Question about Mitsubishi WS-55805 55" Rear Projection Television
Mitsubishi 42 in hdtv
I have red and green shadowing in my picture...i've tried adjusting the convergence but that does not work...too far out of adjustment...picture sometimes corrects itself....any suggestions.
thank you! chris
  • 1 more comment
  • suitashlee Jan 10, 2008
    Some days it wants to be cooperative, but some days mine doesnt. It's doing the same thing. It turns into red green and blue separation, you mostly notice it on text, and the image seems to become curved like a rainbow. Sometimes it fixes itself, and i know its bad...but sometimes if i pound on the top of the TV once or twice the image comes back. I don't have the money to fix it and the picture is great...when its working.
  • mr dee Jan 22, 2008
    what is the cost of this/these parts and could this be done by a computer repair kinda guy or...what would a repair cost??
    the mdl# i have is a WT-42413
    Genius:
  • 1,694 Answers
Convergence issue = STK IC's involved on center circuit board.
You can solder the connects, but that is a temporary fix.
Correct solution is to replace IC's....need the exact model # off
the back of the set to verify part number...could be STK392-570
quantity 2 or STK393-570 quantity one...................T.
Posted on Dec 13, 2007
  • Vista Electronics Jan 22, 2008
    The center circuit board has a large heatsink with one IC on it.
    Part # STK393-570....you can either re-solder the pins of the IC
    or replace it for about $20.00.....take your time .........T.
Picture shadow
Tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have colors pictures shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Mitsubishi WT-42413 42" Rear Projection...
Tv gets a red and green shadow on the left side after being on.
convergence solder connections likely going bad. you may be able to resolder or just replace the chips.
check my tutorial and let me know if you need more help.
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Jun 05, 2010 | Mitsubishi WT-42313 42" Rear Projection...
I have a HCN4727w samsung. Red/green shadowing. Bowed image
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 17, 2010 | Samsung HCN4226W 42" Rear Projection...
Mitsubishi wt42313. Three pictures, one with each
Thats caused by the convergence Ics having failed. www.tvrepairworld.com should have the convergence kit for your model. The kits also contain the CD with instructions.
Dec 22, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi TV Model #WS65903 - Green Shadow Lines on Screen
Something is not right here--The green is adjustable in the TECH menu--did this person adjust or try to adjust in the customer or the TECH menu?
If you confirm actual model number I can tell you how to get into the TECH menu--yes--green will not adjust in customer menu--it determines geometry and is only adjusted in the TECH menu.
Also, this set requires any convergence adjustments to be done in 480 and then in 1080--if only adjusted in one mode the other will still be bad.
Let me know if you know how to adjust in TECH menu or not--with exact model number I can tell you how to get there.
If this helps you rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
My picture suddenly has "ghosting" or "Shadowing." Cable is fine in the other room and I also tried the picture through my dvd. same thing.I tried the touch focus but this did nothing.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 17, 2009 | Toshiba 42H83 42" Rear Projection...
55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Oct 01, 2009 | RCA HD52W59 HDTV Projection Television
I have a Mitsubishi HD 1080 42" and the pictures has a yellow shadow on the right side of the tv. also yellow and green shadows
Your television needs convergence adjusted. Seek your owners manual to do this.
If you need help locating it, let me know.
Jan 19, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
135 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
