Question about HP Pavilion dv2120us Notebook
HP Pavilion dv2120us Notebook PC battery release latch
My battery release latch is stuck. How do I fix the latch to the normal postion. I can release the battery because the battery release latch is jam.
  • 6 more comments
  • nicktal89 Dec 25, 2007
    when i installed my new battery, the latch that releases it got stuck in the "release" position, yet the battery remains firmly connected to the laptop. the battery works and everything. i just cant take the battery out. i have a hp dv2000
  • Anonymous Dec 28, 2007
    I have a hp pavilion dv9500t that the battery is jammed in also. The release slide is also jammed in the open position. hp says that I need to mail it in for repair and I'd like to avoid that if at all possible.
    I tried prying it out with my finger nails, but it is stuck and I don't want to use a screw driver because that will mar the surface.
  • axgupta12008 Jan 26, 2008
    I have HP DV6000t and the battery release latch is stuck in open position. The battery is jammed and I need to remove it to reset the laptop. The laptop cannot be opened as suggested in the solution because some screws are located under the battery. Till the battery is removed, the bottom case cannot be removed. Any ideas will be appreciated.
  • dr620 Mar 02, 2008
    I have a HP dv2000 and the battery latch is stuck. Should I try to force the latch?
  • Anonymous Mar 07, 2008
    I have an HP Paviliondv6000. When I first purchased it and put the battery in, it got stuck. I had to exchange the laptop. I did not remove the battery of the new laptop for about 11 months. When I did, the latch on this one got stuck also.
  • kagerry Jul 28, 2008
    Same problem. My HP Pavillion DV2000T battery latch is stuck. I even bought a second battery and now I can't use it. I sent a note to HP tech support and they gave me this ridiculous video on sliding the latch to open the battery. They also gave me a link to national support providers. Best Buy was listed and when I contacted them, they said that they don't fix laptops bought someplace else. Another provider, Micro Center, said that it would cost $79 for a diagnostic and almost $300 if they have to send it out. I have a second HP notebook and the wireless radio broke after less than a year. I also have a 3 month old HP monitor and the screen turned pink. Luckily I was able to get a good connection by buying an HDMI cord. HP products are a really big disappointment!!!
  • Curt Pool Apr 18, 2012
    Make sure you pry on the side opposite of the switch (the side on the back of the computer). If you pry on the switch side, you will bend the release.
  • Anonymous Mar 15, 2014
    battery release latch has come off hoe do i put it back (probook)
My battery latch got stuck in the open position after replacing the battery on HP's DV 6300 series. The battery was thus stuck. I used the 'screwdriver' technique but with a rounded end kitchen knife not an actual screwdriver to remove the battery. It is important to push the knife down a little into the groove at the outer long edge of the battery and pry that outer edge up. AFTER DOING THIS THEN GOING TO REPLACE THE BATTERY I REALIZED THE LATCH PROBLEM OCCURRED BECAUSE I HAD PUSHED THE BATTERY LATCH TO THE OPEN POSITION TO REPLACE THE BATTERY. THIS IS WHAT JAMS IT. TO REPLACE THE BATTERY 'DON'T TOUCH THE LATCH AT ALL'. LEAVE THE LATCH IN THE CLOSED POSITION AND REPLACING THE BATTERY WILL SET THE LATCH IN THE CORRECT CLOSED POSITION, READY TO BE SLID TO OPEN POSITION ONLY TO DO THE ACTUAL BATTERY REMOVAL.
Posted on Mar 21, 2009
  • Richard Pratt May 07, 2013
    Moving it up and not out is the main thing. I manage to do it with all 8 fingernails once I realized I needed to pull up and not out.and not to pull back the latch when replacing the battery. Works great!!
This site was a great find ! The solution(s) worked ! Several people have offered correct solutions with slight differences that can be summarized as 1) Do not put the battery in while holding the release in the open position (pushed towards the outside of the case) 2) If that's what you've done then be aware that the release is already in the open position & stuck there so this release button has nothing to do with the problem at this point. The battery is simply stuck ! 3) Pull or pry the battery on it's inside edge - the long edge that is nearest the release button. That's the side that releases first so that the battery can be removed.
Posted on Jun 09, 2010
I was able to remove it without damaging anything. What you need to do is push the latch all the way to the right with a scissor or a screw driver. If you keep forcing it will pop off. You can either force it to the left or lift the plastic lever slowly. It is cheaply made. Once you have it removed you will see another hinge that if you push down it will release the battery. Push it down and pry the battery with your hands. You should be able to get remove it. All I had was a scissor. I have a light scratch from the back. I dont think I will be putting the battery anymore.
Posted on Jan 25, 2009
The battery was stuck -- with the latch in the open position -- on my HP dv2000, and I found that my cake frosting tool was the best for freeing it. I tried the thin flathead screwdriver first, but it left some little marks in the plastic around the battery compartment and bent up the tool. The cake frosting tool (looks like a big flat knife, only much thinner, very flexible and rounded) worked great. I just used it to pry the battery out by working it around the edges while applying some light pressure, just enough to flex the tool a bit. Battery popped right out.
This is the most use I've ever gotten out of that kitchen utensil. Ha-ha!
Posted on Jun 17, 2010
  • dmva Nov 26, 2011
    This worked absolutely PERFECTLY. And didn't even mess up the frosting knife either, with my wife glaring at me while I tried it. Overall, that'll teach me to pay more attention, and not try to put the battery in backwards, jamming it. I was sure I was going to be on ebay, searching for a replacement frosting knife...
Ok, I fixed the problem by prying out the battery with a flat head watchmaker's screwdriver. My toolkit has a number of these screwdrivers both in philips head and flat head. I used the thickest flat head one. Quite a bit of force is required so the smaller screwdriver might have broken. The release latch popped into place and now it is working correctly.
You may also want to try to press the battery into place, particularly the outer edge, to try and get the release latch into position. If this doesn't help, the prying the battery out maybe the only solution. It did leave some scars on the edges of the battery compartment but saved me the trouble of sending the laptop back to HP.
Hope this helps.
Posted on Jan 26, 2008
    Scholar:
  • 48 Answers
You either need a flat screwdrive to pry it out. or safest way is to remove all screws from chassis and remove the halves and reset it that way. Here is a guide on how to disassemble a laptop
http://www.irisvista.com/tech/laptops/Toshiba_Tecra_S2/pull_apart_laptop_1.htm</url>
Posted on Jan 07, 2008
John898's resolution works. Pop the latch off by lifting up on it with a screw driver. Once the push latch is off you may see a sliding mechanism with a square hole towards the outside of the laptop (towards the CD/DVD ROM). This is the unlock position. Mine was messed up where the latch was to the unlock position, but the internal rail was caught in the locked position. Luckily, the hole was there just enough to get a pair of needle nose pliers on, and I tugged towards the CD/DVD ROM and heard it unlock. Still had to pry the battery off, but you can do it by hand (may need someone else to pull on the sliding hinge with the pliers while you tugged the battery out). Don't bother trying to take the laptop apart... there are screws under the battery to get the bottom off. The sliding rail catches on itself for me also so fat chance of releasing the battery properly once it's back in. This is a huge design flaw with the dv2000 or any HP laptop that has a crappy, plastic sliding battery ejecting mechanism. The thumb latch may not work anymore as in my case. The two little parallel plastic clips are too short so they pop out of the square hole making it useless.
Posted on Feb 16, 2009
I got mine open with the screwdriver. What a poorly designed lever system. The release button connects to a long slidind rod that catches on the battery, securing it in 3 places.
One of the 3 spots in mine was misaligned, and the tab broke off when the battery finally came free.
So I can remove it freely now, but it is only secured 2/3 as well as before.
Bit of a toss up.
Posted on May 12, 2008
    New Friend:
Http://bijeshkawan.com.np/stuck-and-cant-remove-hp-pavilion-dv6000-battery-problem-solved.html
use this link really helpful
Posted on May 01, 2013
The HP Compaq Presario CQ62-417NR Notebook PC, which was the "newest" model in stock when I bought a laptop June 2011 has the same design flaw. Crappy plastic latch, that gets stuck in the open up position. One must be careful when putting a battery in to be sure the stupid crappy latch is not stuck all the way over to where they pushed it to get the battery out. Mine was stuck big time. Thanks to the comments on here I found my solution, which is the only one. (I am not going to risk taking a computer apart to re-set the latch; some times I lose my car keys for days on end, so taking it apart is not an option for me) My solution was to use one of the little flat head screw drivers - 3.00mm. I was able to slide it into a small crack on the side long part of the battery opposite the dvd drive, give it a small tug and the battery popped out. The latches are so cheap mine broke when I first encountered the problem because I tried to force the long knob. I did not realize it was in the open up position. Words of caution. Just pop the battery out, and you may save the latch knob. Just be careful when popping the battery out to stay away from the side where the contacts meet. A screwdriver could potentially cause problems in that area (towards the dvd drive). Cheers!
Posted on Dec 14, 2011
I was able to clear a stuck latch by forcing a wide screwdriver into crack around the battery and then prying the cover open.
Posted on Sep 20, 2009
    Sniper:
  • 109 Answers
I Have A Diffent Type Of Laptop
And Found That Tweezers Work If The Slider Bit Is Lost
Posted on Apr 07, 2009
If you need a new battery, I suggest you could purchase one from battery, which would shipping to you fast and the quality is satisfy satisfied.:)
Posted on Apr 30, 2008
  • JohnTiger Jan 27, 2011
    I own a Compaq Presario V5000 laptop. I followed the advice of Michael. I wedged my flathead screwdriver between the space of the battery and computer bottom. I twisted my screwdriver to pry the battery out of its locked (stuck) position. Once the battery came out, the stuck latch returned to the original closed position. I inserted my new battery. Fortunately, my latch works normally again. Thanks for the help.
I have an HP dv2000 and I also fixed the jammed battery using the thickest flathead screwdriver in my jewler's set. Just wedge the screwdriver all around the outer edge of the battery, including the sides. It pops out fairly easily, and you don't need to loosen any screws. I managed to do this with no visible scratches to my case once I put back the battery.
Note: the "open" position is towards the outside edge of the laptop. The "locked" position is towards the middle of the laptop. This fix is for a jammed battery while the latch is in the "open" position.
Michael
Posted on Mar 15, 2008
Need to replace the battery release button for my hp pavilion pv3, any suggestions
Go to service. Or check HP for spare parts for your laptop. Adress the shop where you brought it for service.
Mar 07, 2013 | HP Pavilion dv2120us Notebook
Hp dv2000 battery latch stuck
I am just gonna post my answer to another, like question. BTW, this seems to be a design flaw. Do not know if HP made them this way to keep maintenance busy, or they just do not have a clue. Here was my solution, which was found on a similar question. - The HP Compaq Presario CQ62-417NR Notebook PC, which was the "newest" model in stock when I bought a laptop June 2011 has the same design flaw. Crappy plastic latch, that gets stuck in the open up position. One must be careful when putting a battery in to be sure the stupid crappy latch is not stuck all the way over to where they pushed it to get the battery out. Mine was stuck big time. Thanks to the comments on here I found my solution, which is the only one. (I am not going to risk taking a computer apart to re-set the latch; some times I lose my car keys for days on end, so taking it apart is not an option for me) My solution was to use one of the little flat head screw drivers - 3.00mm. I was able to slide it into a small crack on the side long part of the battery opposite the dvd drive, give it a small tug and the battery popped out. The latches are so cheap mine broke when I first encountered the problem because I tried to force the long knob. I did not realize it was in the open up position. Words of caution. Just pop the battery out, and you may save the latch knob. Just be careful when popping the battery out to stay away from the side where the contacts meet. A screwdriver could potentially cause problems in that area (towards the dvd drive). Cheers!
Feb 08, 2011 | HP Pavilion dv2120us Notebook
I have a HP Pavilion dv6225us laptop, and cannot get the battery compartment out. The release latch does not work.
Cheek for screws if any. if not (1) Press slide and hold the battery latch toward the outside edges of the computer. (2) Slide the battery Straight back still pressing to Remove.
Dec 09, 2009 | HP Pavilion dv6225us Notebook
HP Pavilion dv6225us laptop battery release latch
is the latched stuck in the open or closed position? if it is in the open position you may be able to wedge a pick or small flathead and gently ease it out. if it is in the locked position attempt to use one of these same tools to move the latch to the open position. hope this was helpful.
Dec 09, 2009 | HP Computers & Internet
Describe your HP Pavilion dv2120us PC Notebook Problem dvd drive not working
try whether cds are working in it and use an good dvd lens cleaner
Jul 22, 2009 | HP Pavilion dv2120us Notebook
Dv2120us keyboard buttons light but screen black, won't boot
Hello Atty
I understand that your Notebook is not powering on. Your Notebooks , that is dv2120us is having a manufacturing defect. So HP accepted that the Notebook will be serviced under the plan "One Time Service Enhancement" . Even if the Notebook is out of warranty your Notebook may be serviced. For more information log on to the chat support .
.http://welcome.hp.com/country/us/en/contact/chat_1.html
They will assist you with the details and the procedure, how to send your Notebook to HP for service.
Feb 16, 2009 | HP Pavilion dv2120us Notebook
Ram capacity on HP Pavillion dv2120us
nope....that 2 gig is true..and the reason it may be invisible is that it is not seated properly, or, it is mismatched..
Oct 16, 2008 | HP Pavilion dv2120us Notebook
Laptop dv2120us
There is one screw on the bottom of the machine that removes the CD right above the memory cover. It may even have an icon of a CD for it. then it should slide out the side.
Dec 20, 2007 | HP Pavilion dv2120us Notebook
Computers & Internet Logo
11,698 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
