Question about Honeywell Cool Moisture 3 Gallon Humidifier
The water refill icon keeps blinking, but the humidifier is full
I tried to turn on the humidifier, filled the tank, placed it on the unit, and the flashing drop icon indicating that the water bowl is empty keeps blinking and the unit won't turn on. I have moved things around, unplugged it a few times, but same problem when I plug it back in.
Any thoughts???
  • 4 more comments
  • Anonymous Dec 30, 2007
    I'm having the same issue...how do you check the water sensor?
  • Gubbs Jan 01, 2008
    I have the same problem with both of my Honeywell's. And I respond to Solution 1 in the same manner - where is the water sensor?
  • Anonymous May 24, 2008
    Same problem. Clueless about where water sensor is
  • Kerarm Nov 18, 2008
    Hey, I am having the same problem. Did anyone ever find our where the water sensor is?
  • 1962pv544 Nov 24, 2008
    I have the same problem. Has anyone found the water level sensor?
  • allans1949 Nov 26, 2008
    It was running without a filter...That I discovered after my wife said the water source wasn't disappearing quickly enough...DUH. I don't know the model # so I bought a "filter" and had to cut a few inches off so it would fit. It doesn't fit perfectly but the cover goes on easily. All I am getting is a flashing icon. Is the filter the problem?
If you look around the unit there should be a # to call. I called 1-800-332-1110. They will send you a new one if you send yours in. Have the model # ready. Try cleaning the crud from the heating element first and if that doesn't work call them up and get a free replacement! That should do it.
Posted on Dec 17, 2008
  • 625 Answers
Have you checked the water sensor?
Posted on Dec 13, 2007
Idylis #0484756 unit shuts off tank emply but take is full
Just purchased a Idylis model 0484756 and it has no
operators manuel. Is there one available?
Where?
Thanks
Jan 20, 2014 | Humidifiers
I HAVE A vICKS VAPORSIOR AND HAVENT USED IT VERY OFTER THERES no STEAM COMMING OUT EVER I USE COLD WATER DON'T FILL ABOVE THE FILL LINE I ALSO CLEANED IT REALLY GOOD WITH CLOROX. aNY SUGGESTIONS???
The unit may simply has a calcium scale build up and it's blocking the water passage. To clean it, empty in water remaining in the tank. Mix a 50/50 solution of White Vinegar and Bottled Distilled Water and fill the tank. Allow it to soak for at least one hour, then turn the unit ON. Place you hand in front of the misting nozzle to see if it's working. If you don't feel any mist, turn the unit OFF and allow it sit over night. If you do feel mist, allow it to run until the tank is 3/4's empty Turn the unit OFF, pour out the remaining solution and refill with Bottled Distilled Water. Run the humidifier until it's empty. This will flush the system entirely. In the future, I would recommend you use Bottled Distilled Water, instead of Tap Water. If you do, you won't have to descale the unit any more.
Hope this helped you, please let me know. Thanks.
May 16, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I turn the humidifier on l or ll. The light is grean but it is not releasing steam or anything. I don't hear a noise and the water level stays the same.
The humidifier may be clogged with a calcium scale build up. Especially, if you use well water or your municipal water supply has a high chemical content.
To solve this problem do the following. Mix a 50/50 solution of White Vinegar and Bottled Distilled Water (enough to fill the tank). Empty any water that is currently in the tank and fill it with the 50/50 solution. Allow at least one hour, before turning the unit ON. After turning it ON place you hand in front of the mist nozzle to see if any mist is being generated. If it's generating mist, allow it to run until the tank is 3/4's empty. Then turn the unit OFF, unplug it and empty the remaining solution. Refill with Bottled Distilled Water and run until the tank is empty.
If the unit did not produce mist after one hour of soaking, allow it to set over night and then follow the procedure above. Generally, an overnight soaking will do the trick. In the future, I recommend using Bottle Distilled Water rather than your tap water.
Hope this helps you solve the problem. Please let me know. Thanks.
May 16, 2011 | Vicks Warm Mist V745A 1 Gallon Humidifier
WATER LEVEL FLOAT DEVICE PREVENTS UNIT FROM TURNING ON,EVEN THOUGH WATER TANK IS FULL. REMOVED SOME FILTER MATERIAL WITH NO EFFECT. FLOAT IS FREE WITH NO RESTRICTION.
These hints are from the air o swiss webpage.
Q: No mist / unit is not working / empty indicator keeps flashing
A: Fill up the water tank. Check if water is flowing through the demineralization cartridge (attached to the water tank cap). If the water tank is full but there is only little water in the base it indicates that the water is now flowing through the demineralization cartridge.
  • Wait for 15 minutes to allow the mist to come out of the unit.
  • If the unit is not working and the empty light is not flashing you might have set the desired humidity too low and the current humidity level in the room is higher. That is why the unit switches off automatically.
  • If the empty indicator continues flashing and the tank is full, water is not flowing through the cartridge. Exchange the cartridge or the granules in the cartridge after 2-3 months, in areas with hard water exchange the cartridge after 1 -2 months. However, the demineralization cartridge and or the granules must be exchanged at the latest after 6 months or the unit does not reach its full performance.
If the granules are new, see the following instructions:
  • Make sure the cartridge and/or granules were soaked for 24 hours, water takes longer to filter through dry granules in cartridge and into the base. Next, remove 2 tablespoons of granules from the cartridge, and throw them away. Too many granules in the cartridge it does not allow water to flow from the tank to the base.
If your issue is with the float and not the mister, then you have to make sure the float is tripping the micro switch that turns the machine on. Some units the filter will not allow the float to hit the switch if the filter is not installed correctly. If everything is in correctly and the float is tripping the switch, then the micro switch must be faulty.
Apr 04, 2011 | Swiss AIR-O-SWISS Ultrasonic Humidifier -...
I tryt to turn on my humidifier tonight.1st the mist was coming out just little bi,but there was no green light on,like the manual sed and the humidifier was making some wird noises too.
Welcome to Fixya!
  • Ensure that the water tank cap is secured properly to water tank.
  •  Empty out water in water basin. Place filled water tank on to empty water basin.
  •  Clean Water Level Sensor.
Hope this helps!
Oct 26, 2010 | Crane Elephant EE-3186 1 Gallon Humidifier
The unit is two years old, and we didn't use it last winter, because it was so mild. Now, I plugged it in, and I get an icon similar to a "water drop in a bucket." It flashes, and the like-new unit will...
The humidifier may have a water level sensor and since it was idling for a year it may have got stuck down indicating no water. Remove the tank and look for a float type sensor.
Jan 10, 2010 | Honeywell Cool Moisture 3 Gallon...
No instruction manual
FILLING THE WATER TANKS
1. Before filling the water tanks, push the POWER switch to the “OFF” position and
unplug unit. Refer to cleaning instructions.
2. Remove water tanks from base, turn each tank upside down and remove tank cap
by turning counterclockwise. Fill tank with clean cold tap water.
Replace the tank cap by turning clockwise. Tighten firmly.
3. Carefully pick up tank, since it will be heavy when full, and slippery if wet.
4. Place water tanks on base. Make sure tanks are properly placed, otherwise, the
humidifier will not work correctly.
Feb 11, 2009 | Slant Fin Cool Mist GF-220 Humidifier
Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Sep 22, 2008 | Sunbeam Ultrasonic Humidifier
LEAKS
Try to just fill the tank with water and set it upright on a table. If it leaks, the tank is cracked and needs to be replaced. Order one at kaz.com (search using model#). I have had this tank leak if the special cap is not sitting properly on the base. Make sure that the steam tower is properly locked in place before you place the water tank in the reservoir. The cap on the tank has a spring release that has to be correctly lined up so it only releases water when the water level in the reservoir drops.
May 08, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
Venta 207 digital humidifier
Caring For Your Venta-Sonic Humidifier
IMPORTANT!
Always unplug the unit before cleaning!
When to Clean Your Humidifier
 Clean your humidifier weekly or more often during heavy use, depending on your
individual water quality. Clean your humidifier before storing and after long periods
of storage.
 When cleaning the inside of your unit, keep water away from the air outlet. Exterior
may be wiped with a damp cloth when unit is off and unplugged.
Cleaning the Oscillator and Water Sensor
 Turn off the unit and unplug power cord. Remove tank from base and empty
reservoir in base. Use cleaning brush provided in base to clean off mineral deposits
and sediment from oscillator and water sensor. Do not scrape or clean with tools
that have metal parts. Be careful to not damage the surface of the oscillator.
ATTENTION: Damage to the oscillator may cause the unit to not work properly.
 The oscillator (ultrasonic transducer) is highly sensitive. Keep this important part
clean and treat gently. Do not touch the oscillator while the unit is operating.
 Do not use soap, cleaning agents, detergents, or other chemicals for cleaning the
tank and humidifier.
 After cleaning fill water tank (see instructions above) and return tank to base.
Storing the Venta-Sonic
Switch off and unplug power cord from A/C outlet. Empty remaining water from base
and tank. Clean tank and unit (see for instructions above). Make sure all parts are
thoroughly dry—allow at least 24 hours to dry. Leave the filling cap of the tank
loosened. This will keep the cap and gasket from sticking together. Pack Venta-Sonic
in original packaging and store in a cool and dry place.
You can find your manual at this link:
http://www.venta-sonic.com/pdf/vs207manual.pdf
Good Luck.
Apr 03, 2008 | Venta VS 100 Humidifier
Honeywell Cool Moisture 3 Gallon Humidifier Logo
499 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
