Question about Dishwashers
Broken Glass in Kenmore 15685 & can't remove Wash Impeller Screw
Hi! Can Anyone Help Me?!
I have a Kenmore 15685 dishwasher, and I broke a big glass pot lid in it today. Thousands of shards immediately gravitated into the little crevices between the vents and screen of the filter.
It looks like I could shop vac the glass out pretty easily & thoroughly, if I could only get the filter assembly off! It's bolted in there by what looks like one centered hex bolt atop a black rubbery-looking disc (maybe the top of the pump?), but when I try to loosen the bolt, it just spins--not like it's stripped or anything, but like it's spinning because that's what it's supposed to do when the dishwasher's running.
I'm really hoping this is something I can do myself, although my gut tells me this is some weird thing Sears has done to keep their service dept. busy. Hopefully I'm wrong. I've got houseguests coming in 2 days and I have to run the dishwasher constantly as it is!! Thanks!
  • hank1234 Dec 27, 2007
  • Anonymous May 14, 2009
    yes, and I am not sure if the screw is left handed or right handed, I also think there is a need for a spacial wrench to hold the big black washer in place so the center 1/4 hex screw can be turned loose.
Same problem here! Great!
Posted on Feb 28, 2008
We have the same problem!! Have you figured out the solution..thanks!
Posted on Dec 27, 2007
Broken glass
It is possible but it can chew up the chopper or impeller. If the dishwasher isn't washing as well as before it may need a new impeller.
Oct 04, 2014 | Dishwashers
I have a Kenmore Ultra Wash model 665 1373 and it isn't getting totally clean on the top rack - glasses and cups are almost clean but bowls etc are not, any ideas?
Check the shaft of the impeller, the plastic shaft might be broken, it was the problem with mine. To get to the impeller you have to remove the filter at the base of the diswasher and after you will see the screw that hold the impeller assembly in place, unscrew it and you will see right away if it is broken, Good luck
Jul 16, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Whirlpool gold gu1200
Sounds like glass fragments against the pump impeller. This may jam the impeller and reduce water pump volume giving poor wash performance and possible inability to evacuate the wash tub. It will not go away and may cause the impeller to fail. Remove screens and get the glass out. Do not poke around with your fingers unless you like cuts.
Sep 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Can't get screw loose on Kenmore dishwasher(665.1559579)impeller.
try it by using a high torck screw driver then the direction for loosening the screw is anticlock wise.
Jul 06, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Bosch dishwasher wont drain. At end of cycle is full of cloudy water.
It is possible if you have broken a glass recently that the piece of glass has made its way to the drain pump impeller. You need to remove bottom basket. Remove the filter strainer clamp by rotating CCW. There may be another round filter under the strainer (depending on model). Then with a torque screwdriver remove one screw which holds the plastic pump cover on. Remove the pump cover and pay close attention to the pump impeller. Does it rotate by finger movement? If not it could be jamed with a piece of broken glass. You must remove any obstruction to allow the impeller to turn. I usually force a paper towel piece (half piece while rotating the impeller by finger to allow the paper towel to bring up any obstruction below the impeller) Reassemble the cover and filters carefully and make sure the final strainer clamp aligns correctly with its marks. This insures nothing will make its way to the impeller in future.
Regards Sam
Jun 15, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Motor just hums during the wash cycle. Put it in
OK, that piece of glass may have jammed the wash impeller. this will destroy the motor windings. you will need to gain access to the circulation motor asap.the impeller is attached to the motor that is housed within the pump casing(upper). try to manually move the impeller. if its stuck, try ot remove the obstruction.
It is possible that, the motor is already damaged to the point of no return. in this case, replace the circulation motor. your drain pump should be ran by a totally separate motor(wax).
**NOTE
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Jun 09, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
My kenmore elite 766451297 sounds as if the arms are not turning also the dishes are dirty at the end of the cycle
Depending on the age of the dishwasher, worst case your wash pump motor is failing (and will soon fail completely.)
But try this first:
-Check the all wash arms and unblock all holes that are blocked.
-If that does does not help., with a screw driver, remove the screws that holds the filter / shroud to the dishwasher base (under the lower wash arm, which must also be removed.)
-Take digital pictures of each step so you can put it back together.
-Rinse everything that has been removed, especially the filter.
-Inspect with a flashlight the whole sump area, remove all debris (watch out for broken glass!)
-Inspect the impeller to make sure it is not broken and is properly connected.
-Reassemble and test.
If this fails, the motor mention above needs to be replaced.
Apr 17, 2009 | Kenmore 76602 / 76604 / 76609
Dishwasher was making whirliing noise during wash, now no wash, only fill and drain
there is a #10 torx screw holding that cover down.do not drill it out. after you take it off you can tell if the chopper is broken.be careful for broken glass.
Oct 17, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher problem
try taking the drain pump off, easy job just tip machine back remove 3 screws from front of base then remove the single screw from pump and twist to remove check impeller is free to turn chances are its not and is probably jammed with broken glass or sweetcorn the two most popular culprits, remove this by either moving the impeller with a screw driver or split the pump using 3mm torx bit, reassemble in reverse order and your sorted.
Oct 22, 2007 | Dishwashers
Dishwashers Logo
299 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
