Question about SanDisk Sansa e200 MP3 Player
Sansa e260 keeps connecting/disconnecting
My Sansa recently started to go between connecting and disconnecting. It only started to do this when I put it on MSC mode. Up until a few weeks ago, I was able to load songs onto it in MTP mode, but then the computer stopped recognizing it and kept asking me for installation software. So then I changed it to MSC mode and now it won't stay connected. I have two of these players and both of them do this in MSC mode and it's not the cable. Solutions? Advice?
  • khunkasem May 17, 2008
    my sansa keep on disconnecting and i cannot upload song to it....i tried to do it by open it on my computer but it said that the device have stop responding...however it only does this on my computer but not on my brother who have window vista
Start by updating the firmware to the latest version. You can get the firmware updater (you will have to do this on your brother's computer probably) online at sandisk's site. Then, check back in after you've done that-sometimes more problems arise, sometimes problems are fixed.
Posted on May 17, 2008
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
Sansa e250 won't connect
1.try formatting your sansa
2.try to copy again..
3.if it does not work tell me what sansa you are using
May 23, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260
go to www.sandisk.com, and then just keep following the links for mp3 players, support; or go to:
https://www.customernation.com/pls/ps/ps.ps_main?p_host=304&p_supplier=5096&p_parm=PSHPP
they did redesign the website recently
May 08, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 mp3 player
my e260 sansa mp3 player dont recognized by computer what to do
May 06, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e-260
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 04, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 won't connect to my computer
see if thers a firmware update for it do windows update run ccleaner tool get out junk in computer may clog it up go to ther web site and download ther latest software and updates cheak for firmware updates ok uuiseing usb 2.0 ports also
Jan 25, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260, with Rhapsody. Sansa turns on, off, on, off continuously
Uninstall the MTP device in your hardware device manager, or remove it using add/remove hardware in control panel
Then:
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Oct 16, 2007 | SanDisk Sansa e260 MP3 Player
SANSA E260 problems!! HELP!!
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Feb 21, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
442 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
