Amp works on off on off
I plugged in my amp and turned it on extreme buzz and or hum i plug in my guitar cord and turn the volume up . 3 minutes after playing extreme buzzing/humming next i have to play with the guitar cord at the amp just touch or tap to get it to work again
  • 44 Answers
The buzzing is possibly the electrical mains hum at 50hz, all amps have a hum/buzzing... if you have to tap the jack lead between the guitar and amp it could simply be a connection problem, the cable may be old and internally damages, maybe loose wiring on the other side of one of the input jacks
Jay.D Bsc Music Technology
SEO - Web business optimisation and online promotion
Posted on Dec 16, 2007
The amp plays fine for about 15 to 20 minutes, then an extremely loud, over powering hum/buzz takes over, and then the amp has to be turned off, but the problem persists. I've tried several guitars,...
You say the "tubes are fine" I take it that you have either replaced them with new or used a very sophisticated tester on them. A heater-cathode short might cause the symptom. There are a bunch of tests I would want you to run alnd get back to me with the results.
Heat up the amp but DO NOT play anything into it for the usual failure time or more and they start to play i... did hum occur WITHOUT playing? With all volume controls down does the hum occur?
The right tools is an oscilloscpe to fing out if the filter caps are good. These are C31, C33, C35, C36.
With hum present in failed stater, plug in a grounded plug into the power amp in jack... if hum is stiil there, check the +/- 16 volts regulating Zener for ripple. get schematic here:
Jan 29, 2011 | Fender Hot Rod Deluxe Guitar Combo...
My Line 6 Spider III 30W amp just quit on me. I know the speaker works, I know my guitar and chord work, but the amp doesn't. The amp will power up and all the lights will work, I can press the different...
Test the amp by touching the tip of the cord you unplug from the guitar and preferably try it with a second cable as well. If at high gain you don't get a loud hum, best to take unit for service. If it hums, then check battery in your guitar. The battery in the guitar is enabled when a cable is plugged in and MANY forget to unplug the cable from the guitar and have a dead battery within a day and blame the amp. This applies to most guitars that have preamps in them... there are some that are "passive" that do not have a battery.
Jan 24, 2011 | Line 6 Spider Iii 30
I've plugged my SX RST guitar into the SX GA-1065 amp but I can't get sound to come from the amp. I've made sure everything is plugged in and adjusted, but it still won't work. Why can't I get it to play?
Test the amp cable by plugging in the guitar cable an touching the end of the cord and you should get hum from the amp if the volume controls are up.
Many guitars require a battery to operate the preamp inside them.. Verify if yours needs a battery and it is fresh and properly installed.
These batteries are turned on by plugging in the guitar cable into the guitar. Leaving the cable in will exhaaust the battery, often within a day.
Sep 01, 2010 | Sx Guitars SX SST SE CAR + GA1065 STCAD...
Hi, i just bought a gnx-3 guitar processor and it hums loudly.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like a bad cable or pickup. Set the volume to a level that you can tolerate. You may want to turn off the amp between each of these steps. Unplug the cable from the amp; if the hum does not go away you have problems with the amp. If it does then plug the cable into the amp and short the end that plugs into the instrument. If the hum goes away it is the pick system in the instrument, if not you have a bad cable.
Good Luck
Mar 01, 2010 | Audio Players & Recorders
Generates buzzing noise even when only cable is connected to it. No cable - no noise.
If you are saying that you are plugging a guitar cord into an input on an amp without the guitar on the other end and you are getting a hum or buzz with the volume turned up ; that is normal. If you are getting the same results with a guitar plugged in it means the ground wire to your output jack on your guitar is broken. Check your cord with a volt ohm meter for continuity on the tip on one end to the tip on the other end. Do this for the sleeve on one end to the other. If you were getting the buzz without a cable it would mean that your input jack in your amp has a broken ground connection. Hope this helps.
Jul 04, 2009 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Loud buzzing when amp connects to guitar
Is there a loose connection anywhere?
Jan 03, 2009 | Music
Electric Guitar wont play through Amp
the buzzing is indicative of an open ground connection, check the cord by substitution or with an ohm meter, if the cord is good look at the connections to the jack inside the amp ( im guessing you built the amp from a kit). Is this a solid state amplifier? Tube amps have lethal votages and should not be experimented on without knowledge of electronic safety. Also if there is more than one input to the amp try plugging the guitar into another one and see if its still the same.
Dec 30, 2008 | Yamaha Electric Guitar
I have just purchased a Yamaha EG012 and a Yamaha GA-15 Amplifier. I've followed the instructions adn plugged everything in, but when i turn on the amp and adjust the volumes there is just a buzzing noise...
You may have a switch with 2 settings somewhere on your amp - one for active and one for passive. try changing that.
If this doesn't work, make sure you got the guitar in the line input, change the lead for another incase it's faulty, turn the volume up on the guitar to activate the pickups, and rock-out when you find the problem and fix it.
Guitar Problem I Think.
First check your guitar to amp cord.
The pickup, audio jack, or pickup selection switch may be defective.
Nov 04, 2008 | Washburn Amplifiers: 25 WATT Guitar...
Not sure yet, but before considering a fault with the amp, does it only make this humming noise when not plugged into the guitar? I am thinking that the cable might be faulty.
If it while the cable is plugged in the guitar, does the humming disappear when you turn the volume control(s) down on the guitar? I am thinking that one or pickups may be faulty.
Sep 14, 2008 | Audio Players & Recorders
290 people viewed this question
