Question about Aprilaire 700 Humidifier
Aprilaire 700 I need to install a model 50 relay. I need to know hoe to do that.
  • 3 Answers
White wire on fan motor ( neutral ) is placed under clamp on relay , one yellow wire on relay goes to one wire on the solenoid valve , other yellow wire goes to the humidistat
Posted on Dec 28, 2007
Aprilaire model 50 current sensing relay won't close
If the relay is not closing then it must be replaced. It works by sensing the current through the common wire of the blower motor.
Dec 08, 2012 | Aprilaire 50 Current Sensing Relay...
Aprilaire 700. It works on fan on mode but not otherwise. It's never on and the humidity reading is always way below the setting. It should turn on automatically to bring the humidity up, right?
It appears your Aprilaire model 700 is wired to only operate when your HVAC fan is operated by your thermostat. Your HVAC installer can wire the humidifier control to operate the humidifier during a heat call, fan call or to turn on the fan when there is a need for humidification. Please contact your HVAC installer to have them change the wiring.
Thank you for giving us the opportunity to be of service
Sincerely,
Brad Uselmann
Technical Support
Research Products Corporation
www.aprilaire.com
Nov 01, 2010 | Aprilaire 700 Humidifier
I need to change my Aprilaire 700 from *automatic* to *manual
Hi google aprillaire you can donwload manuals for this
Jan 09, 2010 | Aprilaire 700 Humidifier
Circuit board smoked on model 700
Here you go!!http://www.aprilaireparts.com/4238-circuit-board.html
I hope it works, Luis
Oct 18, 2009 | Aprilaire 700 Humidifier
Keep running
You should have a #50 relay hooked up to the main blower assembley to turn the 24 volts on and off with the blower to the humidistat. Alot of humidifiers sold do not tell you about the #50 relay. They assume that you are a hvac pro and you aready know about.
Good luck
HVAC Teacher
Mar 02, 2009 | Aprilaire 600 Humidifier
New Aprilaire 700 - loud hi pitched whistle
You may be having problem with air scaping from the base of the hum. it will probably may have to put silicone around the base of the hum. to stop the air scaping.
Feb 05, 2009 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Doesn't work
check this website for a wiring diaghram Aprilaire 700 Repair Parts & Supplies
http://www.arnoldservice.com/Aprilaire_700_repair_parts_supplies.htm
Dec 07, 2008 | Aprilaire 700 Humidifier
Humidifier control .
if humidifier was wired into thermostat circuit for power instead of seperate transformer , this can happen. you need to see if you voltage going to the solenoid valve. if you do , and it isn't opening, the valve is bad . this is assuming that it is using a # 50 relay to come on only when the fan runs . . make sure the water valve is open
Dec 24, 2007 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
124 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
Mack Baxter
Doug
Level 1 Expert
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
