Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Electric Kenmore Ultra Bake Oven
After we had a power outage our oven panel read "PF 5Ab". We have not been able to clear it and use the oven. The stove top works just fine but that is it. Normally after a power outage we just press the "stop/clear" button but none of the buttons are doing anything. Our Model is #665.95713300. Thank you for any help on what we need to do or fix!!!
  • 1 more comment
  • JenKell101 Dec 25, 2007
    Oh yes, same thing happened to us. The power went out and the stove has the letters PF which means power failure. In return it will not go off. But we can still use the oven and stovetop. Now our problem with this stupid stove is that it is in Celsius not Fahrenheit and the temperature will not stay at the request degree, it will continue to rise to about 600 degrees. No more Sears products.
  • Vnel Feb 07, 2008
  • Marsha Robinson
    Marsha Robinson Dec 23, 2012
    Kenmore Pro double oven with PF code. Turned power off at circuit breaker, which didn't work but when I set the clock, error code disappeared and oven worked.
  • 4 Answers
I finally found my manual to the range, and to change from celsius to fahrenheit press the BROIL button for 5 seconds. A tone will sound, and the temperature should switch to Fahrenheit.
As far as the code PF 5ab--it could be PF Sab which means the power went out during Sabbath mode. Try pressing and holding TIMER OFF for 5 seconds. If that doesn't work, then open the oven door, press STOP/CLEAR, press both the HOUR "up" and "down" arrow pad at the same time and hold for 5 seconds, "Sab OFF" should appear. Press START to accept the change, then close the oven door.
Posted on Sep 17, 2008
    President:
  • 1,314 Answers
Kenmore dont publish much on their ranges but listen somewhere on that range will be a technial data sheet some you pull the bottom drawer out and look on either side for a white sheet in a holder others are taped some are under the back panel if you have to get under that panel unpluf the range or turn the breaker off that sheet will give you speficis on that code and how to clear it it will also tell you how to change it to farenhiet but you owners should tell you that under that but if you have a cancel button try pushing that or holding stop clear for 5 secs by the way fyi kenmore is built by whirlpool and good stove i wait to hear
Posted on Dec 29, 2007
I have a kenmore ultra temp electric stove and the oven will not heat up. I had it set for 350 and it only climbed up to 177
Posted on Apr 02, 2009
2 Suggested Answers
SOURCE: I have a Kenmore Ultra Bake Stove, we had a power
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Posted on Feb 15, 2010
Kenmore ultra bake self cleaning super capacity electric oven is showing the letters pf in red what could this mean?
PF usually just refers to power failure. You should only have to reset your clock and then check to make sure everything else works.
Jun 15, 2015 | Kenmore Ovens
Why won't my oven let me set the temperature after a power failure?
Good Morning Annette,
I see that you are having trouble with setting the temperature of your oven on your range, model# FGB24S5A, after a power failure. I also see that you have reset your appliance by unplugging it and are receiving an error message of SAG or 5AB. I have looked into the model number that you have listed and it shows as a wall oven. I also do not show either of those error codes you have shown. If you can please get me the model number off your range, so I can better assist. The model number will either be right inside the oven on the back of the door or it may be located inside the bottom drawer. Looking forward to hearing from you.
WP
Apr 25, 2014 | Frigidaire FGB24S5A Gas Single Oven
PF code
Depending on manufacturer and model, PF can mean a number of things. On my stove, PF simply indicates "Power Fail" Yours may, too. You can clear this generally by updating the clock display. To verify that PF does indeed mean power fail for your stove, simply shut off the power for the cicuit than supplies the stove. This can be either circuit breaker or fuses. Turn the power back on after 5 or more seconds and if it displays PF again, you know it means power fail.
Otherwise, please provide the manufacturer and model of you stove for an answer.
Jul 02, 2012 | Ovens
What does the code 5ab or sab mean my cook top works but not the oven
amana oven reads SAb or 5Ab code? stove works, oven doesnt??? HELP
Aug 21, 2010 | Amana AOCS3040 Electric Single Oven
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Apr 16, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
Kenmore Ultra Bake Oven Won't Heat Up
Turn the breakers off and wait 10 minutes and then on.  If this doesn't clear the problem, you'll need an electronic timer module.  Electrical spikes cause problems like this.
Nov 17, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
5,211 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Mike
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
