actually some RAMs don't work on some motherboards especially if the frequency is not supported. You might also try to refresh all connections on your motherboard and reset the CMOS / BIOS (by remove the battery) before installing the RAM. Hope this will help.
As you can see your codes are not listed so I would presume you have the Award BIOS and your problem comes under "Other beep conditions" = memory errors.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
FINALLY! Somebody found exactly what I was looking for! The link showed exactly my problem and I found a solution based on it! THANKS!!!!
" - AnjiiF
Turn the computer off.
Remove all the RAM sticks.
Turn the computer on -- what "beep" code?
Insert ONE RAM stick into the 'DIMM1' slot.
(Look closely at the labels on the motherboard,
to determine which of the RAM-slots is 'DIMM1'.)
Remove the RAM, and insert one "other" stick into DIMM1.
Is the RAM labelled PC100 or PC133 or DDR or DDR266 or DDR333 or DDR400?
Power up the pc and see if the fans are working. If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Was this helpful?
Yes
No
Popular Solutions for Compaq 187498-001 Motherboard
Hello!I have the mother board mentioned below.For this motherboard i want to buy a good graphic card...
(More)
Hello!I have the mother board mentioned below.For this motherboard i want to buy a good graphic card especially fron Nvidia and Ati.Please suggest some of the best graphic cards compatible with my motherboard.I will be very thankful to you.It's urgent. Processor:Intel Pentium III Compaq 187498-001 Motherboard email ID: mrusaims@yahoo.com
