Question about Panasonic PT-40LC12 40" Rear Projection HDTV
No picture Panasonic PT-40LC12 40
Replaced bulb, no picture, green light blinks
  • 3 more comments
  • jalli Dec 21, 2007
    I also have the same problem.... help appreciated. thanks.
  • YUNGLE Jul 15, 2008
    HELLO ! I HATE THIS TV. HAS REPLACED BULBS 3 TIME , NOW WITH THE NEW BULB WHEN TURN ON THE GREEN LIGHT BLINKS AND NO PICTURE + NO FAN , THE MODEL NO # PT40LC12 AND THE SERIAL # K2AA51771 PLEASE SOME ONE HELP BEFORE I BLOW IT UP AND WILL NEVER , NEVER BUY ANOTHER PANASONIC AGAIN . THANKS. SO MUCH FOR HELPING .
  • nmshimizu Aug 09, 2008
    Help, please.
    Same problem.
  • dottenbacher Jan 26, 2009
    green light just blinks. no fan or anything else turns on. it has a new lamp. it worked for a while but then this.....
  • tracy73 Feb 24, 2009
    Hi, I just got this TV from a friend and I have never had one like this before so I was wondering is there any special way to clean the screen? Can I use Windex or just water?
    Problem Solver:
  • 16 Answers
Sent me the serial number, and I can check for any re-call ...
my e-mail is <ultraman_s@yahoo.com>
Posted on May 22, 2008
    President:
  • 4,402 Answers
Found that the thermistor/temp measuring device is suspect, no resistance across legs. There is a label there that says F701 see service manual
http://www.goodmans.net/get_item_th-tf117c_thermal-fuse-117-degrees-celsius.htm
I went here for a tech manual for the Panasonic
tv.
http://www.ManualsParadise.com
then ordered
Manufacturer: Panasonic
Part Description: FUSE
Part Number: LSJA0411-1
from
PartStore.com
it was mounted to the case that holds the lamp. had to remove the back panel, etc. Also think I had to splice in the fuse or something. was a while ago.
i purchased a NTE8115 from my electronics supplier, closest I could find.
Radio shack also has them.
remove the back cover and measure for continuity across the thermal fuse
above the lamp housing.
if open jump it wth a 5 amp fuse, be sure to close the safety switch with
the small blue lever then try to power on.
If comes on ok you will need to replace the entire ballast assembly to get
that fuse.
Panasonic does not have a part number for just the fuse on the PT40LC
series.
It is possible to cut off the fuse and replace with another but dont solder
Posted on Jan 28, 2008
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Turned itself off. I turned it back on and the green power light blinks for awhile then blinks red for awhile.no picture or sound
Get rid of this TV. Had one and replaced the bulb and light engine many times. Just buy a Samsung or Vizio 50+ inch instead and be very happy. Those Panasonic projection TV's were terrible. You will find a 50 inch Vizio for around $500 bucks and it will blow your mind how great the picture looks.
Oct 16, 2014 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-52LCX66 blinks green then red lamp light comes on
Replace the lamp cartridge. You can get the replacement DLP lamp from www.tvrepairworld.com and the lamps come with installation instructions
Oct 27, 2012 | Panasonic PT-52LCX66 Projection Television
Panasonic PT-50LC13 Power Light Blinking Yellow
My Panasonic PT-50LC13 when turned on has a green light for a few seconds you can hear the fans turn on and then you have a yellow/amber light that starts to blink 8 times i have replaced the bulb and the door is closed any ideas?
Apr 01, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic model# PT-50LC13
It very well could be the ballast. I unfortunately have this tv and keep extra bulbs because they go out about once a year. Last time when I replaced the bulb the tv blinked and the red lamp light flashed like it does when the bulb is bad. Ballast repair kit fixed it up. This is certainly a design issue but you'll get no help from Panasonic. If tv comes on the goes out after a while, clean the fan filter.
Feb 17, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
367 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
