Question about Polaroid PDV-0700 Portable DVD Player
Audio..Black Screen? I got this player, about a year and a half, my sister was watching something, and dropped it. It works..meaning the audio and sound, but the screen is black, except if you tilt it, you can just see a little bit of what is playing..It's completely fine besides that..I'm wondering if you can help..thanks so much
On this dvd player the screen stoped working and it will not charge what do i do
Posted on Apr 25, 2008
  • 61 Answers
Either the backlight tube or the board that drives is broken, probably the tube - it's a cold cathode fluorescent, usually along the top or bottom of the screen. It may be fixable, but probably only worth it
if you DIY and can get replacement cheap enough. They can be a real pain to get to, usually cheaper to get a new player.
Posted on Dec 13, 2007
Black screen - audio works - hp logo on start - then goes black
It is either the power supply or the backlight inverter board finally failed. You will need to do some voltages checking inside, also see if you can see any bad caps in the power supply.
See my troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Parts: www.shopjimmy.com
Jun 15, 2010 | HP LC2640N 26 in. HDTV-Ready LCD...
When i put a dvd in the disk drive it only plays the audio. the video screen just says something like ''warning dont drive while watching video'' this happens all the time even if im in park.
You have to bypass the parking brake arrangement, which usually means just wiring that wire (it's the one the manufacturer wants you to have connected to the handbrake, Pioneer uses a lime green color) to the black ground wire. This works with most, but I have noticed that newer models work around that so you may need some sort of bypass toggle switch.
Oct 04, 2009 | Car Audio & Video
MVOHD80 Liquid video car DVD player has audio, but no picture
THAT MEANS UR TUBE IN THE SCREEN IS FRIED, IF SO U HAVE A FACTORY WARRENTY, NOW WOULD BE A GOOD TIMER 2 USE IT
Mar 20, 2009 | Car Audio & Video
Toshiba 61H70
Does it look like a 3D image?
Would you be able to post a picture of the TV with the mention lines?
Aug 16, 2008 | Toshiba 61H70 61" Rear Projection...
Half of the screen goes black
the light engine is defective and needs to be changed..this set is not that old..contact mitsubishi customer relations to see about having it done under a customer accomodation, as they have had a lot of problems with the engines
Nov 28, 2007 | Mitsubishi WD-73732 73" Television
Picture flicker
B board = Part # A-1302-209-A fix by substitution......
check price and availibility..............B is a sister board mounted
to the A board (signal)........................................T.
Aug 14, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Half a screen
The picture on your TV screen is driven from the center to the top and bottom of the screen by the vertical drive circuit. The fact that you can see the entire picture means you have a problem called foldover. This is caused by a failure in the vertical drive circuit where the vertical saw signal is altered by a component failure within the vertical drive circuit. You cannot solve this problem but any good repair shop should be able to correct the problem at a reasonable cost.
Jun 22, 2006 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Polaroid PDV-0700 Portable DVD Player Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
