Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Does not run
My whirlpool will fill in the water, but doesn't wash (agitator doesn't turn)even though I can hear the motor running. If I need to check inside, how can I open the back? thanks
  • fabregas Dec 26, 2007
    my washer filled with water and then it stop. It does not work on any cycle it does not make any noise at all
  • Anonymous Dec 26, 2007
    Washer fills but no other cycles or stations work
  • 83 Answers
Check your motor coupler pull unit out from wall and tip it back and look under unit between motor and transmission for motor coupler
Posted on Dec 13, 2007
Motor is running but won't agitate and belt is on ? I can hear the motor humming and it will fill up but it wont agitate.
Check drum turning by hand ok not sticky sounds like could be motor if it hums and no turn..
Oct 18, 2014 | Hotpoint Washing Machines
Whirlpool washing machine LA5310XPWO wont agitate -- what would cause this and how can it be repaired?
Is this a top or front loader? If it is a top loader do you hear the motor run? If you do the first thing to check is the rubber driver between the motor and the transmission. One way to chek if the motor runs is to fill it with water and put it into spin. If it pumps the water out that means the motor runs. If the rubber driver is broke (happens often) it will neither wash nor spin.
May 20, 2011 | Whirlpool Washing Machines
If I move the agitator manually I can hear water splashing inside even though it is empty and dry
When you move the agitator, your are also turning the motor which is connect to the pump. The water sound you are hearing is the water that is left in the pump.
Jan 07, 2011 | Whirlpool Washing Machines
My whirlpool washer will not drain or spin, but it will fill and wash
This sounds like you are having a problem with the motor not changing direction. The pump for draining is on the front of the motor and runs even when agitating, just it runs backwards therefore keeping the water in the machine. When the motor changes direction, the pump starts taking water out of the tub and at the same time the transmission changes state from agitate to spin.
This could be a bad motor, a bad timer (not connecting the proper wires to reverse motor direction) or even a connection problem with the wiring harness, though the former two are more likely.
Hope this helps
Oct 27, 2009 | Whirlpool Washing Machines
Washer will not agitate or spin
Usually it is the drive coupler in between the motor and transmission. Do you know how to repair that if not read my articles here or contact me.
Apr 19, 2009 | Whirlpool Washing Machines
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer does not agitate after filling with water
does it spin?
sounds like your coupling is broke.It takes the place of the belt if it breaks it won't spin or agitate. it will still pump though.
Part # 285753A
Nov 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
