Question about PC Chips P23G Motherboard
Onboard lan??? hello i have vista x34 bit and i tgried to find my onboard lan but i can fine any idea???
  • Anonymous Apr 19, 2008
    xp pro does not see the on board ethernet adapter and i can't find the enable/disable setting for it in the american megatrends bios where it is supposed to be per the p23g bios manual. next to the moden enable/disable. it is missing. i get a green light on my ethernet connector and this ethernet connection has worked for years on this mother board. i don't know why it would stop working all by itself.
    Genius:
  • 1,601 Answers
Just installed a GA-PP67A-UD4-B3 mother board because the GA-P67A-UD4 board was dfective. I am running Windows 7, 64 bit. The new MB was a replacement provided by the manufacturer. Now, the Realtek...
Please enter into the BIOS settings and verify if under Integrated Peripherals the setting for Onboard H/W LAN is Enable. As additional step select SMART LAN and see if it will detect you cable lenght and Etehrnet speed. If Smart Lan do not detect anything or you have a bad onboard LAN or the cable, hub, router has a problem.
If SMART LAN will successfully report back some information it means that the issue must be with Windows 7. If it's the case i suggest to completely remove the network card, reboot and re-install the drivers.
Please let me know if you need additional help.
Mar 19, 2011 | Intel Motherboard
ASUS P5KPL-AM SE Motherboard no land card
Make sure you have it Enabled in the Bios (from page 2-17 of the user manual):
2.4.5 Onboard Devices Configuration
Onboard PCIE 10/100M LAN [Enabled]
Allows you to enable or disable the onboard LAN controller.
Configuration options: [Enabled] [Disabled]
LAN Option ROM [Disabled]
Allows you to enable or disable the boot ROM in the onboard LAN controller. This item
appears only when the Onboard LAN item is set to Enabled. Configuration options:
[Disabled] [Enabled]
Sep 08, 2010 | ASUS P5KPL-AM SE Motherboard
Multiple networks appear after reboot on lan desktop. OS is Vista Home Premium 32 bit with DIR615 router. I have to disable and enable lan network in order to get rid of the Unidentified network and enable...
the reason could be the networks scanned by your wireless card when it starts up. What you could do is go to select your preferred netwrok and bring it to the top of the list . ( In the wireless configuration utiity ).
Thanks Ranjit
Jan 05, 2010 | D-Link DIR-615 Wireless Router
I have onboard lan windows 7 say the adapter or driver is not installed. This was working fine with xp
windows xp is a entirely different engine then vista and win7 you need to goto EG's website aqnd get the newer drivers
Dec 05, 2009 | EliteGroup GeForce 6100SM-M Motherboard
VIA KT400 Chipset Driver update fried my ATI Radeon 9550 AGP Card
AGP is a bit old for win7, i'd drop it. that said, if the ati card is an addin perhaps your onboard (via) chip is causing the problem. turn it off in your bios so that the install never even detects it and use drivers from ati.
Jun 09, 2009 | ASUS A7V8X- X VIA KT400 ATX AMD AUDIO LAN...
I need 915 gavl intel chipset driver for vista
hello..try here....(www.downloadtube.com/Drivers/SOUND-CARD/Download-Freetech-PF12-ALC-650-sound-driver.html)..Thanks
May 10, 2009 | Intel D915GAG Socket 775 Motherboard -...
Onboard LAN detected , drivers properly installed but not responding
The Problem is in your onboard LAN, get PCI LAN card, plug into your PCI slot, install the driver of that PCI LAN Card..
Apr 27, 2009 | Computers & Internet
Dont have motherboard cd,m not able to find LAN Drivers on net
You have 2 choices. 1. Call Intel tech support & see if they can find a solution for you or 2. Install a standalone ethernet/wireless card, depending on your setup and disable onboard LAN. I had to go the 2nd route as my onboard LAN wass not compatible with Windows Vista. Hope this helps.
Dec 24, 2008 | Intel D845GLLY Motherboard
I disabled the lan and when i enabled it again it won't work
Hi, well now you have windows registry confused. The PCI card may have come with software & you installed it. (See if its listed in add/remove programs & uninstall it), than go to this link & download the free software to clean your registry. (Keep the onboard lan disabled in the bios).
http://www.pctuneuptips.com/recommends/clean/?gclid=CL2RiIrTmpICFSFMGgodODIPzg
When the program finishes close the program & shut down the system. Than boot the system & enter the bios. Enable the onboard lan. Save & exit. With any luck windows will see your lan & ask for the software. You can use the CD to guide windows to the lad driver software or you can download it from ECS. The online lan may be a bit newer or may not be. Click here to go to ECS web site:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=474&DetailName=New&DetailDesc=915G-M%20%20(V1.0)&CategoryID=1&MenuID=82&LanID=0
If you are running XP install through windows device manager.
Run into trouble, just let me know what the trouble is & we'll go from there.
Mike
Sep 28, 2008 | EliteGroup 915G-M Motherboard
Problem with the LAN Ethernet NVIDIA
right click on taskbar network icon and click disable
Mar 13, 2008 | ASUS P5N-E SLI Motherboard
PC Chips P23G Motherboard Logo
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
