
Rich
Feb 09, 2011 | Thermos Stainless Steel Gas Grill
I have a newly installed 35k btu natural gas wall
The disc is doing its job, saving your life! If the heat exchanger gets too hot this disc is the safety. Find out how hot the heat exchanger is getting and what the disc is rated for. Check that there is air flowing over the heat exchanger keeping it from over heating. If your vent was installed incorrectly it could be keeping too much heat inside the furnace not allowing it to escape to the outside.
Dec 29, 2009 | Cozy (W352E) Heater
Newly installed furnace led light flashes continuously
on some new furnaces that is the "heart beat" and means everything is ok. There should be a key on the control or on one of the doors somewhere
Oct 08, 2009 | Heating & Cooling
I have a ravenheat boiler that i have no idea hoe to reignite
you need to reset it but if it dont light you prob have rectifaction fault
Feb 15, 2009 | Calvin Klein The Field Controls Company...
We have a Intertherm MAC 1378 gas furnace in out mobile home and it has shut off on us. There is still gas coming in, we checked the meter outside to be sure. But when we try to reignite the pilot light it...
Check to make sure the roof vent is not covered over with snow.
Very deep snow can block the intake to the furnace. You may need a ladder and a broom (or shovel) to clear the snow.
Hope this helps.
Matt
Jan 03, 2009 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
48 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
vance jones
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
