Question about Carrier XHD183D Air Conditioner
Carrier XHD183D Through-the-Wall Heater/AC runs constantly
My Carrier XHD183D has started running constantly on heat or air conditioning, regardless of the thermostat setting. Sometimes, turning the thermostat dial back and forth a few times will start it cycling normally, again. When it runs constantly, turning the dial up or down does not produce the audible click that normally results in the unit starting up or shutting down. Do I need to replace the thermostat assembly?
  • Anonymous Mar 13, 2014
    I have a carrier window unit air con and the unit shuts down periodicly an it show CF on the control unit. Before it will start again I have to unplug it and then plug it back in.
    Problem Solver:
  • 9 Answers
YOU COULD EITHER HAVE A THERMOSTAT PROBLEM OR FAN CONTROL PROBLEM.TURN THE POWER OFF AT THE FURNACE AND TAKE THE THERMOSTAT OFF THE WALL.MAKE SURE YOU MARK THE WIRES SO YOU KNOW HOW TO HOOK IT BACK UP AGAIN.RESTORE POWER TO THE FURNACE.TOUCH THE WIRES THAT WERE HOOKED TO THE R & G TERMINALS ON THE T-STAT TOGETHER AND HOLD THEM THERE.OBSERVE THE OPERATION. WHEN YOU TAKE THEM APART DOES THE BLOWER STOP?TRY IT A FEW TIMES. IF IT CONTINUES TO START AND STOP YOU GOT A BAD T-STAT.JEFF
Posted on Dec 15, 2007
Need wire diagram for carrier ac/heat model xhd183d
May find one on Google images, worth a look
Dec 14, 2016 | Carrier Heating & Cooling
What is difference between on an auto on thermostate
I'm not sure exactly how this applies specifically in a car, but on a home heating and cooling (air conditioning) thermostat, it is often associated with the fan or blower setting.
If for a system fan:
"Auto On" setting in a heating / cooling system would start the fan when the temperature climbed above or dropped below the setting you on the thermostat and start the heat or cooling source. Once the thermometer indicates the desired temperature had been reached, the heating / cooling source would be stopped and the fan would turn off.
"On" would run the fan all the time, regardless if the thermostat tired to start the heat or cooling source. This would result in constant circulation of the air in the space(s) and tend to keep warm or cool spots (rooms) from being created.
Nov 30, 2015 | Cars & Trucks
An air conditioning technician told me that my Carrier XCB183D (9 years old) needs to be replaced (not cooling sufficiently) but that model is no longer available. Is that true?
Thats very likely, they update and come up with more efficient units and discontinue the older models.
The compressor will lose effieciency over time.
Jul 28, 2011 | Carrier XHD183D Air Conditioner
My honeywell heater thermostat is only blowing cold air, there is no heat blowing regardless of setting. how can i fix it? it won't even turn off.
the wiring for thermostats are color coded. R(red)power, Y(yellow)cooling, G(green)common, W(white)heating. O(orange), E(emergency)heat. Make sure that you have the right thermostat because there is an air condition thermostat and there is a heatpump thermostat and they wire up differently.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
Problem with new Carrier Infinity 96 gas furnace
carrier infinity 96 furnace went to turn down the thermostat and their was no power to it and the furnace doesnt run
Nov 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
My problem is in addition to moisture near some duct outlets the thermostat always go 2 degrees below the set limit .I also have a carrier infinity system installed only 1 yr, had the problem from the...
if you have a mercury thermostat and it is not leveled properly it will turn the temperatyure on and off by a couple of degrees
some thermostats have the capability of running the unit longer than the set temperature
i would recommend calling a local heating and air conditioning contractor and get the unit cleaned and bring up the issue then
Aug 04, 2009 | Heating & Cooling
I have a carrier heatpump model 38Q130300 when I turn the thetmostat to run the fan the heat comes on and stays on until I turn the fan off. Any Ideas. Thanks Doug
suggest starting with thermostat replacement only because it sounds as if the fan/heating control has constant power.
good luck
Dave
Jul 16, 2009 | Heating & Cooling
Furnace runs constantly since blower motor was replaced
Sounds like they wired it direct to line voltage , it should run through a sequencer or fan relay to cycle on and off , your seq./relay could be stuck closed to but unlikely being it was just repaired , call the service company back before you do anything they are responsible.
Apr 11, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier XHD183D Air Conditioner Logo
467 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
