Question about Dell A940 All-In-One InkJet Printer
Aaaaaaaaaaaaaa!!!!!! can't get the black inkjet to work properly. it is making white blocks evenly spaced through out my papers. i had previously just fixed a c502 error. could i have knocked something out of place?
  • Anonymous Mar 04, 2009
    in a page of text lines are omitted in two different parts of the page. new cartridge installed recently.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 74 Answers
Bring it back to where you got it fixed and let them know that they did not properly fix the printer. DO NOT PAY ANYMORE for them fixing it properly. Let me know how it goes.
Cynthia Charczenko
Posted on Jan 15, 2008
Canon PIXMA iP3000. I have completed a nozzle check, but have odd results... BLACK-Perfect CYAN-4 EQUALLY SPACED WHITE LINES...NO DROP OUTS PALE CYAN-PERFECT MAGENTA- 4 EQUALLY SPACED WHITE LINES...NO DROP...
Inkjet printers do not like being left unused for long periods.
Some of the color print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 17, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Loaded Visioneer Strobe XP 300 with PaperPort 11 on Win7 machine, but all scans come out black. Any ideas out there? Previously I had the same scanner working fine on an XP machine. Maybe there is an...
Did you calibrate the scanner on the Windows 7 machine? When you calibrate, a file is saved on the host computer - if you do not calibrate, everything is black.
In case you dont have a calibration sheet, I just uploaded one to FixYa - it will take a few days for moderators to review it, but then you can print it out on both sides of a single sheet of paper (so that the arrows are pointing at the same end of the paper, but on both sides of it) and use that to calibrate your scanner - make sure that you have 'edge to edge' printing turned on, as there cannot be any white space on the sides of the black space.
Aug 22, 2010 | Visioneer Strobe XP 300 Pass-Through...
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
The documents are faded even after putting in a new cartridge
  • make sure you are using inkjet papers as inkjet printers work on inkjet papers.
  • Lift the printer access door, then remove the ink cartridges from the printhead.
  • Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  • Close the printer access door.
  • Reprint the picture or document that had the quality problem.
  • if still light prints then proceed further
  • Print Test Page
  • Review the printed test page and verify that:
    • the left color blocks are gray, cyan, and black.
    • the right color blocks are magenta, yellow, and black.
    • each block is completely filled with color.
  • If no---> Clean Printhead, the On/Off light flashes during the cleaning procedure.When the On/Off light glows steady, print test page again.
  • If Yes---->The problem could be caused by the type of paper you are using.
May 28, 2010 | Kodak Office Equipment & Supplies
White lines on photo
Take the cartridges out, then take the print-head out and run it under warm water for a few minutes. You could stand it in a saucer of warm water if you like - just the nozzles . Dry it thoroughly - use kitchen town and then refit it into the printer. Put the inks back in and then do some test prints.
It might take 2 or 3 goes but it should clear the blocked nozzle(s)
Inkjets like to be used - it keeps the nozzles clear.
Dec 31, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
My HP 1280 printer does print black and white text
Could it just be that the black cartridge has run out? If not, try and clean the print heads. You should be able to do this in the printer options in Windows. It is more than likle that the black nozzle is blocked.
Dec 13, 2009 | HP DeskJet 1280 InkJet Printer
Black ink not working
Print out a test print to see what comes out. If the printer is printing the black and colour blocks then the printer should be OK. If not then check the black and colour inks to make sure they are OK and remove each of the cartridges and reinstall them. Then run a full cleaning cycle and reprint the test sheet. Keep doing this until all the inks are printing OK. Then run an alignment test making sure that there is plain white paper in the paper tray and adjust the printer as necessary.
Oct 07, 2009 | HP Photosmart C7180 All-In-One InkJet...
I bought new color cartridges, but the printer only prints in black and white or grayscale. Why won't the color show up?
check the print settings by going to printing preferences and check if the grayscale or black and white is the one that is selected
change it to color
also make sure that the color cartridge is properly snapped inside.
try printing a test page and see if all colors come on the printed page
let me know if you need any further assistance
Jul 09, 2009 | HP Photosmart 8050 InkJet Printer
Hi, I refilled my black cartridge and since then it starts printing but always comes up with error code 5200, it does not even put ink on the paper. I have tried all the usual tips like moistening the...
Have you put the black label back right. It will only work properly if you have the top near the 2 straight lugs. If it is down low near the curved lug then it will block the chip! Make certain that ink hasn't covered it up too.
Jul 07, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Dell A940 All-In-One InkJet Printer Logo
46 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
