Question about Sharp 55R-WP4H 55" Rear Projection Television
VIEW TIMER Tv shuts off view timer keeps blinking please help
  • 4 more comments
  • chovie Dec 31, 2007
    Everyones assistance was greatly apprieciated....but not having a schematic of our tv, i choose to take it in to get checked by a tech.....all of the tech that do come out to check the tv, want a kidney just to check it....
    I guess i'll wait to see what the tech tells me but as far as i know i rate this site with a 10.
  • ebhe Jan 20, 2008
    The screen is black. The view timer light flashs.
  • Duramax Feb 09, 2008
    My view timer light is blinking, will not reset. Sharp email says to call,..18 min hold, before they talk to ya.
  • Anonymous Apr 05, 2008
    VIEW TIME BUTTON BLINKS AND THE TV SCREEN DOES NOT COME ON.
  • Anonymous Apr 20, 2008
    view timer keeps blinking can't turn tv on
  • kerry Boyd Apr 26, 2008
    I unplug the TV and leave it off for 30 minutes. Plug it back in. Usually it will work. But inevitably it will happen again.
  • 934 Answers
Try unplugging the B+ to the convergence circuit and see if it will power up.. If so replace the convergence amps, two STK392-040 and check all the low ohm resistors.
Bill
Posted on Dec 28, 2007
  • William Rayburn
    William Rayburn Dec 31, 2007
    If you rated the site so highly why did I get such poor marks?
    Bill
Ebhe,
Have you fixed the problem on you sharp?
Posted on Feb 03, 2008
How to get marantz tv sllep timer of so tv comes on
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 30, 2014 | Marantz PV-6070 TV
Can timer be shut off early
I have extensive files on timers.
Your timer is not identified by those numbers.
Copy following link to view diehl timer resources:
http://waterheatertimer.org/Woods-timers-and-manuals.html#dial
Add a comment and describe timer in detail for possible identification
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 07, 2013 | Diehl Hardware & Accessories
View timer keeps blinking..tv wont turn on.nobody set view timer..is there a reset button? tried to unplug but no luck
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons need to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterward!)
Apr 14, 2010 | Sharp 55R-WP4H 55" Rear Projection...
Tv shutting off timer light blinking
The problem you describe is not really related to a timer function being set. The unit is in shutdown and the light is blinkng to let you know there is a problem.
There are several possible causes. the most common is a failure in the vertical deflection circuit due to a bad vertical IC and possibly a capacitor, zener diode and resistor.
Feb 19, 2009 | JVC AV-27530 27" TV
JVC TV AV-32870 will not turn on. blinking timer light
Worth taking it in since it is hard to find a new TV for less than $300. I have a 32 inch JVC iart that for about 2 years would turn itself off and the timer light would blink. Only thing that worked would be to disconnect and turn back on. Eventually, the tv "popped" I could smell something that burned out and within 3 weeks tv went "dead" Took it to a tv repair place and replaced power unit for $150. I had similar problem with a 19 inch Philips and that tv has been going strong for 4 years since repair.
Good Luck
Oct 17, 2008 | JVC AV-32820 32" TV
Timer LED flashing and tv screen not viewing
does the tv have a separate tuner box? if so check the cables i have a pioneer that does that when the connection isnt in sync
Apr 09, 2008 | Televison & Video
View timer only lights
TV WILL NOT NOT TURN ON RED VIEW TIMER LIGHT FLASHES AND THEN I CAN'T TURN OFF TV
Mar 29, 2008 | Sharp 61RWP4H 61" Rear Projection...
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
View timer is stuck on
take your set to a tech your problem is more a technical problem that sounds as you are having a chip problem that controls the timer
Feb 16, 2007 | Sharp 55R-WP4H 55" Rear Projection...
Sharp 55R-WP4H 55" Rear Projection Television Logo
297 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
