Question about Viking DDBB363 Bottom Freezer Refrigerator
Freezer ice maker not making hardly any ice
Only make a few cubes a day. also ice cream is not very frozen. have on coldest setting
If the temperature of the freezer is above normal (0-5 degrees) the icemaker will not function properly -- you've probably got sealed system issues -- listen to see if the compressor is running -- if so, more than likely have either a leak or a restriction in the sealed system -- if less than 5 yrs old -- call the manufacturer, it might be covered.
Posted on Dec 13, 2007
Model TFH30PRTA NOT KEEPING ICE CREAM FROZEN
Ice cream will get hard when the temperature is closer to - 20 C or -1 F scale. Water becomes Ice at 0 C or 32 F scale.
Ice cream soft means your freezer is not cooling enough.
You were cleaning the coils? Both condenser and evaporator coils? Cleaning coils and then loosing cooling in the fridge is not a good sign or combination. May be there is a freon leak and the seal system is low on freon now.
Call a service tech to check the seal system.
Unfortunately, if it is a leak you may eventually buy a new fridge after spending money on freon fill up, freon system sealant, leak check etc etc... No good news. Sorry
Oct 25, 2017 | GE Profile Performance 29.8 cu. ft....
I have a kenmore upright freezer and can't remember which setting it should be on. It has coldest 1 2 3 etc.
I keep min two notches from the coldest setting.A great way to check where you should set yous,is ice cream.Put an open container of ice cream in the freezer,and turn the freezer to coldest.The next day try to scoop the ice cream.If the ice cream is hard the freezer is too cold.Adjust the freezer two notches ,and try the ice cream the next day.Repeat till you are happy with the hardness of the ice cream.It should be easy to scoop but not too soft.
May 17, 2011 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Ice cream will not freeze, but will make ice cubes.
Actually, it's not as you think. Ice cubes are made between 0-4 degree Celsius and ice creams are frozen below -3 degree Celsius. Your freezer temperature may be between 0 and -3 degree Celsius and that is causing the problem. An ideal freezer should have temperature between -3 and -30 degree Celsius.
Apr 20, 2010 | Samsung RS2578BB Side by Side Refrigerator
Ice Cream won't stay frozen it get's all soft and gross. Main things in the freezer stay frozen.
This is an easy one!!
Ice cream needs to be around -5 degrees to +5 degrees to stay frozen (or hard) if the freezer is at like 15 degrees the ice cream will be soft but the rest of the things like meat and ice cubes will be rock solid because anything lower than 32 degrees is freezing for those things.So you might wanna check to see if the fan motor is working and also make sure the condensor coil is free of debris.
Sep 20, 2009 | Refrigerators
Freezer side will not keep ice cream, popsicles or orange juice frozen. it will make ice in ice cube trays-the ice maker makes very few ice cubes.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check
, defrost heater, defrost thermostat.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 06, 2009 | Frigidaire FRS6R5EMB Side by Side...
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Ice cream is soupy & when I freeze it it becomes icy
Freeze the bowl for at least 24 hrs, rather than the 12 hrs the manual suggests - it will make all the difference in the world. For really thick ice cream, freeze the bowl for a day, and then put the ingredients in the freezer until the outer rim becomes frozen. Very delicious!
-Tha Mp3 Doctor
Dec 10, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
I have the automatic frozen yogurt-ice cream & sorbet maker ICE-20 series made bby CUISINART. The first few times the icecream came out perfect & great. I made ice cream yesterday and it was soupy. I put...
I would actually let the freezer bowl thaw out on a level surface. Then place perfectly level back in the freezer for 24 hours. Should work again. Enjoy!
-Tha Mp3 Doctor
Freezer not freezing
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
barneyluc.
Sep 28, 2008 | KitchenAid Superba Architect KSCS25INSS...
Viking DDBB363 Bottom Freezer Refrigerator Logo
204 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
