Question about Philips Magnavox 9P6034C 60" Rear Projection Television
No picture nor sound
No picture or sound a friend checked it out and said i needed a power supply board...where can i find to order ?
  • d-ray63 Dec 28, 2007
    no picture and no sound.
    Genius:
  • 1,153 Answers
18008447871
Posted on Dec 24, 2007
Phillips hts3565d/37 will not power up at all
If the set is dead, no sound or picture chances are you have a bad power supply board, the bad news is so do lots of other people, this board has a high failure rate and is really hard to find and if you do find one it will run close to 100 bucks. What you can do is order a repair parts kit for 13 dollars and chance the parts yourself if you know how to solder, if not maybe you have a friend that can do it for you...Ive repaired a number of these boards with this kit and had good success...here is the kit ...Good luck
http://www.shopjimmy.com/philips-996510003225-power-supply-component-repair-kit.htm
Oct 21, 2017 | Televison & Video
32in LG TV. Sound but no picture. Flashlight test = picture. Ordered a new power supply board. Installed it & TV will not power on now. Put the old board back in & it will not power on.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 28, 2017 | LG Televison & Video
Need to know what board to replace next??????
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 25, 2016 | Televison & Video
My TV gets power and sound. The picture is on for a bit and then goes blank, then comes back on, then goes blank. What parts do I need to order to fix it?
http://electro-medical.blogspot.com/
May 17, 2016 | Vizio Televison & Video
Which replacement board to order to fix LCD with no picture, but sound.
Oct 26, 2015 | Sanyo Televison & Video
Toshiba 40 D431J7Y24618K1 sound but no picture approx 6mnths old could it have taken a whack for it not to to have a picture ?
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 02, 2015 | Toshiba Televison & Video
To fix no video Vizio E470i-A0 TV
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 21, 2015 | Vizio Televison & Video
Green light comes on no picmor sound
Hello Afox5, hi, make sure that there are no user controls or setup that are out of order. as a backgrounder, TV of this type mostly has two boards, power supply and main board. On the power supply board, this has two section, primary that deals with mains voltage and secondary that deals with TV supply current requirements, if you see green light mean that power on the secondary section of the power supply board of your TV is working, but it does not mean that the power supplied to the main board is correct, the supplied current produced by the power supply section to the main board that controls sound and picture needs to be checked, so voltages are needed to be checked and loose wiring, or screws needs tightening, are a common trouble, but some go to extremes like replacement of any boards.
Aug 31, 2010 | Sanyo DP42746 42 in. Plasma Television
Here is a number you can call i know they work on all zenith broad exchange they repair some other broads, try them1-800-632-6637. I am not at my shop right now but i will look up parts and supplyers for you I had a 60 phillips that came in yesterday it has no power i am going to look at it today .It could have same problem as yours,ill let you know!
Dec 22, 2007 | Philips 60PP9202 60" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
