Question about Epson Stylus Photo R300 InkJet Printer
Service life has ended on my epson stylus r320 photo printer
What am i to do and how do i do it.
Parts inside your printer are near the end of their service life. See your printer documentation
  • 8 more comments
  • ianbongcayao Apr 26, 2008
    service life has ended on my epson stylus r320 photo printer problem
  • Anonymous May 18, 2008
    PRINTER STATES ORTS COME TO END OF SERVICE LIFE
    PRINTER STATES PARTS INSIDE OF MY PRINTER HAVE COME TO THE END OF THERE SERVICE LIFE
    BOUGHT THE CD EPSON PRINTER FIX 2008 UNABLE TO DO IT WITHOUT INSTRUCTIONS
  • HELMI2neo May 24, 2008
    Parts inside your printer are at the end of their service life. See your printer documentation.
  • Anonymous Jun 09, 2008
    Parts inside your printer are near the end of their service life. See your printer documentation.
  • Anonymous Aug 06, 2008
    Error
    Printer parts are at the end of service life. See printer manual for details.
    no such details are in the manual!
    printer has completely stopped!
  • lk3577 Feb 04, 2009
    Service required. Parts inside the Printer are near the end of their servicelife. i have a C88+ Epson Printer and would like to know what i can do against that Probleme.
  • epsonguy Apr 13, 2009
    Thanks for the advice. Simultaneously pressing stop, maintenance & power buttons for around ten seconds causes the displays to go blank as if the power gos off. Keep pressing them for another few seconds and it resets the ink pad full and a message appears on the LCD screen. I switched the power off then on and moved the ink carrage out of the way by going through the cartridge replacement routine. It is then possible to soak up the excess ink in the pads with tissues and some ink cartridge flush fluid if you have it.
    Reset as if ink cartridge has been replaced. Job done. Printer back in action.
    Thanks for the advice. I can get on with work.
  • b_ts_a May 11, 2010
Thanks for your selflessness Steve H. describing the RESET procedure for the Epson R300 by simutaneouly depressing the POWER, STOP and MAINTENANCE switches.
I checked with Epson, via telephone, and they recommended going to an authorized dealer for ink pad replacement (approximately $100) or buy a new printer ( $150 - $250).
After completing your suggested RESET procedure successfully - I went a step further and mopped up the excess ink that was evident on the 'black ink pad' which was saturated with black ink. I used Kleenex which seemed to mop up the excess BLACK ink nicely, and continued this mopping procedure until there was no evidence of black ink on the Kleenex. There was very little evidence of spilled ink on the color pads.
Time alone will tell. So thanks again Steve - you saved me $100 to $200.
Oh yeah! I LOVE this printer.
Posted on Aug 21, 2008
I have had the same problem and its because I have been using compatible inks. You just need to take it to your nearest Epson dealer and have the ink pads cleaned.
Posted on Dec 28, 2007
Thank you so very much Guest for your solution . I too didn't want to have to buy an new printer and since I am not very smart with fixing things my only solution would of been to do that but thanks to you I was able to contiue using my printer.
Thanks so very much
Bren
Posted on Aug 09, 2008
Service required problem?text me 09192589332
Posted on Mar 29, 2009
My printer (3230) is converted to be a ciss,, does it work the same??
Posted on Feb 07, 2010
To Steve H.
Thank you very much. This worked for us and we thought we had to find a new printer. Love this one and am glad for the fix.
Louis
Posted on Apr 22, 2008
I have had a R300M for a while now and had a few cartridges in it. (Mostly Compatible Cartridges not OEM) Recently a message came up on the screen 'parts inside your printer are at the end of their life' and the printer refused to work!
After searching the web it appears to be a waste ink counter, but I could not find any info on resetting it.
Tried pressing different combinations of buttons on the printer and success. (Found Ink counter reset)
Press and hold 'stop' 'maintenance'(ink button) and 'power' buttons for about 10 seconds,(while printer is on) a message will come up on the screen saying counter is reset and to turn off.
Thats it, turned my printer back on, and all works fine again.
I hope this helps R300/R300M owners out!
(Also I have email into Epson Support, can't wait to hear what they say the problem is for the fix!)
Good Luck,
Steve H.  :-)
Posted on Jan 06, 2008
    Scholar:
  • 94 Answers
Service Required Parts Inside your printer is at the end of service life.This message refers to the ink pads, which are actually a number of porous pads in the printer that collect, distribute, and very importantly contain the ink that is not used on printed pages. Ink is collected by these pads during the initial setup of the product, during cleaning cycles and when printing borderless photographs. Most users will not receive this message before the printer is replaced for other reasons. Some high volume users or those who use the printer for many years may receive this message about ink pads before other components reach the end of their usable live.
The best solution that we can advice regardding this error message are the following:
1. Download the Epson Ink Pad Reset Utility at http://www.epson.com/ipr
2. Since the ink pad is full. It is recommended to send the printer to the nearest authorized epson service center.
Posted on Jun 11, 2008
2 Suggested Answers
shaky120
  • 310 Answers
SOURCE: service life has ended on my epson stylus r320 photo printer
Hi, it means you must contact epson to have it repaired, which usually costs £75 + vat ie cheaper to buy a new one.
parts are too expensive to even attempt to fix the problem yourself..
Happy New Year
John
Posted on Jan 01, 2008
My Epson Stylus photo R320 gave me an error saying "Service required. Printer parts are at end of service life. See printer manual for details". Which parts need replaced? thanks, Holly
It's probably going to be less expensive to REPLACE the whole printer, rather than paying a qualified printer technician $50 to $75 to disassemble the printer, change the parts (which won't be included in that charge for "labour"), to reassemble, and to test it.
Oct 11, 2010 | Epson Stylus Photo R320 InkJet Printer
Service required print parts are at end of service life
You need to reset your printer. Google search for "indoreset for r320" and download it. That is a program you will use to reset your printer.
Jul 22, 2010 | Epson Stylus Photo R320 InkJet Printer
Service required printer parts are at end of life
your printer porous pad need to be replaced.. and the waste ink counter need to be reset...
May 20, 2010 | Epson Stylus Photo R320 InkJet Printer
Waste ink pads - need counter re-set
download "SSC Service utilities" software and try with this program
Dec 21, 2009 | Epson Stylus Photo R320 InkJet Printer
It's is asking service required,
parts inside your printer are near the end of their service life. This is message is coming, how can i do this problem, please tell me
Sep 06, 2009 | Epson STYLUS R230 InkJet Photo Printer
I have Epson stylus photo R320 printer and it keeps on saying parts inside your printer are at the end of their life,?
You need to reset waste ink counter. Don't forget to replace or wash waste ink pad. Or just extend outlet pipe from head cleaning mechanics to outside bottle.Use SSC latest version or R320 adjusment program. Find at indoreset.blogspot.com. Or contact me if you don't find out there. It's free.
Aug 19, 2009 | Epson Stylus Photo R320 InkJet Printer
On your machine it means that the ink absorbers are full. There are around 9 of them. You will need a shop to replace them and then reset the counters.
Aug 10, 2009 | Epson Stylus Photo R320 InkJet Printer
PART INSIDE YOUR PRINTER EPSON STAYLUS PHOTO R230 ARE AT THE END OF THEIR SERVICE LIFE SEE YOU PRINTER DOCUMENTATION
Mar 09, 2009 | Epson Stylus Photo R200 InkJet Printer
Happy New Year
John
Dec 13, 2007 | Epson Stylus CX5400 All-In-One InkJet...
EPSON PRINTER R22O
display This massages Parts inside your printer are near the end of their service life.
Nov 08, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
3,823 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
