Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Motokrzr k1m where the heck does sim card go?? got phone unlocked on ebay cant figure out where card goes can you help me??i see where sdmini goes but not sim jcassidy12000@yahoo.com
  • ljam Jan 04, 2008
    I am having the same problem. I can't locate where the SIM card would go. I've looked every where and tryied Motorola's website but can't find an answer. Please help?
  • Anonymous Apr 20, 2009
    where do you put the sim card on krzr k1m? The picture says memory card only?
  • 4 Answers
The K1M only takes a Transflash card. Remove the battery cover, and at the bottom, you will see a small rubber cover. Pry it out with a fingernail, and insert the Transflash card to to the left. Replace the rubber cover and the battery cover.
Posted on Jan 21, 2008
Hi I got the same phone today. I assume you are trying to install the SIM card as you stated and not the memory SD card as some are talking about.
My manual just shows a picture!
Take out the battery hold the phone with the bottom toward you look at the hole where the battery was.
On the bottom of the square there is a slot in the middle that the SIM card slides into.
THE NOTCH ON THE SIM IS TO THE BOTTOM LEFT CORNER.
Place the SIM card flat against the bottom of the hole where the battery was with the notch as stated and slide it down towards you into place. The SIM just about disappears into the slot. Thats what my manual showed about inserting theSIM card.
Haven't inserted a SD card yet.Hope this helps.
Posted on Oct 09, 2008
It's incorrect, jimsmith78. I just got a KRZR K1m on ebay and installed the sim card in the same location. It works fine.
Posted on Jan 19, 2008
Ya slide off the battery cover and find the rubber flap above where the battery is located. you have to bend the flap up a little, but be sure you got a MIRCO SD and not a MINI SD...
Posted on Jan 06, 2008
  • jimsmith78 Jan 06, 2008
    Oh, sorry, the MOTO KRZR K1m doesn't take a SIM card, only MICRO SD
Behind battery door
Posted on Dec 14, 2007
Cant access any other GSM card in my nokia 6700 classic
in order for you to use it with a different sim card (carrier) you must buy an unlock code, You can usually find one on ebay, just type on the search box: nokia 6700 unlock code
Jun 30, 2010 | Nokia 6700 Classic Cell Phone
Got a motorola razr v3 on ebay. Not reading SIM card.
It may be caused that when you take out sim from old phome it has damaged, try for old one is it still working? if not then your sim is dead, also old phones made SIM-s to be bend and such SIM-s have difficlt electrical connection with new phones.
Also find if "this sim only" is activated in your phone.
It must give you signal, Insert sim card, or insert proper sim. If insert sim card warning card is damaged or have not enough good connection, if another, then this sim only is activated you first you must unlock it to work .
Aug 20, 2009 | Motorola Mobility RAZR V3
Is it possible to unlock my phone so i can use any
it is possible yes you just have to buy sim unlocker it goes under the sim you may find it on ebay.
Aug 10, 2009 | Samsung S8300 Ultra Touch platinium-red...
Cant get phone to work with my at&t sims card
You can purchase ...very cheaply... a universal sim unlock card... it'll slide right between your sim and the connectors in the phone... I put one in a Nokia I purchased and unlocked it so i could use it with my Mexico second line... give it a shot... ebay has em... KE
May 13, 2009 | Cell Phones
I need to relock my unlocked lg vu
i just got mine and noticed the sim card can go in upside down. the same thing happened when i put mine in. try putting the sim card in different ways
Mar 18, 2009 | LG Vu CU920 Cellular Phone
Need samsung g600 unlocking code
I have just tried it with my new locked to orange g600 and it works fine on all networks.
1-Turn on the phone without sim card .
2-Pull off the battery cover and insert any non-accepted sim card (without turning off the handset)
3-Do full reset *2767*3855# , phone will reboot and goes to Menu .
4-Customize Sp-lock code *7465625*638*00000000*00000000#
5-Unlock your phone with new SP code #7465625*638*00000000#
6-Enjoy G600 unlocked
if it doesn't work after step 3.. try changing the 'non-accepted' sim card that ur putting in..
eg if you are locked to vodafone and you try this method and use an orange sim card and it doesn't work, try using a o2 sim or even virgin :)
its easy good luck
Jan 29, 2009 | Samsung SGH-G600 Cellular Phone
UNBLOCK MY PUK CODE
PUK stands for 'Pin Unlock Code', and has to be entered if you've locked your SIM by repeatedly entering the wrong PIN code. If you're asked for a PUK code, you've had more goes at guessing your SIM card PIN code than you're allowed. You'll need to phone your network provider Customer Services for your PUK code to unlock the SIM. For security reasons, it's only the network operator that can legally provide you with a PUK code to unlock your SIM.With some phones you will get a cert card with your sim card and it might have the 8 digit PUK on it. if this has been entered 10 times or more incorrectly then you will need a new sim card
Nov 24, 2008 | LG KU990 Viewty
Phone not reading sim card
dont worry there is some prblm in ur sim pls contact ur customer care there is no prblm in ur phone
Oct 11, 2008 | Motorola Mobility SLVR L7 Cellular Phone
THREE SIM CARD
sorry ,i don't know
May 30, 2008 | Nokia 6600
Unlock Dash T-Mobile
google lokiiz software
Dec 30, 2007 | T-Mobile Dash Smartphone
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
307 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
