Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE XL44 Oven - On/Off heating of bottom burner.
When the oven is turned on, the glow burners comes on and it takes about a minute before the gas valve opens and the lower burner comes on. But for some reason, the gas valve starts to open/close and this was visually verified when the cover on the lower burner was removed. The flame is full, then it suddenly seems to loose the gas feed to the point the flame goes out and then suddenly the flame goes full (as if the valve opened). This ossilication goes on and on and on. This occurs as the oven heat up and when it maintains temperature. I would have expected the flame to stay full when initially heating the oven. Have any recommendations (could it be the regulator??). Thanks
  • macbirt56 Feb 08, 2009
    I also have a GE Natural Gas fed oven. Mine also pulses. We noticed this strange noise two days ago coming from the kitchen when we were preheating the oven for supper. I shut down the oven as soon as I realized it was the source of the noise.
    Once it cooled down I removed the bottom cover and turned the oven back on and all was fine for about two minutes the the flame began to pulse, rhythmically. Normal flame...almost out... normal...almost out... this went on for a couple minutes and I decided that it was unlikely to stop so I shut off the oven.
    This is not normal as we have had the oven for 3 years and this has never happened before... we would have heard it it was quite noticable and unsettling.
  • ssnachku Apr 24, 2009
    I have the same problem and it takes 30-40 min to preheat to 350degrees same noises. other day all works normaly
  • 833 Answers
Mag...not sure here. Is there a particular reason that you're suspecting a problem? Does the unit heat much slower than before? Does it bake properly? You may be looking for problems that aren't.
Posted on Dec 13, 2007
I have a GE True Temp XL44 oven the stove burners work fine but the oven will not light. When I turn it on the oven, I do not smell any gas. What is the problem and how do I fix it?
could be a problem with the ignitor. take the racks out of the oven. remove bottom panel in oven. remove metal plate covering the flame spreader. the ignitor should now be visible. turn the oven on. the ignitor should begin to glow. if it doesn't glow bright white, or bright glow, ignitor is bad and needs to be changed.
Feb 13, 2011 | GE Ovens
My ge xl44 oven will not turn on. There is no gas smell or sounds coming from oven. Burners are working fine. Any suggestions?
I have the same problem. Worked fine last night - now nothing from the stove but the top works fine.
Nov 15, 2010 | GE Kitchen Appliances - Others
I have a GE Spectra XL44, model #JGBP40BEC4WH gas oven. The 4 burners on top work but the oven will not. I replaced the oven safety valve (dual type 1), thinking that it was stuck and not directing gas to...
Most likely, you're oven igniter is not getting hot enough to open the gas valve to ignite the burner. It glows like normal, but does not reach the temperature required to open the gas valve. Replace the igniter. Before you replace that, make sure that the small shutoff lever on the appliance regulator was not accidentally closed, which would turn off the gas to the oven, while still allowing gas to the stovetop. The silver lever should be sticking straight out or up. Douglas
Sep 12, 2010 | GE JGRP17 Gas Single Oven
I have a GE Kitchen range XL44, stove top burners work fine, but oven won't light??? HELP please
Unplug the range.
Remove the oven racks.
remove the oven base pan.
remove the flame spreader pan.
remove the glow bar ignitor on the left hand side of the gas burner and replace it with a good ignitor.
Jan 25, 2010 | GE Kitchen Ranges
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44 oven not igniting but burners ignite
The most common failure for a nobake on this type of oven is the bake ignitor. turn unit on and look at the bottom of the oven, you should after about 30-45 seconds see an ORANGE glow, if you do not, chances are you have a failed ignitor.Remove lower part of oven and if you have a meter, place one lead on each terminal and check for continuity( a closed circuit)
If you have an "open" circuit, the ignitor is bad
Feb 26, 2009 | GE JGRP17 Gas Single Oven
GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Oct 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Top works bottom doesn't
I have XL44 oven JGBP26. I replaced the glow ignitore on the oven but still will not glow. I carfully tested the current to the ignitore and showed 125 volts, I also tested the resistance on the control valve lead and to ignitore and showed 1100.
Dec 15, 2007 | GE JGBP28 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
256 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
