Question about Compaq Armada M700 Notebook
101 i-o rom error
Hi there my laptop refuses to boot up and i cannot get into dos, i am getting the 101 i-o rom error and one long beep and one short beep. i do not have a floppy disk drive - just a cd on it any ideas how i can get this boot up again and how i can fix the problem?
thanks
oakvillecub@yahoo.ca
  • 3 more comments
  • oakvillecub Dec 18, 2007
    yep it did not work, gets to the "red compac" screen with the fault prompt same as usual.
  • oakvillecub Dec 19, 2007
    I disconnected the card from the bottom as you recommended and it worked! thanks so much for the advice, well done!!!!
  • Rouen Jan 12, 2008
    My 101 I/O ROM error message is accompanied by one beep and appears after the red Compaq screen. I more or less manage to get round it by using Control-Option-Delete and forcing the start-up with rapid use of these keys just before the error message appears. Sometimes I shut down and disconnect printer, power and USB hard drive. Each successive start-up takes more time, however, and it looks like I'm running out of time...
    Henry
    ferguson.henry@swissonline.ch
  • sulu2811 Apr 18, 2008
    In Armada 700 Compaq Laptop Processor Fan is not working. so, i hv opend it and replaced that fan ....after that my laptop is starting and gives two beeps and show compaq starting screen and gives me error 101-I/O Error and ater 2 lines it give me 162 system option net set
    so, plz give me solution what to do
    Thanking you
    President:
  • 4,402 Answers
Remove the memory chip and try
Posted on Dec 17, 2007
  • Cary Farah
    Cary Farah Dec 18, 2007
    removed the modem/LAN-card from underneath its
    cover.
    Just remove the two screws the
    cover is fastened with, then gently easy up the inner side of the card
    which is set in the slot, then remove the two cables connected to the
    card, and voila... you're done...
    if that doesnt work
    My suggestion is to remove everything CD Drive,
    battery, extra RAM, hard drive and see if it boots if it does add
    components one by one and see if the error returns put them back in in
    this order:
    hard drive
    battery
    CD drive
    Problem Solver:
  • 5 Answers
Sounds like it could be a connection problem. sometimes when items like the keyboard connector or cd rom connector get dirty it doesnt work properly and the bios cannot detect it correct.
Posted on Apr 19, 2008
Thanks so much i will give it a shot, i think i may have caused the problem when i tried to use the "install new hardware" on using a direct internet connection to my intranet jack so perhaps that may just solve the problem.
Posted on Dec 18, 2007
I will give it a shot and let you know, thanks.
Why does my pc beeps 4 times and will not boot up?
Sounds like you mother board is the problem.
Did you drop it, add memory.......
1 short DRAM refresh failure CH000996
2 short Parity circuit failure CH000607
3 short Base 64K RAM failure CH000996
4 short System timer failure CH000607
5 short Process failure CH000607
6 short Keyboard controller Gate A20 error CH000383
7 short Virtual mode exception error CH000607
8 short Display memory Read/Write test failure CH000607
9 short ROM BIOS checksum failure CH000607
10 short CMOS shutdown Read/Write error CH000239
11 short Cache Memory error CH000607
1 long, 3 short Conventional/Extended memory failure CH000996
1 long, 8 short Display/Retrace test failed CH000607
Jun 16, 2014 | IBM Computers & Internet
Starding beep sound problem
The below beep code may help you to understand your problem
Beeps
Error Message
Description
1 short No error System is booting properly 1 long, 1 short BIOS ROM checksum error The contents of the BIOS ROM to not match the expected contents. If possible, reload the BIOS from the PAQ 2 short General error Unknown 1 long, 2 short Video error Check the video adapter and ensure it's seated properly. If possible, replace the video adapter 7 beeps (1 long, 1s, 1l, 1 short, pause, 1 long, 1 short, 1 short AGP video The AGP video card is faulty. Reseat the card or replace it outright. This beep pertains to Compaq Deskpro systems 1 long neverending beep Memory error. Bad RAM. Replace and test
1 short, 2 long Bad RAM Reseat RAM then retest; replace RAM if failure continues
Aug 08, 2012 | Compaq Computers & Internet
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
101 I/O ROM Error for Compaq E500
if you are sure there is one long beep and one short beep then it is a hardware issue most probably motherboard issue or else video card issue. get it inspected by a technician there.
Aug 08, 2009 | Compaq Armada M700 Notebook
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
Problem booting
Any beep code from pheonix starting with two beeps relates to ram issues. If you have treid swapping the ram and it only gives the first 2 beeps then most likely the RAM controller on the north bridge or the data channels themselves are damaged on the motherboard.
You can try running a single chip of ram in each slot at seperate attempts. If it is a data channel damaged this will bypass the problem although it will cripple the laptops performance. Either way, the only permanent and proper fix would be to replace the oBo which I doubt would be cost effective on this unit.
Chris
Jun 02, 2009 | Gateway Solo 9500 Notebook
Blank sreen after bios update
Update BIOS with Boot Block Error Code/Beep:
Definitions Error Beeps Error Code (Port 80H)
BIOS updated successfully. 2L-1S-1L F1h
The BIOS file size is not equal to the BIOS ROM size; wrong BIOS file. 1L-1S F1h
The BIOS file can't be read; it is defective. 1L-2S F2h
The model ID is mismatched; wrong BIOS file. 3S F3h
The BIOS ROM has failed to be erased. Try to flash again. 2L-1S E1h
The BIOS ROM has failed to be programmed. Try to flash again. 2L-2S E2h
No diskette, or cannot locate the BIOS file.
Try to use a new formatted diskette and copy the BIOS file again. 2S D1h
Mar 27, 2008 | Acer Aspire 1640Z Notebook
COMPAQ M700 ERROR 101 I/O ERROR
Computer Post / Beep codes Beep Code. Description. Document. 1 long, 2 short, Indicates a video error has occurred ... One Long and Three Short Beeps.
Good Luck, please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
1,197 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
