Question about LG DBRH197H DVD Player/HDD Recorder
No audio on tv channels but perfect on DVD playback etc
Hi, very weird porblem, have hooked up the recorder to an LG plasma TV model 42PXDV-AA after having it already installed on a normal analogue TV and working properly. now we have perfect audio on DVD playback and even on stuff on the HDD recorded earlier, but just a squeaky clicking sound on the digital channels and no audio on analogue channels and even freakier when we record something and playback, it plays audio but like its really fast chip monk style and the picture is like still photos, has to be some stupid setting not right hey, but we've tried every thing. i know i had to set it to 576i for the analogue TV but cant remember how to change this setting and the manual is'nt helping appreciate any advice!!!
LOok there is no such thing as anologue anymore . The old anologue channels are now set on digital. So in menu set everything on digital & then do a auto search again
Posted on Apr 26, 2017
    New Friend:
  • 4 Answers
This looks very much like a problem I once 've had (and later found the solution by accident). When you go into the menu of the remote control and press the "automatic channel search" function you can always specify from which "source" the signal is arriving either 1, from antenna, (ie. over air) or 2, from cable or 3, from satellite. Then the decoder searches and finds a bunch of station in its reach. Once (while hooked up to an antenna) ,I had accidentally made it do the station search under the "cable" header instead of "antenna" and it found the same stations as the one's I've had before,(over antenna) but some stations suddenly had no more audio. Because I was unaware that the set was programmed under the cable header I could solve this strange mystery only much later when I reprogrammed it one day and it searched the stations under the Air-Antenna header, then suddenly all the stations were coming in properly, with good image and full audio. ------If this doesn't solve your problem then search under the menu of your set if at another part of it you can specify some other similar options like Antenna-Cable choice. I'm quite sure its easy to correct. good luck Alex
Posted on Apr 09, 2017
5 Suggested Answers
  • 619 Answers
SOURCE: LG 4912 using with a new digital TV
in order to solve the complect of channel/ choose one / if tv is digital in line w/dvd is digital.
If your your recorder is analogue choose use analogue channel.
Posted on Jan 03, 2008
SOURCE: No sound from LG HDD DVD recorder
Same Problem here, have not done anything yet, but I am convinced that it is due to blown Capacitors in the Power Supply......
Posted on Oct 11, 2008
  • 909 Answers
SOURCE: how to record digital tv thru reocrder
You need to go into the menu and set the "av-2 out put" to DTV, that should solve the problem, remembering to connect the "in" scart on the recorder to AV-2 on the tv.If there is only 1 scart on the recorder it will be a 2 way connection, sending and recieving a signal.
Posted on May 29, 2009
SOURCE: G'day, I have an LG HDD/DVD
You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
Posted on May 26, 2011
How to hook up to panasonic tv & sony dvd player
DVD output (HDMI) to HDMI input on TV will transfer both audio and video from DVD to TV. Audio output on TV to unused Input on Yamaha receiver (Aux, CD, etc.). This hookup will allow DVD and TV channels audio playback through your Yamaha receiver. Remember to test any/all new hookups or connections using minimum settings (volume, etc.), and bring up levels slowly for the initial testing.
Mar 31, 2015 | Yamaha HTR-5930 Receiver
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
Im having problems hooking up thru vcr/dvd player
The correct setup depends on whether you have a cable/satellite receiver and whether you want to record to and playback from the VCR. If you are using a cable/satellite receiver, this needs to be connected to both the TV and the DVD/VCR if you want to record. The DVD then needs to be connected to the TV via the video and audio out sockets on the back of the DVD/VCR for playback.
I can let you know exactly which connections to use and where they should all go, but I need to know the following details as otherwise I don't know which sockets/connect you have available.
1. Brand and model number of TV
2. Brand and model number of DVD/VCR
3. Brand and model number of any cable/satellite receiver if you are using one.
Please confirm these details and I will try to assist you further.
Regards,
BElectric
Dec 16, 2010 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Sony bravia-unable to tune in video channel via dvd
thethe wires have to run out of your cable box into the dvd recorder then back out to the tv,try rehooking it up
May 19, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Recording from LG 42pc1dv plasma tv to LG v782w VCR
If it does this on all channels then the video on your AV out from the TV is bad.
If it only happens with some channels then this is Macrovision protection working which will not allow you to record premium channels and any that are using this protection.
Aug 10, 2008 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
I am having problems hooking it up to an HD Receiver from Direct TV
playback and record are 2 different things. playback, you connect the DVD player audio-video OUT to the audio-video IN of the TV. recording, you connect the DVD player from the audio-video IN to the audio-video OUT of the source (i.e. cable box, set-top box, etc) hope this helps!
Oct 29, 2006 | Samsung DVDR120 DVD Recorder
LG DBRH197H DVD Player/HDD Recorder Logo
125 people viewed this question
Computer Repairing
Computer Repairing
