Panasonic CT-27SX12 27" TV Logo
Posted on Dec 13, 2007
Rings of Color
I turned on my tv tonight to find the color is distorted into rings. The center is a solid green and takes up most of the screen surrounded by a blue and red ring. Is this fixable (at a reasonable price) or do I junk the tv?
  • rpkcar Aug 01, 2008
    Rings of color with purpley blue in the center , then pink and green. Panasonic CT-27SX12
A
Anonymous
You will need a degausser. Check out Wikipedia for the definition. Look on ebay or your local TV repair shop. Cost should be $20-$100.
Have a halo rainbow effect on the screen. Get a picture but it has an off color with rings of red, green and purple emanating from the center of the screen. Like rings from a pebble in a pond. The rings do...
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Colored Circles
sounds like the degausing coil isnt working or you have a speaker close by.
Color problem
Replace D805 (?) Thermistor for permanent fix, manually
degauss with coil is temporary........T.
Panasonic Color Rings
It sounds like you have a warped shadow mask in your picture tube if your set uses a picture tube. A shadow mask is like a screen wire that lets the three color guns shoot electrons to their respective phosphor dot on the screen to produce the three primary colors which are mixed properly to produce the scene that is being shown. In other words you have a bad picture tube. Stargazer
Color rings on hdtv
Sounds like a CRT (picture tube) that did suffer a bit of a blow to it. The rings are caused by the thin sheet of steel inside of the CRT called a shadow mask being warped. The other cause for this is the internal degauser in the TV comming on and staying on too long causing damage to the CRT. Either way the CRT is over $400 plus you will need to find out what caused the issue and repair that first.
RCA MM36100 color problem
sounds like you have a deguassing problem with your TV .. have the repair person bring out a deguassing coil and see if thsat helps.. This will only be a temp repair as you will have to have the problem that caused this to be fixed. good Luck
2answers
SEEING TRIPLE
Possible problems: 1. Ghosting is caused by an ingress of off-air signals into the TV through the cable system, or the TV's antenna 2. An F-connector may be loose 3. The cable plant may have a "leak" in the area Solutions: 1. Check and hand tighten the cable fittings to the TV set and VCR. 2. Remove the antenna from the VHF terminals when cable is used. 3. A converter or A/B switch may be needed to correct the problem (A/B switch enables you to bypass the set-top cable box or descrambling cable box and tune all unscrambled channels directly with your TV, antenna, or VCR). good luck!
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
