Question about Panasonic Palmcorder PV-GS15 Mini DV Digital Camcorder
Dv port on camcorder dead!
My wife knocked over camera while it was connected to dv cable. Now computer will not recognize camera, I don't believe it is making proper connection. Is it possible to repair port on camera, or replace port on camera?
Most likely the dv connector is come of or loose connection.if you can resolder it will be fine, or you can take to somebody who can resolder it with SMD rework station
Gopal
Posted on Dec 13, 2007
How to connect canon gl-2 camcorder to computer
Are you using the proper Firewire cable to connect? Also, the GL2 has had issue with the Firewire port going bad. Try a different cable and see if that helps. It can't be a USB-Firewire cable either.
Sep 07, 2014 | Canon GL2 Mini DV Digital Camcorder
Hi, I have a JVC GR-D750AA digital video camera. I do not know how to download the things recorded to my PC. I have also bought the USB cable n tried but the camera USB port is not recogned by the PC. I do...
Turn the power switch on your camcorder to "Off." Connect the USB cable that came with the camcorder to the USB port on the camcorder. If you are using the DV cable, connect one end of the cable to the computer first. Put the other end of the USB cable into the USB port on your computer. If you are using the DV cable, connect it to the camcorder. Power on your camcorder. Wait while your computer recognizes the attached JVC GR-D270U camcorder. Typically you will get a pop-up on your screen asking how you want to proceed once the camcorder has been recognized. Open your video editing software, such as Adobe Premiere, Roxie, iMovie or Windows Movie Maker. Import, or capture, the video from the camcorder to your computer using the video editing software. For example, in iMovie you click on "File," then "Import from Camera" to download the movie from your camcorder to the computer.
Jan 13, 2018 | JVC GR-D275 Mini DV Digital Camcorder
I have a mini DV SONY DCR-PC9E PAL camcorder and i need to copy my tapes on my WINDOWS 7 Ultimate 32bit. Don't Have the Driver, and my computer is not reading the USB cable connected from the Camera to the...
I believe this camera has a firewire/iLink connector.
Using a firewire cable will allow you to not only transfer videos, but will also let popular video editing software control your camera for ease of use!
As for the driver, your camera is specific to latin america.
You might try to download this program which is a licensed sony product, but will be in spanish. It may have drivers built in, which will allow your pc to properly recognize your device in other programs.
Feb 23, 2011 | Sony Handycam DCR-PC9E Mini DV Digital...
My Sony Dvcam DCR-HC15E Mini DV Digital Camcorder is not being seen when I plug it into the USB port on my computer. I have downloaded a program called Driver Robot which is supposed to update my computer...
Go to camcorder Menu and enable USB Streaming option.
Computer / Windows will recognize camcorder and will install drivers automatically for further communications.
Thanks.
Sep 18, 2009 | Sony Dvcam DCR-HC15E Mini DV Digital...
I connect the IEEE cable (4 pin to 4 pin) to the camera and the computer and turn the camera to "play". The camera is not recognized by the computer.
Check the cable first. It's easy - put another one. If it works - change the cable. If Not - check the PC input by connecting another similar camera. If it works with another camera, then Your IEEE camera port is broken and needs to be repaired. And the order of connection must be: 1. Power off camera. 2. Put IEEE cable on it. 3. Plug another connector of cable on computer. 4. Power on the camera. DON´T TRY TO CONNECT A CAMERA IN A PLAY MODE, it probably can destroy Your camera IEEE port. Sincerely.
Sep 11, 2009 | Canon Elura 100 Mini DV Digital Camcorder
Can not connect mini dv to computer via ieee1394 cable - he is not recognize the dcrpc120e sony
Make sure that the camera and the computer are both turned off. Put camera in the playback mode and turn off.
Turn camera and computer on at the same time and open your editing software. The software should then recognize the camera. Press play on the camera and capture on the software screen at the same time.
Feb 25, 2009 | Sony DCR-HC30E MiniDV Camcorder
Can't get my computer to recognize the device
You may use different USB ports. Make sure your computer USB is v2.0 Computer's Bios and Chipset update could be a possible solution. You may also try Firewire/1394 Connection which is more reliable and faster for video editing and conversion.
Usually in professional use hook up the Camcorder directly to the computer is not very preferred, Using DV converters are more common such as Canopus products as you can find them on www.canopus.com
Nov 09, 2008 | Panasonic PV-GS250 Mini DV Digital...
NOt recognized
if your trying to download video usb won't work! must use firewire cable hooked up to dv port on cam and connection on laptop or tower called 1394-cable is either 4 pin or 6 pin-depends on computer- cam is always 4 pin-says dv on camcorder-usb only for still pics-use windows movie maker in xp or vista to edit
Jun 28, 2008 | Canon MV700 Mini DV Digital Camcorder
Unable to tansfer video to computer using DV cable..
Pinnacle software will recognize the camera installed through a firewire cable once the camera is turned on. Windows movies software doesn't recognize DV cameras. You may be able to get capture to work if you go to Microsoft.com and download the Windows Media 9.0 Development Kit. I believe DV input is a capture option.
There has to be a 3rd party program installed to get it to recognize it.
Good luck on that.
Sep 20, 2007 | Canon ZR800 Mini DV Digital Camcorder
Firewire (i-link) computer does not recognize cam
as far as the camera not being recognized when using firewire, you have to use a genuine, original Sony i-link/firewire cable. for the longest time i couldn't figure out what was wrong with the camera. i tried two different cables and two different computers. finally i took it to a sony service center and had them check it out. when i went to pickup the camera they said there was no problem. i didn't believe them and asked to talk to the technician that worked on the camera. I told him to show me it worked and was recognized. He did indeed, but using a sony cable. when i gave him my cable to try, it didn't work. luckily they were nice enough to let me go without paying the $80 minimum charge for any work, including the diagnostic "plugging in sony cable" check. I then bought an overpriced sony firewire cable for $25 and everything works. Damn sony's proprietary **** (all the sony people i related this story to blamed the bad quality of the cables i had been using)
Sep 29, 2006 | Sony Handycam DCR-HC42 Mini DV Digital...
Panasonic Palmcorder PV-GS15 Mini DV Digital Camcorder Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
